Data Sheet
Modular Programmable DC Electronic Load
MDL Series
Features and Benefits
mode, which uses DSP technology to simulate
non-linear loads and realistic loading behavior.
The MDL Series is a multi-channel modular
programmable electronic load system. Seven
different modules of programmable DC loads
ranging in power from 200 W to 600 W
provide users the flexibility to test a wide range
of power sources from multi-output AC/DC
power supplies to batteries, fuel cells, and
photovoltaic arrays.
Easily edit the load’s parameters such as voltage,
current, slew rate, and width via the front panel.
Increase productivity by saving your test
parameters into any one of the 101 memory
areas for quick system recall. Additionally, the
MDL Series provides 16-bit resolution as well
as numerous protection modes and a power-on
system self-test to ensure the reliability of your
testing.
The mainframe has four slots that can be
configured with any assortment of the modules
up to 2400 W (up to 4800 W with mainframe
extension). The high-performance electronic load
modules of the MDL Series are capable of
operating in constant current (CC), constant
voltage (CV), constant resistance (CR), constant
power (CW), and constant impedance (CZ)
Modules
For remote communication, the MDL series
provides LAN, USBTMC compliant USB,
RS232, and GPIB standard interfaces that
support SCPI command protocol.
Power range up to 2400 W
Voltage range up to 500 V
Current range up to 120 A
CC/CV/CR/CW/CZ operating modes
Removable modules for easy system
configurability
200 W
*250 W/
50 W
300 W/
300 W
300 W
400 W
500 W
600 W
Operating Voltage
80 V
80 V
80 V
500 V
80 V
500 V
80 V
Rated Current
40 A
20 A
45 A
20 A
60 A
30 A
120 A
1
2
2
1
1
1
Operate identical modules in parallel mode
for high current applications
Synchronous Load on/off function
Standard LAN, GPIB, USB, and RS-232
interfaces with USBTMC/SCPI protocol support
Analog current control and monitoring
Transient mode up to 25 kHz
List mode (sequence mode) - minimum 20 µs
Adjustable slew rate in CC mode
16-bit voltage and current measurement
step width with 84 user programmable steps
system providing high resolution of 0.1 mV
and 0.01 mA
Automatic test function
101 memory locations to save/recall setting
parameters
* The MDL252 is a dual-channel 250 W load module supporting a
unique flexible power configuration. The user can allocate up to
250 W to either channel up to 300 W total (e.g. 50 W/250 W,
250 W/50 W, 150 W/150 W), thus replacing many dual-channel
modules with fixed power distribution.
Technical data subject to change
© B&K Precision Corp. 2021
1
Support for up to 16 channels using dual
channel modules with mainframe extension
MDL200 MDL252 MDL302 MDL305 MDL400 MDL505 MDL600
Power
No. of Channels
Remote sense
OVP/OCP/OPP/OTP and reverse voltage
protection
www.bkprecision.com
MDL Series
▲ Front panel
Bright VFD display
Module pane l keys
Adj ust me nt kno b
Main frame
functi on keys
Nume ric
ke ypad
Po wer
swi tch
M ai nframe
M odules
▲ Rear panel
GPIB i nte rface
Load input t ermi nals
RS- 232 in terface
L AN in terface
Module
curre nt
moni torin g
t ermin al
M ain frame
t rig ger I/O and
synchroni zati on
on /of f cont ro l
USB i nte rf ace
2
M ai nframe
exten sion
con necto r
Module re mo te s ense , digit al I/O, and analog current co ntrol terminal
www.bkprecision.com
MDL Series
The tools you need
Hi gh per formance architecture
Mod ular d esig n
Tr ansient operation
Equipped with a high-performance microprocessor
in every mainframe and module, the MDL Series
programmable DC electronic load utilizes a
parallel architecture that provides a high
measurement speed. Additionally, a simultaneous
load on/off operation can be performed through
the front panel, analog control terminal, or remote
SCPI command. This configuration allows the
system to control modules synchronously and
increases productivity in testing.
