875B
875B
    B&K
    LCR METER
875B 数据手册
Data Sheet LCR Meter Model 875B The rugged 875B LCR meter is a reliable, easy-to-use workhorse that will measure inductors, resistors, and capacitors quickly and accurately. Utilizing special circuitry, the measurement more closely replicates true in-circuit measurements. The meter allows for resistance measurement down to 1 mΩ of resolution and zero adjustment for removing lead resistance. Specifications ■ Precision measurement of very low resistances ■ Measures D (dissipation factor) ■ Unique drop-proof construction ■ Tilt stand ■ Measures resistance using a test frequency that can cause an inductive reactance 875B Range Resolution 200 pF 0.1 pF 2 nF 1 pF 20 nF 10 pF 200 nF 100 pF 2 µF 1000 pF 20 µF 0.01 µF 200 µF 0.1 µF Capacitance 2 mF 1 µF 20 mF 10 µF 20 Ω 10 mΩ 2Ω 200 Ω 2 kΩ Resistance 20 kΩ 200 kΩ Inductance Features & Benefits Accuracy 1%+2 2%+10 1 mΩ 1%+5 100 mΩ 1Ω 1%+2 10 Ω 100 Ω 2 MΩ 1 kΩ 20 MΩ 10 kΩ 200 µH 0.1 µH 2 mH 1 µH 20 mH 10 µH 200 mH 100 µH 2H 1 mH 20 H 10 mH 200 H 100 mH 2%+2 2%+2 1%+2 Not specified, ranges are used for referance only General Power requirements 9 V 006P battery Display 0.5” digital height, 31/2 digits liquid crystal display with “LOBAT” and decimal annunciators Low battery warning Display will “LOBAT” in the last 5% of battery life Current consumption 17.3 mA Temperature 32° to 104° F (0° to 40° C) Operating / -4° to 158° F (-20° to 70° C) Storage Dimensions (LxWxH) 6.97” x 3.46” x 1.57” (177 x 88 x 40 mm) Weight 14 oz (400 grams) Included accessories Operation manual and one pair of test clips (red & black) Three-Year Warranty Technical data subject to change © B&K Precision Corp. 2015 v041715 www.bkprecision.com
很抱歉,暂时无法提供与“875B”相匹配的价格&库存,您可以联系我们找货
