575A
575A
    B&K
    ICTESTER/IDENTIFIERDIGITAL
575A 数据手册
Data Sheet Handheld IC Testers Models 570A and 575A Model 570A analog and model 575A digital IC testers are compact, handheld, battery powered testers offering advanced functionality and ease of use. The 2-line x 16 character dot matrix LCD shows the result of the test as a PASS or FAIL, together with individual pin diagnostics and test modes. Both units contain extensive built-in test libraries. The 570A analog IC tester’s built-in test library includes all common analog ICs including op-amps, comparators, voltage regulators, voltage references, analog switches and multiplexers, opto-isolators and opto-couplers, and audio ICs. The 575A digital IC tester’s built-in test library includes a broad range of TTL, CMOS, memory, LSI, interface and other IC devices of up to 40 pins. Model 570A Features Model 575A Features ■ Auto identification mode ■ Conditional/Unconditional loop testing mode ■ Functional test unit emulates passive circuitry ■ 40 pin capability (NAND gates or CPUs) to implement a comprehensive test in a variety ■ Identifies unmarked and house-coded devices of configurations and gain settings ■ ■ ■ Displays diagnostic information for individual ■ Built-in membrane keypad, 2 x 16 dot matrix Comprehensive device library covers most TTL, CMOS, memory, and interface devices Detects intermittent and temperature related faults component pins ■ Displays diagnostic information for individual pins alphanumeric LCD, and high quality 16-pin ■ Battery operated Model 575A ZIF socket ■ Battery operated Specifications Power Sources Power Consumption 570A 575A Batteries 4 x 1.5V AA DC Input 6V, 850 mA max. regulated Power Off 10 µA Standby 30 mA Test Thresholds Logic High: 2.2 V Min. Logic Low: 0.8 V Max. Variable (DAC controlled) Library ICs Operational Amplifiers, Comparators, Operational Amplifiers / Comparators, Voltage Regulators, Voltage References, Analog Switches / Multiplexers, Transistor Arrays, Optoisolators / Optocouplers, DACS / ADSC, Special Functions ICs, Virtual Grounds, Audio ICs Series 54/74 TTL ICs, CMOS ICs, Memory ICs, Interface, Peripheral, Microprocessor & LSI ICs (75000 series, ULN2000 series, DS8800 series, 8T series, 8200 series, 25/26/29 series, MC6800 series, MC3400 series, Z80 series, MC6500 series, Intel 8000 series, etc.) One Year Warranty Technical data subject to change © B&K Precision Corp. 2012 v09102012 www.bkprecision.com
很抱歉,暂时无法提供与“575A”相匹配的价格&库存,您可以联系我们找货
