122
122
    TPI(TPI 公司)
    COMPACT DIGITAL MULTIMETER
122 数据手册
STEP BY STEP PROCEDURES: 7 a.Measuring DC Volts STEP BY STEP PROCEDURES: WARNING! Do not attempt to make a voltage measurement of more than 1000V or of a voltage level that is unknown. Instrument set-up: Instrument set-up: DCV BLACK TEST LEAD RED TEST LEAD MIN READING MAX READING COM VΩ 1mV 600V FUNC BLACK TEST LEAD RED TEST LEAD MIN READING MAX READING ACV COM V/Ω 1mV 600V Measurement Procedure: Measurement Procedure: 1. 2. 3 4. 1. 2. 3. 4. 5. 6. 7. Instruction Manual b. Measuring AC Volts WARNING! Do not attempt to make a voltage measurement of more than 600V or of a voltage level that is unknown. FUNC Digital Multimeter 122 8 Disconnect power to circuit to be measured. Plug the black test lead into the COM input jack. Ω input jack. Plug red test lead into V/Ω Set rotary switch on 122 to desired range in DCV function depending on the voltage to be measured. Connect the test leads to the circuit to be measured. Reconnect power to the circuit to be measured. Read the voltage on the 122. 5. 6. Test Products International, Inc. 9615 SW Allen Blvd., Ste. 104 Beaverton, OR USA 97005 503-520-9197 • Fax: 503-520-1225 tpiusa@msn.com Test Products International, Ltd. Disconnect power to circuit to be measured. Plug the black test lead into the COM input jack. Ω input jack. Plug red test lead into V/Ω Set rotary switch on the 122 to desired range in ACV function depending on the voltage to be measured. Connect the test leads to the circuit to be measured. Reconnect power to the circuit to be measured. 342 Bronte Road South, Unit 9 Milton, Ontario L9T5B7 Canada 905-693-8558 • Fax: 905-693-0888 L122M • 12/1/97 copyright © 1998 Test Products International, Inc. STEP BY STEP PROCEDURES: 9 c. Measuring Resistance WARNING! Do not attempt to make continuity measurements with circuit energized. Instrument set-up: NOTE: To make accurate low ohm measurements, short ends of test leads together and record resistance reading. Deduct this value from actual readings. FUNCTION OHM( ) BLACK TEST LEAD RED TEST LEAD COM VΩ Measurement Procedure: Instrument set-up: FUNC BLACK TEST LEAD RED TEST LEAD MIN READING MAX READING OHM COM VΩ 1Ω 2.000kΩ Measurement Procedure: 5. 6. 10 d. Continuity Buzzer WARNING! Do not attempt to make resistance measurements with circuit energized. For best results, remove resistor completely from circuit before attempting to measure. 1. 2. 3. 4. STEP BY STEP PROCEDURES: Disconnect power to the circuit to be measured. Plug the black test lead into the COM input jack. Ω input jack. Plug the red test lead into the V/Ω Ω function Set rotary switch on the 122 to 2kΩ depending on the voltage to be measured. Connect the test leads to the circuit to be measured. Read the resistance value on the 122. 1. 2. 3. 4. 5. 6. Disconnect power to the circuit to be measured. Plug the black test lead into the COM input jack. Ω input jack. Plug the red test lead into the V/Ω Set the rotary switch on the 122 to the position. Connect the test leads to the circuit to be measured. Listen for the buzzer to confirm continuity. Standard Accessories Part No. 9V Battery Test Lead Set Rubber Boot (122 only) A009 A040 A121 Optional Accessories Part No. Deluxe Test Lead Set Microamp Adapter Temperature Adapter Carbon Monoxide Accessories Boot Hook Soft Carrying Case Carrying Case for multiple instruments SDK1C A112 A301 A701/A702/A711 A120 A255 A901 *These accessories have not been evaluated by UL and are not considered as part of the UL Listing of this product. MAINTENANCE 1. e. Data Hold Press the DATA-H button at any time on any function or range to freeze the reading on the LCD display. This function is very useful when measuring in locations where the display is difficult to read. 2. Battery Replacement: The 122 will display BAT when the internal 9 Volt battery needs replacement. The battery is replaced as follows: a. Disconnect and remove all test leads from live circuits and from 122. b. Remove the 122 from its protective boot. c. Remove the four screws from back of 122 housing. d. Carefully pull apart front and rear instrument housing. e. Remove old battery and replace it with new battery. f. Reassemble instrument in reverse order from