DM-510A-C
DM-510A-C
    GREENLEECOMMUNICATIONS(格林利)
    DMM TRMS AC/DC
DM-510A-C 数据手册
DMM,TRMS,AC/DC(DM-510A)(CALIB) Professional Plant Digital Multimeter Cat No: DM-510A-C UPC No: 783310357582 Description • • • • • • • • • • • • • • • • • Measures voltage, current, resistance and frequency Tests continuity and diodes Backlit LCD with 6,000 count display Two voltage detection modes - non-contact or using a single test lead BeepJack warns when test leads are incorrectly inserted in current measurement terminals Automatic and manual rangeselection Relative offset mode to see changes in measurements Data hold Use optional USB / RS-232 interface DMSC-2U for direct-to-PC logging Lifetime Limited Warranty Accessories included: (2)1.5V AAA batteries, bead temperature probe (DM-210A, DM-510A only, 400 DEG F/204 DEG C max), test leads, protective boot True RMS for no-compromise accuracy Crest capture (peak hold)plus recording of max, min, max-min and average Low impedance AutoCheck mode - automatically selects ACor DC volts, resistance or continuity, Low impedance masks ghost voltage pickup Measures capacitance Measures temperature using a type K thermocouple Includes Certificate of Calibration Specifications • • • • • • • • • • • • • • Amperage Measurement : 600, 6000 MICAMP, 60, 600 MILAMP, 6, 8 AMP Battery : (2) 1.5 V AAA Capacitance : 60, 600 NFD, 6, 60, 600, 3000MFD Display : Backlit LCD With 6,000 Count Frequency Measurement : 10 HZ - 50 KHZ Sine Wave, 5 HZ - 999.9 KHZ Logic Level Square Wave Includes : (2) 1.5V AAA Batteries, Bead Temperature Probe (DM-210A, DM-510A Only, 400 DEG F/204 DEG C max), Test leads, ProtectiveBoot Measurement Category : CAT IV 300 V, CAT III 600 V, CAT II 1000 V Replacement Part : TSG-3 Sure-Grip Test Leads Resistance Measurement : 600 OHM, 6, 60, 600 KOHM, 6, 60 MOHM Standard : CAT IV, CAT III, CAT II, C/ULUS Listed, CE Listed Sub Brand : ESM Temperature Rating : K Type, -58 To 1832 DEG F (-50 To 1000 DEG C) Type : Professional Plant Digital Voltage Measurement : 60, 600 MILV, 6, 60, 600, 1000 V
DM-510A-C 价格&库存
很抱歉,暂时无法提供与“DM-510A-C”相匹配的价格&库存,您可以联系我们找货
