9070
9070
    TPI(TPI 公司)
    SMART VIBRATION METER
9070 数据手册
9070 Smart Vibration Meter Vibration analysis at the touch of a button Machinery Health Monitoring Tools from testproductsintl.com • 800.368.5719 BENEFITS • ISO Built-in Alarms Analyze and Interprets readings…Incredible performance at an unbelievably low price • Easily identify bearing problems with BDU Reading • Easily identify problems with built in band filters: 1X (unbalance) 2X (misalignment) 3X (looseness) • 800 line FFT (spectrum) • Ruggedized IP67 case • 3-year Limited Warranty Overall machine and bearing conditions: vibration values are displayed with color coded alarm levels for ISO values and Bearing Damage (BDU). FEATURES • Full Color OLED Display • Built-in accelerometer with stinger. Optional long stinger and magnetic mount available MARKETS • Commercial/Industrial HVAC • Food Processing • Manufacturing Easy vibration analysis: clear picture of machine problems detected with built in band filters: 1X (unbalance) 2X (misalignment) 3X (looseness) • Mining • Packaging • Petrochemical • Pulp and Paper • Power Plants • Utilities • Automotive 9070 data sheet 04.12 Photo Actual Size Identify complex issues: 800-line spectrum with zoom and cursor. Test the TPI Advantage Copyright © 2012 Test Products International, Inc. 9070 Smart Vibration Meter Machinery Health Monitoring Tools from testproductsintl.com • 800.368.5719 Stinger tip accelerometer with standard 1/4 x 28 threads. Various length stingers or magnets can be used Full color high contrast OLED display • Size: H 7.95” W 2.36” • Weight: 9.8oz (280g) • Environmental: o Water: IP67 Waterproof o Operating: 32°F to 122°F (0C to 50C) o Storage: -4°F to 158°F (-20C to 70C) • Power supply: 2xAA batteries • Battery life: Approximately 50 hours of normal use • Frequency ranges: 2/10Hz - 1kHz ISO 2Hz - 3kHz • Frequency resolution: 100 / 200 / 400 / 800 lines • Displayed amplitude units: Acceleration in g / velocity in inches per second or mm per second / Bearing damage in BDU • Displayed frequency units: Hz, CPM or RPM • Input range: +/- 50 g • Dynamic range: 72 dB • Auto set up of VA bands • Accelerometer connection: Internal sensor • Standard accessories o Pouch with protective cap for pointed stinger • Optional accessories: o Magnet Top button with circle: • Press to power ON • Press again to take a reading • Auto OFF one minute after last reading, unless time OFF is changed in power time OFF in user settings Left and right cursors: • Move curser in FFT mode • Select set up in Menu mode Menu Setup button: • Press and it cycles through main big number screen, VA screen (Unbalance, Misalignment and Looseness) • FFT, FFT zoom *2, FFT zoom *4, FFT zoom*8 and back to start. Press and hold Setup Menu to set: • ISO filter 2/10Hz • ISO alarm level • Units of measure: Metric/English • Run speed (Metric defaults to 1500 CPM/English 1800 CPM) • Frequency axis CPM (default) or Hz • Screen brightness • Power time OFF (programmable) Left and right buttons select options and Menus accepts change Photo Actual Size Copyright © 2012 Test Products International, Inc.
很抱歉,暂时无法提供与“9070”相匹配的价格&库存,您可以联系我们找货
