DMM 500K COUNTS (DM-860A) (CALIB)
Industrial 500,000-Count Digital Multimeter (Calibrated)
Cat No:
DM-860A-C
UPC No:
783310020691
Description
True RMS, 5-5/6-digit, 500,000-count display for greater accuracy
Audible input alert helps avoid damage to meter
Record max, min, and max-min and data hold
Crest capture (peak hold) max, min and max-min readings
Relative offset display mode makes monitoring relative measurement changes simple
Performs frequency, temperature and capacitance measurements, plus diode and continuity tests
Measures temperatures up to 1832°F
Autoranging for convenientoperation - and to save you time
42-segment analog bar graph display capability makes it easy to view quick changes
Bright, backlit display is easy to read under any light condition
RS-232 capable, may be connected to a PC for extended measurement capability with optional
interface DMSC-9
Accessories included: (1)9V battery, bead temperature probe (400°F/ 204°C max.), test leads,
protective boot, carrying case
Lifetime Limited Warranty
Specifications
Accessory : (1) 9V battery, bead temperature probe (400°F/ 204°C max.),test leads, protective
boot, carrying case
Application : Performs Resistance, Conductance, Frequency, Duty Cycle, Temperature And
Capacitance Measurements, Plus Diode And Continuity Tests
Battery : 9 V
Replacement Part : TC-20, Carrying Case (included), TSG-3, Sure-Grip Test Leads
Standard : CUL Listed
Temperature Rating : 1832 DEG F
Type : Industrial 500,000 Count
Voltage Rating : 9 V
很抱歉,暂时无法提供与“DM-860A-C”相匹配的价格&库存,您可以联系我们找货
