601B
601B
    B&K
    TRANSFORMER PULSE 492UH .8DCR
601B 数据手册
Data Sheet Handheld Battery Capacity Analyzers Models 600B and 601B The 600B and 601B Battery Capacity Analyzers address the need to test and maintain sealed lead acid (SLA) batteries used in backup power UPS, emergency lighting, fire alarms, security systems, and many other electrical systems. By quickly characterizing a battery’s response to a load resistance, these meters display the remaining battery capacity as an indicator of the battery’s health. Powered by the battery under test, both models support testing of 12 V storage type lead acid batteries. The 601B is also capable of testing 6 V batteries and displaying the internal resistance of the battery. Features ■ Measure remaining battery storage capacity in just seconds ■ Easy-to-use interface ■ Powered by the battery under test eliminating the need for external power to instrument ■ High quality, durable Kelvin clamps ■ Rubber buttons ■ Rugged housing with extruded aluminum case ■ Internal resistance measurement (601B only) Model 600B 601B Supported SLA battery voltages 12 V 6 V & 12 V Internal resistance -- √ Load voltage -- Technical data subject to change © B&K Precision Corp. 2015 √ www.bkprecision.com Handheld Battery Capacity Analyzers Models 600B and 601B Front panel Display Rubber keypad Reverse polarity LED Kelvin clamps Strain reliefs Specifications Model 600B 601B Supported SLA battery voltages 12 V 6 V & 12 V 5 - 100 in 1 Ah steps Ah range 7, 12, 24, 42, 65, & 100 No load (open circuit) voltage accuracy ±2 counts ±(0.2% + 1 count) Dimensions (W x H x D) 2.91” x 10.44” x 2.18” (74 x 265.1 x 54 mm) 2.91” x 10.44” x 2.28” (74 x 265.1 x 58 mm) Weight 2.65 lbs (1.2 kg.) Included accessories User manual One-Year Warranty 2 v092315 www.bkprecision.com
很抱歉,暂时无法提供与“601B”相匹配的价格&库存,您可以联系我们找货
