2708B
2708B
    B&K
    DMM AUTO RANGING TRUE RMS TOOL
2708B 数据手册
Data Sheet Auto Ranging True RMS Tool Kit® DMM Model 2708B T Specifications RUE RMS A ut o/ Manual Ranging DC Volts Ranges Resolution Accuracy Input Impedance Overload Protection AC Volts (50 H z-500 H z) Crest Factor Ranges Resolution Accuracy Input Impedance Overload Protection DC Current Ranges Resolution Accuracy Select between Auto or Manual ranging The 2708B is a full-featured auto ranging true RMS DMM that combines performance, value and functionality. The 3400 count LCD has a 34 segment bar graph that simulates analog responsiveness. The 2708B can measure resistance values up to 34 MΩ. With the auto power-off-feature you won’t have to worry about accidental battery consumption. Value-packed features make this meter a must in every "Tool Kit®". Features ■ Magnetic hanger ■ One-handed operation ■ True RMS ■ Auto/manual ranging ■ Auto power off ■ Measures up to 10 A (AC & DC) ■ DC voltage to 1000 V ■ AC voltage to 750 V ■ Resistance to 34 MΩ ■ Continuity test ■ Diode test Bar Graph The 34 segment bar graph simulates an analog display by updating at a rate of 12 times per second. model 2708B 340 mV, 3.4 V, 34 V, 340 V, 1000V 0.1 mV, 1 mV, 10 mV, 100 mV, 1 V ±(1.0 % rdg + 2 dgts) 340 mV: >100 MΩ; 3.4 V: 10 MΩ; 34 V to 1000 V: 9.1 MΩ 1000 VDC or 750 VACrms True RMS
2708B 价格&库存
很抱歉,暂时无法提供与“2708B”相匹配的价格&库存,您可以联系我们找货
