2704CKIT
2704CKIT
    B&K
    2704CDMMWITHTESTLEADS
2704CKIT 数据手册
Data Sheet Manual Ranging Tool Kit® DMM with Transistor Test Model 2704C hFE Transist or Test Measures commonemitter gain. The 2704C has all of the functionality for basic DMM applications including some high end features you might not expect. The 2000 count LCD can display resistance values up to 2 GΩ, capacitance to 20 uF or a transistors common-emitter gain value up to 1000. Value-packed features make this meter a must in every "Tool Kit®". Features ■ Magnetic hanger ■ DC voltage to 1000 V ■ AC voltage to 750 V ■ Resistance to 2000 MΩ ■ Capacitance to 20 uF ■ Continuity test ■ Diode test ■ Logic test ■ hFE Transistor test ■ One-handed operation ■ Measures up to 10 A (AC & DC) Specifications model 2704C D C Volts Ranges 200 mV, 2 V, 20 V, 200 V, 1000V Resolution 0.1 mV, 1 mV, 10 mV, 100 mV, 1 V Accuracy ±(0.8 % rdg + 1 dgts) Input Impedance 10 MΩ Overload Protection 1000 VDC or 750 VACrms* A C Volts (50 Hz-500 Hz) Ranges 200 mV, 2 V, 20 V, 200 V, 750V Resolution 0.1 mV, 1 mV, 10 mV, 100 mV, 1 V Accuracy 200 mV & 20 V ranges: ±(1.5 % rdg + 5 dgts) 200 V & 750 V ranges: ±(2.0 % rdg + 5 dgts) Input Impedance 10 MΩ Overload Protection 1000 VDC or 750 VACrms* D C Cu rrent Ranges 20 mA, 200 mA, 10 A Resolution 10 uA, 100 uA, 10 mA Accuracy 20 mA to 200 mA ranges: ±(1.0 % rdg + 1 dgts) 10 A range: ±(3.0 % rdg + 3 dgts) Input Protection 0.5 A/500 V & 10 A/600 V fast blow ceramic fuses 10A Input 10 A for 60 sec max. followed by a 10 minute cooling period Technical data subject to change © B&K Precision Corp. 2013 Page 1 of 2 AC Curren t (50 Hz-500 H z) Ranges 20 mA, 200 mA, 10 A 10 uA, 100 uA, 10 mA Resolution 20 mA to 200 mA ranges: ±(2.0 % rdg + 5 dgts) Accuracy 10 A range: ±(3.0 % rdg + 5 dgts) Input Protection 0.5 A/500 V & 10 A/600 V fast blow ceramic fuses 10 A for 60 sec max. followed by a 10 minute cooling period 10A Input Resis tan ce Ranges 200 Ω, 2 kΩ, 200 kΩ, 20 MΩ, 2000 MΩ Resolution 0.1 Ω, 1.0 Ω, 100 Ω, 10 kΩ, 1 MΩ 200 Ω to 200 kΩ ranges: ±(1.0 % rdg + 4 dgts) Accuracy 20 MΩ range: ±(2.0 % rdg + 4 dgts) 2000 MΩ range: ±(5.0 % rdg + 10 dgts) Open Circuit Voltage (typical) 0.3 VDC (3.0 VDC on 200 Ω, 2000 MΩ range) Overload Protection 500 VDC/ACrms Capacitance Ranges 2 nF , 20 nF, 200 nF, 2.0 uF, 20 uF 1 pF, 10 pF, 100 pF, 1 nF, 10 nF Resolution ±(4 % rdg + 10 dgts) Accuracy Overload Protection Discharge capacitor before connecting Fre qu ency Ranges 2 kHz, 20 kHz, 200 kHz, 2 MHz, 20 MHz Resolution 1 Hz, 10 Hz, 100 Hz, 1 kHz, 10 kHz Accuracy ±(0.1 % rdg + 3 dgts) Sensitivity 2.0 Vrms minimum Minimum Pulse Width >25 ns Duty Cycle Limits >30 % and
2704CKIT 价格&库存
很抱歉,暂时无法提供与“2704CKIT”相匹配的价格&库存,您可以联系我们找货