above. Cleaning your 122 Use a mild detergent and slightly damp cloth to clean the surfaces of 122. EC DECLARATION OF CONFORMITY 1 This is to certify that model 122 conforms to the protection requirements of the council directive 89/336/EEC, in the approximation of laws of the member states relating to Electromagnetic compatibility and 73/23/EEC, The Low Voltage Directive by application of the following standards: EN 50081-1 EN 50082-1 EN61010-1 EN61010-2-031 SAFETY CONSIDERATIONS Even though this instrument complies with the immunity standards, the accuracy can be affected by strong radio emissions not covered in the above standards. Sources such as hand held radio transceivers, radio and TV transmitters, vehicle radios and cellular phones generate electromagnetic radiation that could be induced into the test leads of this instrument. Care should be taken to avoid such situations or alternatively, check to make sure that the instrument is not being influenced by these emissions. • • • • • • Line voltage. Control circuit voltage. Heating element resistance (continuity). Compressor winding resistance. Contactor and relay coil resistance. Continuity of wiring. ACV OHMS DCV • • • Measure line voltage. Continuity of circuit breakers. Voltage of direct drive DC motors. SPECIFICATIONS a. General Specifications Power Supply Battery Life Size (H x L x W) Weight REFER TO INSTRUCTION MANUAL 4 GROUND • Inspect test leads before using to make sure there are no breaks or shorts. DOUBLE INSULATION • Double check all connections before testing. ON/OFF, PUSH BUTTON SWITCH • Have someone check on you periodically if working alone. • Have a complete understanding of circuit being measured. Features and Benefits • Disconnect power to circuit, then connect test leads to the 122, then to circuit being measured. Safety Meets CE and IEC 1010 requirements. UL Listed. Large LCD Easy to read at all angles and the majority of lighting levels. Data Hold Freeze readings on the display. NEVER • Attempt to measure unknown high voltages. • Attempt to measure current with the meter in parallel to the circuit. Rubber Boot Added protection when the instrument is dropped. (122NB does not include boot.) • Connect the test leads to a live circuit before setting up the instrument. Versatile • Touch any exposed metal part of the test lead assembly. SPECIFICATIONS (cont.) 5 IEC 1010 Over Voltage: CAT II - 1000V, CAT III - 600V Pollution Degree 2 9 Volt Battery 560 hrs. Alkaline 33mm x 86mm x 187mm (1.3” x 3.4” x 7.4”) 340g (12 oz) Range 2000mV 200V 600V Resolution 1mV 0.01V 0.1V 0.1V Accuracy ±0.5% of reading, ±2 digits Impedance 10M Ohm 6 Resolution 1mv 0.1V 1V Resolution 0.001kΩ Turns the 122 on and off. D/H Activates the Data Hold function. Rotary Switch Accuracy Impedance ±1.2% of reading, ±3 digits 10M Ohm Ω) d. OHM (Resistance,Ω Range 2kΩ MEASUREMENT TECHNIQUES Push Buttons b. DCV Range 2000mv 20V 200V 600V Use accessories like a carbon monoxide attachment to expand the capabilities of the 122. 1. Controls and Functions: c. ACV (45Hz to 450Hz) ELECTRICAL FUNCTION DC (DIRECT CURRENT) Test the 122 before using it to make sure it is operating properly. Perform the following with the TPI 122 and appropriate function: ACV ACV or DCV OHMS OHMS OHMS OHMS AC (ALTERNATING CURRENT) • CAUTION: 3 CAUTION: RISK OF ELECTRIC SHOCK GENERAL GUIDELINES ALWAYS To ensure conformity with these standards, this instrument must be operated in accordance with the instructions and specifications given in this manual. HVAC/R FUNCTION INTERNATIONAL SYMBOLS WARNING: Please follow manufacturers test procedures whenever possible. Do not attempt to measure unknown voltages or components until a complete understanding of the circuit is obtained. 1992 Emissions Standard 1992 Immunity Standard 1993 Safety Standard 1995 Safety Standard PRODUCT APPLICATIONS 2 Accuracy ±0. 5% of reading, ±1 digit V Used for measurement of DC Volts. Select best range for the voltage to be measured. V Used for measurement of AC Volts. Select best range for the voltage to be measured. Ω Used for measurement of Resistance and Continuity. Overload Protection 600V DC or AC Peak Input Jacks e. Continuity Buzzer Test Voltage 2.5V Threshold
很抱歉,暂时无法提供与“122”相匹配的价格&库存,您可以联系我们找货
