2706B
2706B
    B&K
    DMM W/TEMP MANUAL RANGING TOOL
2706B 数据手册
Data Sheet Manual Ranging Tool Kit® DMM with Temperature Model 2706B LC D bac k light Ultra bright blue LCD back light for low ambient light measurements The 2706B is a versatile manual-ranging DMM with temperature measurement. The 2000 count LCD has a bright blue back light that allows the meter to be used in dimly lit environments. With the auto-power-off feature you won’t have to worry about accidental battery consumption. Value-packed features make this meter a must in every "Tool Kit®". Features ■ Auto power off ■ AC voltage to 750 V ■ DC voltage to 1000 V ■ Capacitance to 20 mF ■ Resistance to 20 MΩ ■ Continuity test ■ One-handed operation ■ Diode test ■ Magnetic hanger ■ Bright blue LCD backlight Specifications model 2706B D C Volts Ranges 200 mV, 2000 mV, 20 V, 200 V 1000 V Resolution 0.1 mV, 1 mV, 10 mV, 100 mV, 1 V Accuracy ±(0.5 % rdg + 1 dgts) Input Impedance 10 MΩ Overload Protection 1000 VDC or 750 VACrms* A C Volts (50 Hz-500 Hz) Ranges 200 mV, 2000 mV, 20 V, 200 V 750 V Resolution 0.1 mV, 1 mV, 10 mV, 100 mV, 1 V Accuracy 200 mV & 20 V ranges: ±(1.2 % rdg + 5 dgts) 200 V & 750 V ranges: ±(2.0 % rdg + 5 dgts) Input Impedance 10 MΩ Overload Protection 1000 VDC or 750 VACrms* DC Current Ranges 200 uA, 20 mA, 200 mA Resolution 0.1 uA, 10 uA, 100 uA ±(1.0% rdg + 1 dgts) Accuracy 0.25 A/500 V fast blow ceramic fuse Input Protection AC Cu rrent (50 Hz-500 Hz) Ranges 200 uA, 20 mA, 200 mA Resolution 0.1 uA, 10 uA, 100 uA ±(1.5% rdg + 5 dgts) Accuracy Input Protection 0.25 A/500 V fast blow ceramic fuse Resis tan ce Ranges 200 Ω, 2 kΩ, 200 kΩ, 20 MΩ 0.1 Ω, 1.0 Ω, 100 Ω, 10 kΩ, Resolution Accuracy 200 Ω to 200 kΩ ranges: ±(1.0 % rdg + 4 dgts) 20MΩ range: ±(2.0 % rdg + 4 dgts) Open Circuit Voltage (typical) 0.3 VDC (3.0 VDC on 200 Ω) 500 VDC/ACrms Overload Protection Capacitance 200 uF, 2 mF, 20 mF Ranges 0.1 uF, 1.0 uF, 10 uF Resolution Accuracy ±(4 % rdg + 10 dgts) Overload Protection 0.25 A/500 V fast blow ceramic fuse Fre qu ency 10 Hz to 40 kHz Ranges Resolution 1 Hz Accuracy ±(0.1 % rdg + 3 dgts) Sensitivity 3.5 Vrms minimum Overload Protection 500 VDC/AC rms Diode Te st Test Current 1.0 mA (typical) Resolution 10 mV Accuracy ±(1.5 % rdg + 3 dgts) Open Circuit Voltage 3.0 VDC (typical) Overload Protection 500 VDC/ACrms Con tinuity Audible Indication Less than 100 Ω Response Time 100 ms Overload Protection 500 VDC/ACrms Temperature Ranges -35ºC to 750ºC, -30ºF to 1400ºF Resolution 0.1ºC, 0.1ºF Accuracy 0ºC to 400ºC ±(1.0 % rdg + 1ºC) -35ºC to 0ºC, 400ºC to 750ºC ±(3.0 % rdg + 3ºC) -4ºF to 750ºF ±(1.0 % rdg + 2ºF) -30ºF to -4ºF, 750ºF to 1400ºF ±(3.0 % rdg + 6ºF) Sensor Type K-type thermocouple Overload Protection 60 VDC or 30 VACrms General Display 3 1/2 digit, 2000 count LCD Polarity Automatic, positive implied, negative polarity indication Overrange OL or -OL is displayed Low Battery Indication Battery symbol will display when battery voltage drops below operating levels Measurement Rate 2.5 times per second Auto Power Off Approximately 25 minutes Operating Environment 0ºC to 50ºC at
2706B 价格&库存
很抱歉,暂时无法提供与“2706B”相匹配的价格&库存,您可以联系我们找货
