DM-830A-C
DM-830A-C
    GREENLEECOMMUNICATIONS(格林利)
    DMM TRMS AC/DC
DM-830A-C 数据手册
DMM,TRMS AC+DC(DM-830A)(CALIB) Digital Multimeter Cat No: DM-830A-C UPC No: 783310357704 Description • • • • • • • • • • • • • • • • • • • True RMS For No-Compromise Accuracy Measures Voltage, Current,Resistance, Capacitance And Frequency Tests Continuity And Diodes Backlit LCD With Dual 10,000 Count Displays BeepJack Warns When Test Leads Are Incorrectly Inserted In Current Measurement Terminals Automatic And Manual RangeSelection Relative Offset Mode To See Changes In Measurements Data Hold Use Optional USB InterfaceDMSC-9U For Direct-To-PC Logging Lifetime Limited Warranty AC+DC True RMS gives accurate readings on complex waveforms Low impedance AutoCheck mode - automatically selects AC or DC volts, resistance or continuity. Low impedance masks ghost voltage pickup dBm function with 20 selectable reference impedance values Crest capture (peak hold)plus recording of max, min, max-min and average Two voltage detection modes - non-contact or using a single test lead Two temperature measurements using type K thermocouples Conductance measurement Accessories included: (1)9V battery, bead temperature probe (DM-820A, DM-830A only, 400 DEG F/204 DEG C max), testleads, protective boot, carrying case Includes Certificate of Calibration Specifications • • • • • • • • • • • • • • Amperage Measurement : 600, 6000 MICAMP, 60, 600 MILAMP, 6, 10 AMP Battery : (1) 9 V Capacitance : 60, 600 NFD, 6, 60, 600 MFD, 6, 25 MILFD Conductance : 99.99 nS Display : Backlit LCD With Dual 10,000 Count Frequency Measurement : 15 HZ - 50 KHZ Sine Wave, 5 HZ - 1 MHZ Logic Level Square Wave Includes : (1) 9V Battery, Bead Temperature Probe (DM-820A, DM-830A Only, 400 DEG F/204 DEG C Max), Test Leads, Protective Boot, Carrying Case Measurement Category : CAT IV, 1000 V Replacement Part : TC-20 Carrying Case, TSG-3 Sure-Grip Test Leads, TPB Bead Temperature Probe (Included With DM-820A, DM-830A) Resistance Measurement : 600 OHM, 6, 60, 600 KOHM, 6, 60 MOHM Standard : CAT IV, C/UL US Listed, TRUE RMS, CE Listed Temperature Rating : K Type, -58 To 1832 DEG F (-50 To 1000 DEG C) Type : Digital Voltage Measurement : 60, 600 MILV, 9.999, 99.99, 999.9 V
DM-830A-C 价格&库存
很抱歉,暂时无法提供与“DM-830A-C”相匹配的价格&库存,您可以联系我们找货