With removable module design, you can choose
suitable load modules to modify the system
according to your requirements. This design
allows for multiple channels and is ideal for
testing several units, especially power supplies
with multiple outputs. At the same time, all load
modules can be configured to work independently.
All load modules, including the high power 500
W and 600 W modules can fit in one slot. Unlike
competitor models that require two slots for high
power modules, the MDL Series offers a one-slot
form factor for all modules.
Transient operation enables the module to
periodically switch between two load levels.
A power supply’s regulation and transient
characteristic can be evaluated by monitoring
the supply’s output voltage under varying
combinations of load levels, duty cycle, and slew
rate. The MDL Series can simulate these
conditions up to 25 kHz.
A
High Level
Low Level
Powe rful communication interfaces
The MDL Series mainframe offers all the latest
options to the user for remote communication.
Connect via GPIB, Ethernet, USB, or RS232 to
carry out data communication through SCPI and
USBTMC standard communication protocols to
control all your electronic load modules from a
PC.
Adj ustable sl ew r ate
In constant current mode, users can control the
rate or slope of the change in current in a
transient response test. Set the slew rate to as
slow as 0.0001 A/µs or as fast as 2.5 A/µs
depending on the module and selected current
range.
Low Voltag e Operation
The MDL series can operate at low voltages for applications such as fuel cell and solar cell testing.
T
Slew Rate
List mode
Not limited to just switching between two levels,
list mode lets you generate more complex
sequences of input changes with several different
levels. Up to 7 groups of list files can be saved
in the mainframe. Each list can contain up to 84
steps with a minimum width time of 20 µs per
step.
A
T
Automatic test mode
The MDL Series can execute multiple test
sequences across all channels. Sequences can be
cascaded, and each step can be programmed
with upper and lower limit values. When applied
in automatic production testing, you can easily
judge whether the test parameters of your
devices are within the specification limits and
adjust your process according to the GO/NG
verdict.
Typical minimum operating voltage at full scale current:
3
MDL200
MDL252
MDL302
MDL305
MDL400
MDL505
MDL600
1V
1V
1.4 V
4.5 V
1.5 V
5.4 V
1.8 V
www.bkprecision.com
MDL Series
Specifications
Model
MDL200
MDL252
MDL302
MDL305
MDL400
MDL505
MDL600
0-80 V
0-80 V
0-80 V
0-500 V
0-80 V
0-500 V
0-80 V
Low
0-4 A
0-3 A
0-4.5 A
0-3 A
0-6 A
0-3 A
0-12 A
High
0-40 A
0-20 A
0-45 A
0-20 A
0-60 A
0-30 A
0-120 A
300 W / 300 W
300 W
400 W
500 W
600 W
Input ratings
Input Voltage
Input Current
Input Power
200 W
Channels
Minimum
Operating
Voltage
250 W / 50 W
1
1
2
2
1
1
1
1
Low
0.10 V at 4 A
0.15 V at 3 A
0.14 V at 4.5 A
0.7 V at 3 A
0.15 V at 6 A
0.54 V at 3 A
0.18 V at 12 A
High
1 V at 40 A
1 V at 20 A
1.4 V at 45 A
4.5 V at 20 A
1.5 V at 60 A
5.4 V at 30 A
1.8 V at 120 A
0-80 V
0-500 V
0-80 V
CV mode
Range
Resolution
Accuracy
Low
0-18 V
High
0-80 V
0-80 V
0-80 V
0-500 V
Low
1 mV
High
10 mV
Low
± (0.05 % + 0.02 % F.S.)
± (0.05 % + 0.025 % F.S.)
High
CC mode
Range
Resolution
Accuracy
Low
0-4 A
0-3 A
0-4.5 A
0-3 A
0-6 A
0-3 A
0-12 A
High
0-40 A
0-20 A
0-45 A
0-20 A
0-60 A
0-30 A
0-120 A
Low
0.1 mA
1 mA
0.1 mA
High
1 mA
10 mA
1 mA
Low
± (0.05 % + 0.05 % F.S.)
