2703C
2703C
    B&K
    DMM MANUAL RANGING TOOL KIT
2703C 数据手册
Data Sheet Manual Ranging Tool Kit® DMM Model 2703C Specifications model 2703C DC Volts Ranges Resolution Accuracy Input Impedance Overload Protection AC Volts (50 H z-500 H z) Ranges Resolution Accuracy Input Impedance Overload Protection DC Current Ranges Resolution Accuracy The 2703C is a versatile low cost manual ranging DMM that combines performance, value and functionality. Value-packed features make this meter a must in every "Tool Kit®". Features ■ Magnetic hanger ■ One-handed operation ■ Measures up to 10 A (DC only) ■ DC voltage to 1000 V ■ AC voltage to 750 V ■ Resistance to 20 MΩ ■ Continuity test ■ Diode test Input Protection 10A Input Resis tan ce Ranges Resolution Accuracy Open Circuit Voltage (typical) Overload Protection Diode Te st Test Current Resolution Accuracy Open Circuit Voltage Overload Protection Con tinuity Audible Indication Response Time Overload Protection General Display Polarity Overrange Low Battery Indication Measurement Rate Operating Environment Storage Environment Accuracies Temperature Coefficient Power Battery Life Dimensions Weight 2 V, 20 V, 200 V, 1000V 1 mV, 10 mV, 100 mV, 1 V ±(1.2 % rdg + 1 dgts) 10 MΩ 1000 VDC or 750 VACrms 200 V, 750 V 100 mV, 1 V 200 V range: ±(2.0 % rdg + 5 dgts) 750 V range: ±(2.0 % rdg + 10 dgts) 10 MΩ 1000 VDC or 750 VACrms 2 mA, 20 mA, 200 mA, 10 A 1 uA, 10 uA, 100 uA, 10 mA 2 mA to 200 mA ranges: ±(1.5 % rdg + 1 dgts) 10 A range: ±(3.0 % rdg + 3 dgts) 0.5 A/500 V & 10 A/600 V fast blow ceramic fuses 10 A for 60 sec max. followed by 10 min cooling period 200 Ω, 2 kΩ, 20 kΩ, 200 kΩ, 20 MΩ 0.1 Ω, 1.0 Ω, 10 Ω, 100 Ω, 10 kΩ, 200 Ω to 200 kΩ ranges: ±(1.5 % rdg + 4 dgts) 20 MΩ range: ±(3.0 % rdg + 5 dgts) 0.3 VDC (3.0 VDC on 200 Ω) 500 VDC/ACrms 1.0 mA (typical) 10 mV ±(3.0 % rdg + 3 dgts) 3.0 VDC (typical) 500 VDC/ACrms Less than 100 Ω 100 ms 500 VDC/ACrms 3 1/2 digit, 2000 count LCD Automatic, positive implied, negative polarity indication OL or -OL is displayed Battery symbol will display when battery voltage drps below operating levels 2.5 times per second 0ºC to 50ºC at
2703C 价格&库存
很抱歉,暂时无法提供与“2703C”相匹配的价格&库存,您可以联系我们找货
