490B
490B
    B&K
    CRT RESTORER ANALYZER
490B 数据手册
490B Specifications model 490B CR-XA Universal CRT Adapter The 490B is intended for the checking and rejuvenating of the cathode ray tubes (CRT) for both color and black-and-white television sets and monitors. With this instrument you will be able to find and repair leakage or shorts by measuring the RGB current of cathodes. You will also be able to plot voltage/current features and to rejuvenate each cathode separately. ■ Test and restore color or monochrome CRTs ■ Test and restore most computer monitor CRTs ■ Test and restore most projection TV CRTs ■ Test emission, tracking, leakage, shorts, life ■ Remove shorts, clean and balance guns, rejuvenate cathodes ■ Continual set-up chart updates and new adapter development ■ Extra rugged carrying case Heater Selectable voltages 6.3V 1A max. 12V 0.5A max. Cut-Off adjustment G1 bias G2 bias Emission test Measurement range G1 bias Color tubes Rejuvenation Current Cycle duration Start cycle Color tubes Leakage and short circuit Indicators Removing Balance test Balance adjustment Life test Emission curve Measurement G1 bias Power supply Input voltage Power Consumption Mechanical features Dimensions WxHxD Weight -50V and -70V selectable +30V to +600V, variable 0 to 1600 uA Cut-off bias R, G or B simultaneous measuring 25 or 50 mA, selectable 70s approx. Manually R, G or B selection Neon Between G1-K and Fil-K For the three cathodes Approximate life period rating Of 1k current Variable from 0 up to-100V AC 110V 50-60 Hz 125V/220V/240V (internally selectable) 35W Rugged carrying case with 16 adapter storage. 17.7 x13.4 x5.7" (420x340x145 mm) 10.71 lbs. (4.9kg) Accessories One Year Warranty SUPPLIED: Instruction manual, Set-up chart, Spare fuse, 2 Adapter sockets for several CRT, Adapter cable, High voltage anode cable Adapter JEDEC base CA23 B10-276 CA24 B 8-274 CC-12* Conversion cable *(allow use of “CR” adapters, including the CR-XA Universal Adapter) OPTIONAL: CR-XA 76 Universal Adapter
490B
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该器件是意法半导体生产的高性能微控制器,具有多种通信接口和外设,适用于多种嵌入式应用。
3. 引脚分配:该芯片有48个引脚,包括电源引脚、地引脚、I/O引脚等,具体分配需参考芯片手册。
4. 参数特性:工作电压2.0V至3.6V,工作频率72MHz,内置64KB Flash和20KB RAM。
5. 功能详解:包括GPIO、ADC、定时器、通信接口(如UART、SPI、I2C)等模块的详细介绍。
6. 应用信息:适用于工业控制、消费电子、医疗设备等多种应用场景。
很抱歉,暂时无法提供与“490B”相匹配的价格&库存,您可以联系我们找货