± (0.05 % + 0.1 % F.S.)
High
± (0.1 % + 0.1 % F.S.)
CR mode
Range
Low
0.05 Ω-10 Ω
0.05 Ω-10 Ω
0.05 Ω-10 Ω
0.25 Ω-10 Ω
10 Ω-7.5 kΩ
High
Resolution
Accuracy
0.05 Ω-10 Ω
0.2 Ω-10 Ω
0.2 Ω-10 Ω
400 W
500 W
600 W
16-bit
Low
0.01 % + 0.08 S
High
0.01 % + 0.0008 S
CW mode
Range
200 W
250 W
300 W
300 W
Resolution
10 mW
Accuracy
± (0.2 % + 0.2 % F.S.)
Transient mode (CC mode)
T1&T2 2
20 us-3600 s / Res: 5 µs-10 ms
Accuracy
Slew Rate 3
5 µs+100 ppm
Low
0.0001-0.25 A/µs
0.0001-0.2 A/µs
0.0001-0.25 A/µs
High
0.001-2.5 A/µs
0.001-2 A/µs
0.001-2.5 A/µs
0.0001-0.1 A/µs 0.0001-0.25 A/µs 0.0001-0.1 A/µs
0.001-1 A/µs
0.001-2.5 A/µs
0.001-1 A/µs
0.0001-0.25 A /µs
0.001-2.5 A/µs
1 ) MDL252: The user can allocate up to 250 W to either channel up to 300 W total (e.g. 50 W/250 W, 250 W/50 W, 150 W/150 W).
2 ) Fast pulse trains with large transitions may not be achievable.
3 ) The slew rate specifications are not warranted, but are descriptions of typical performance. The actual transition time is defined as the time for the input to change from 10% to 90%, or vice versa, of the
programmed current values. In case of very large load changes, e.g. from no load to full load, the actual transition time will be larger than the expected time. The load will automatically adjust the slew rate to fit
within the range (high or low) that is closest to the programmed value.
4
www.bkprecision.com
MDL Series
Specifications
Model
MDL200
MDL252
MDL302
MDL305
MDL400
MDL505
MDL600
Readback voltage
Range
Resolution
Low
0-18 V
High
0-80 V
0-80 V
0-80 V
0-500 V
0-80 V
0-500 V
0-80 V
Low
0.1 mV
0.1 mV
0.1 mV
1 mV
0.1 mV
1 mV
0.1 mV
High
1 mV
1 mV
1 mV
10 mV
1 mV
10 mV
1 mV
Accuracy
± (0.025 % + 0.025 % F.S.)
Readback current
Range
Resolution
Accuracy
Low
0-4 A
0-3 A
0-4.5 A
0-3 A
0-6 A
0-3 A
0-12 A
High
0-40 A
0-20 A
0-45 A
0-20 A
0-60 A
0-30 A
0-120 A
Low
0.01 mA
0.01 mA
0.01 mA
0.01 mA
0.1 mA
0.01 mA
0.1 mA
High
0.1 mA
0.1 mA
0.1 mA
0.1 mA
1 mA
0.1 mA
1 mA
Low
High
Readback power
Range
200 W
250 W
300 W
300 W
Resolution
10 mW
Accuracy
400 W
500 W
600 W
Protection range (typical)
OPP
OCP
200 W
250 W
Low
4.4 A
High
44 A
82 V
OVP
310 W
300 W
400 W
500 W
600 W
3.3 A
5A
3.3 A
6.6 A
3.3 A
13.2 A
22 A
50 A
22 A
66 A
33 A
132 A
82 V
82 V
510 V
82 V
510 V
82 V
OTP
185 ºF (85 ºC)
General (typical)
Short Circuit
Current (CC)
Low
4A
3A
5A
3A
6A
3A
12 A
High
40 A
30 A
50 A
20 A
60 A
30 A
120 A
Voltage (CV)
Resistance (CR)
Input Terminal Impedance
Safety
Electromagnetic Compatibility
Dimensions
Weight
0V
25 mΩ
50 mΩ
30 mΩ
220 mΩ
25 mΩ
180 mΩ
15 mΩ
300 kΩ
300 kΩ
300 kΩ
1 MΩ
300 kΩ
1 MΩ
300 kΩ
EN61010-1:2001, EU Low Voltage Directive 2006/95/EC
Meets EMC Directive 2004/108/EC, EN 61000-3-2:2006, EN 61000-3-3:1995+A1:2001+A2:2005
