391AKIT
391AKIT
    B&K
    TRUE RMS DMM W/TEST LEAD SET
391AKIT 数据手册
Data Sheet Handheld Digital Multimeters Test Bench® Series High Quality, Ruggedized, Multifunctional High performance and value priced, the Test Bench® Series offers more features for the dollar than other multimeters. In addition to measuring voltage and current, the meters also measure capacitance, frequency and temperature, and include component test, diode test and logic indicator capabilities. See the chart below for the meter that best fits your needs. A double injection molded case provides improved grip and protection for the meters. Features and Benefits Features ■ Resistance measurement ■ Frequency measurement ■ Diode check ■ Audible continuity ■ All current ranges fused ■ Auto power off ■ Ruggedized case ■ CATIII 1000 V, (all models) ■ CATIV 600 V, (392 & 393) 392 & 393 True RMS Ranging DCV Accuracy AC/DC Voltage and Current Display Digits, Count Bar Graph Capacitance Measurement Transistor Test Temperature Probe Logic Probe Relative Mode Min/Max Hold Peak Hold Data Hold USB √ Auto/Manual 0.08% √ 60000, 4 5/6 √ √ √ √ √ √ √ 393 only 391A √ Manual 0.05% √ 20000, 4 1/2 √ √ - 390A 389A 388B Auto/Manual 0.1% √ 4000, 3 3/4 √ √ √ √ √ √ √ √ Auto/Manual 0.25% √ 4000, 3 3/4 √ √ √ √ √ √ - Manual 0.5% √ 4000, 3 3/4 √ √ √ - Specifications 392 & 393 391A 390A 389A 388B Volts True RMS reading True RMS reading - - - 600 mV, 6 V, 60V, 600 V, 1000 V 200 mV, 2 V, 20 V, 200 V, 1,000 V DC Ranges 400 mv, 4 V, 40 V, 400 V, 1000 V AC Ranges 600 mV, 6 V, 60V, 600 V, 750 V 200 mV, 2 V, 20 V, 200 V, 750 V 400 mv, 4 V, 40 V, 400 V, 750 V Resolution 0.01 mV, 0.1 mV, 1 mV, 10 mV, 100 mV 10 µV, 100 mV, 1 mV 10 mV, 100 mV 100 µV, 1 mV, 10 mV, 100 mV, 1 V Basic DC Accuracy ±(0.08% rdg + 5 dgt) ±(0.05% + 3 dgt) Basic AC Accuracy ±(1.5% rdg + 20 dgt) 500 Hz -1 kHz ±(2% + 10 dgt) 500 Hz - 2 kHz Overload Protection 1000 VDC or 750 VAC rms 1200 VDC or AC rms 500 VDC/AC rms 15 sec on 200 mV range 1100 VDC or AC rms 1000 VDC or peak AC 1200 VDC or AC rms 500 VDC/AC rms 15 sec on 200 mV range Input Impedance 10 MΩ, 11 MΩ on 6 V range 10 MΩ 400 mV: >100 MΩ, 4V: 10 MΩ 40 V - 1000 V: 9.1 MΩ 10 MΩ Technical data subject to change © B&K Precision Corp. 2017 ±(0.1% rdg + 2 dgt) ±(0.25% rdg + 2 dgt) ±(1.5% rdg +5 dgt) 500 Hz - 1 kHz www.bkprecision.com ±(0.5% rdg + 1 dgt) ±(1.5% rdg +3 dgt) 500 Hz - 1 kHz High Performance DMM Test Bench® Series Specifications Current Ranges Resolution DC Accuracy AC Accuracy Input Protection Max. Burden Voltage Resistance Ranges Resolution Accuracy Open Circuit Voltage Overload Protection Diode Test Transistor Test (hFE) Capacitance Ranges Resolution Accuracy Test Voltage Overload Protection 392 & 393 391A 600 µA, 6000 µA, 60 mA, 400 mA, 20 A* 10 nA, 100 nA, 1 µA, 10 µA, 1 mA 600 µA to 60 mA: ±(0.5% rdg + 10 dgt) 400 mA: ±(1.0% rdg + 10 dgt) 20 A: ±(2.0% rdg + 10 dgt) 200 µA, 2 mA, 20 mA, 200 mA, 20 A* 10 nA, 100 nA, 1 µA, 10 µA, 1 mA 600 µA to 400 mA: ±(1.5% rdg + 20 dgt) 20 A: ±(2.5% rdg + 20 dgt) µA/mA input: 0.5A/100V fast blow ceramic fuse 20A input: 20A/600A fast blow ceramic fuse 500 mV on 600 µA & 60 mA ranges, 2 V on 6000 µA range 600 Ω, 6 kΩ, 60 kΩ, 600 kΩ, 6 MΩ, 60 MΩ 10 mΩ, 100 mΩ, 1 Ω, 10 Ω, 100 Ω, 1 kΩ 600 Ω: ±(0.3% rdg + 20 dgt), 6 kΩ to 6 MΩ: ±(0.3% rdg + 10 dgt), 6 MΩ: ±(1.0% rdg + 10 dgt), 60 MΩ: ±(3.0% rdg + 20 dgt) -1.2 VDC typical, -3.0 VDC typical on 600 Ω range 600 VDC or 600 VAC rms Tested at 0.5 mA, 2 VDC max. typical ±(2.0% rdg + 10 dgt) accuracy Does not apply 6 nF, 60 nF, 600 nF, 6 µF, 60 µF, 600 µF, 6 mF 1 pF, 10 pF, 100 pF, 1 nF, 10 nF, 100 nF, 1 µF 6 nF: ±(3% rdg+30 dgt), 60 nF to 600 µF: ±(3% rdg +10dgt), 6 mF: ±(5% rdg+10 dgt) 30% & 0 Hz 600 VDC or 600 VAC rms Ranges Resolution Logic Test Logic Threshold Frequency Response Pulse Width Pulse Limits Indication Overload Protection 2 kHz, 20 kHz, 200 kHz 0.1 Hz, 1 Hz, 10 Hz ±(0.1% rdg + 3 dgt) 50 mVrms min. (At>30 & 25 ns >30% & 60dgt; 200kHz>60dgt 4 kHz, 40 kHz, 400 kHz, 4 MHz, 40 MHz 4 kHz, 40 kHz, 400 kHz, 4 MHz 1 Hz, 10 Hz, 100 Hz, 10 kHz, 100 kHz 1 Hz, 10 Hz, 100 Hz, 10 kHz ±(0.1% rdg + 3 dgt) ±(0.25% + 4 dgt) 1 Hz - 4 MHz: 1Vrms 4 MHz - 40 MHz: >2 Vrms, 25 ns >30% & 2 µs - - Hi: 2.8±0.8 V, Lo: 0.8 ± 0.5 V 20 MHz 25 ns >20% and 20% and
391AKIT 价格&库存
很抱歉,暂时无法提供与“391AKIT”相匹配的价格&库存,您可以联系我们找货
