DML-430A
DML-430A
    GREENLEECOMMUNICATIONS(格林利)
    DMM DLOG 43K TRMS AC/DC
DML-430A 数据手册
DMM,DLOG 43K,TRMS AC+DC(DML-430A) Digital Logging Meter (43,000data points) Cat No: DML-430A UPC No: 783310087465 Description • • • • • • • • • • • • Datalogging Capability - Stores 87,000 Single-Channel Or 43,000 Dual-Channel Measurements Use Optional USB InterfaceDMSC-9U To Transfer Data To PC Or For Direct-To-PC logging AC+DC True RMS Gives Accurate Readings On Complex Waveforms Low Impedance AutoCheck Mode - Automatically Selects AC or DC volts, Resistance Or Continuity Low impedance masks ghost voltage pickup Backlit LCD Displays 2 Readings With 10,000 Count Resolution BeepJack Warns When Test Leads Are Incorrectly Inserted In Current Measurement Terminals Measures Voltage, Current,Resistance, Conductance, Frequency And Capacitance Checks Continuity And Tests Diodes Two Temperature Measurements Using Type K Thermocouples Accessories Included: (1)9V Battery, Bead Temperature Probe (400 DEG F / 204 DEG C Max.), Test leads, Protective Boot, Carrying Case Lifetime Limited Warranty Specifications • • • • • • • • • • • • • • Amperage Measurement : 600, 6000 MICAMP, 60, 600 MILAMP, 6, 10 AMP Battery : (1) 9 V Capacitance : 60, 600 NFDN 6, 60, 600 MFD, 6, 25 MILFD Conductance : 99.99 nS Display : Backlit LCD Displays 2 Readings With 10,000 Count Resolution Frequency Measurement : 15 HZ - 50 KHZ Sine Wave, 5 HZ - 1 MHZ Logic Level Square Wave Includes : (1) 9V Battery, Bead Temperature Probe (400 DEG F/204 DEG CMax), Test leads, Protective Boot, Carrying Case Measurement Category : CAT IV, 1000 V Replacement Part : TC-20 Carrying Case, TSG-3 Sure-Grip Test Leads, TPB Bead Temperature Probe Resistance Measurement : 600 OHM, 6, 60, 600 KOHM, 6, 60 MOHM Standard : CAT IV, C/UL US Listed, TRUE RMS, CE Listed Temperature Rating : K Type, -58 To 1832 DEG F (-50 To 1000 DEG C) Type : Digital Voltage Measurement : 60.00, 600.0 MILV, 9.999, 99.99, 999.9 V