EN 61000-4-2/-3/-4/-5/-6/-11, EN 61326-1:2006
3.2” x 7.2” x 22.6” (82 x 183 x 573 mm)
11 lbs (5 kg)
Three-Year Warranty
5
www.bkprecision.com
MDL Series
Mainframe Specification
Number of
Slots
Power Input
Operating
Temperature
Storage
Temperature
Humidity
4
110/220 V ±10%, 50/60 Hz
32 to 104 ºF
(0 to 40 °C)
14 to 140 ºF
(-10 to 60 °C)
Indoor use, ≤95%
Note: Applies to MDL001 mainframe and MDL002 mainframe extension.
Mechanical Specifications
Model
Type
Dimensions (W x H x D)
Weight
MDL001
Mainframe
17.5” x 7.2” x 21.6”
(445 x 183 x 549 mm)
34 lbs (15.4 kg)
MDL002
Mainframe
Extension
34 lbs (15.4 kg)
MDL200
Module
3.2” x 7.2” x 22.6”
(82 x 183 x 573 mm)
11 lbs (5 kg)
MDL252
Module
3.2” x 7.2” x 22.6”
(82 x 183 x 573 mm)
11 lbs (5 kg)
MDL302
Module
3.2” x 7.2” x 22.6”
(82 x 183 x 573 mm)
11 lbs (5 kg)
MDL305
Module
3.2” x 7.2” x 22.6”
(82 x 183 x 573 mm)
11 lbs (5 kg)
MDL400
Module
3.2” x 7.2” x 22.6”
(82 x 183 x 573 mm)
11 lbs (5 kg)
MDL505
Module
3.2” x 7.2” x 22.6”
(82 x 183 x 573 mm)
11 lbs (5 kg)
MDL600
Module
3.2” x 7.2” x 22.6”
(82 x 183 x 573 mm)
11 lbs (5 kg)
Standard Accessories
Mainframes
Power cord, user manual, mainframe extension cable (MDL002 only)
Modules
Certificate of calibration
Optional Accessories
Rack mount kit RK153 for mainframes MDL001 and MDL002.
6
v110221
www.bkprecision.com
About B&K Precision
For more than 70 years, B&K Precision has provided reliable and value-priced test and
measurement instruments worldwide.
Our headquarters in Yorba Linda, California houses our administrative and executive functions
as well as sales and marketing, design, service, and repair. Our European customers are most
familiar with B&K through our French subsidiary, Sefram. Engineers in Asia know us through
our B+K Precision Taiwan operation. The independent service center in Singapore services
customers in Singapore, Malaysia, Vietnam, and Indonesia.
B&K Headquarters
Yorba Linda,
California, USA
Sefram
St. Etienne, France
B&K Taiwan
Taipei, Taiwan
Dynamics Circuit
Singapore
B&K Precision group member
Independent service center
Quality Management System
B&K Precision Corporation is an ISO9001
registered company employing traceable
quality management practices for all
processes including product development,
service, and calibration.
ISO9001:2015
Certification body NSF-ISR
Certificate number 6Z241-IS8
Service center location
Video Library
View product overviews, demonstrations,
and application videos in English, Spanish
and Portuguese.
http://www.youtube.com/user/BKPrecisionVideos
Product Applications
Browse all of our supported product
and mobile applications.
http://bkprecision.com/product-applications
