DM-350-C
DM-350-C
    GREENLEECOMMUNICATIONS(格林利)
    DMM 1000V 10A RMS BL
DM-350-C 数据手册
DMM, 1000V 10A RMS BL (CALIBRATED) DMM, 1000V 10A RMS BL Cat No: DM-350-C UPC No: 783310228974 Description • • • • • • • • • • • • • • True RMS for no-compromise accuracy when harmonics are present Large LCD with backlight for easy viewing AC/DC voltage, AC/DC amperage measurement Non-contact voltage detection for identifying live lines without contacting conductors Auto shut-off for longer battery life plus low battery indicator Resistance measurement Audible continuity and diode tests Frequency measurement Capacitance measurement Data hold to capture measurement 6000-count LCD for high resolution Min/Max feature for addedversatility Audible input alert warnsuser if leads are in incorrect position Lifetime Limited Warranty Specifications • • • • • • • • • • • • • Amperage Measurement : ƕ 600, 2000 MICAMP ƕ 6, 10 AMP Amperage Rating : 10 AMP RMS BL Application : To Measure Voltage, Resistance And Continuity, For AC/DC Voltage, AC/DC amperage Measurement Capacitance : 600 NFD, 6, 60, 600, 2000 MFD Display : 6000-Count LCD Frequency Measurement : 40 HZ Minimum, 100 HZ - 60 KHZ Maximum Measurement Category : ƕ CAT IV, 600 V ƕ CAT III, 1000 V Replacement Part : TSG-3 Sure-Grip Test Leads, TC-40 Carrying Case Resistance Measurement : ƕ 600 OHM ƕ 6, 60, 600 KOHM ƕ 6, 60 MOHM Standard : CAT IV, C/US UL Listed, CAT III, CE Listed Type : TRMS Voltage Measurement : ƕ 600 MILV ƕ 6, 60, 600, 1000 V Voltage Rating : 1000 V RMS BL
DM-350-C 价格&库存
很抱歉,暂时无法提供与“DM-350-C”相匹配的价格&库存,您可以联系我们找货
