2640
2640
    B&K
    RF FIELD STRENGTH METER 2.0 GHZ
2640 数据手册
Data sheet 2.0 GHz Handheld RF Field Strength Meter Model 2640 Cost effective RF field strength meter with basic spectrum analyzer function The B&K Precision model 2640 is a battery operated, hand-held RF Field Strength Meter capable of measuring RF levels and electric field strength. The synthesizer-based design provides you with reliable measurements across a wide reception range of 100KHz to 2000MHz, a remarkably low noise floor of -110 dBm to detect weak signals and basic spectrum analyzer functionality. The 2640 provides field technicians and engineers with a cost-effective measurement tool for basic signal investigations at only a fraction of the cost of a full-featured conventional spectrum analyzer. The 2640’s user-friendly interface combined with convenient presets such as predefined filter settings and other special functions (e.g. squelch) commonly used in analog communication systems make the 2640 easy to use. The B&K Precision 2640 supports RS 232C serial communication and includes software that can control the instrument from a personal computer. The user can save the instrument’s measurement data on the PC for further analysis. The handheld RF Field Strength Analyzer is an ideal tool for field testing, installing and maintaining Mobile Telecommunications systems Technical data subject to change © B&K Precision Corp. 2008 v031610 such as Cellular and Cordless Phone, CB Paging, Paging, Cable and Satellite TV Systems as well as performing antenna site measurements and maintenance. Features ■ ■ Battery-operated portability 100KHz to 2GHz measurement range with a maximum display span of 400MHz ■ Hand-held and battery operated portability ■ Built-in 2GHz frequency counter ■ Detects wide band (180KHz) and narrow band FM (12.5KHz), AM & SSB (2.4KHz) signals ■ Phase-locked loop for precise frequency tuning ■ Up to 160 channels may be scanned and displayed ■ Audio output of the detected signal with built-in speaker ■ Detachable antenna included ■ Back-lit display ■ Storable setups and displays ■ RS-232 Interface w w w.bk prec ision.c om Tel.: 714.921.9095 Handheld RF Field Strength Meter Model 2640 Specifications model 2640 ▲ F re q uen c y Frequency Range Resolution Accuracy W-FM / N-FM / AM / SSB R F Fi el d S t r e n g t h A n a ly z er ■ Spectrum: Peak Search, Marker to Center, Channel Power Function ■ Internal Attenuation: The input range can be extended by enabling the internal 10 dB Attenuation function ■ Sweep Mode: Single Run, Free Run, Squelch Run Selectable Step Range ■ Squelch Function: The Squelch Level may be adjusted across the full dynamic range. Span Range Volume RF Input Type N Earphone Frequency Counter Frequency Selection Mode Am p lit ude Measurement Range Average noise Level Amplitude Units Reference Level Accuracy ▲ F req ue nc y C oun t e r The 2640’s built in frequency counter is independent from the field strength analyzer and measures the signal applied to the external BNC connector ■ Frequency range: 35 MHz to 2,000 MHz ■ No. of digits: 7 digits ■ Resolution: 1 kHz ▲ P C S of t w ar e The included AK2640 software and interface cable allows full control of the 2640 via a PC through the RS232C interface. The software allows the saving, recalling and analyzing of current and saved waveforms. The 2640 can save up to 100 waveforms and states in to it’s internal memory. Screenshot of the AK2640 software Reference Level Range Log Scale Internal Attn Internal Attn Accuracy Swe ep Speed Trigger Source Trigger Mode Trigger Level Marker Mode Me m ory Trace & Setup Storage Display Type Display Resolution LCD Light F re q uen c y C ou nt er Frequency Range Resolution Accuracy Sampling Time Input Sensitivity Input Impedance Max. Input Voltage Spec tr u m I npu t Por t RF Input Connector Max Input Level O p er at ion Env iro nm ent Operating Temperature Humidity Storage Temperature P ower S ou r ce Battery Power Source Battery Specification Adapter Auto Power On/Off P hy sic al Sp ec ific a tio ns Dimension Weight 100 kHz to 2,000 MHz Min. 6.25 kHz Multiples ± 4.5 PPM Wide FM : Approx. 180 kHz @-6 dB Narrow FM : Approx. 12.5KHz @-6 dB AM/SSB : Approx. 2.4 kHz @-6 dB AM, SSB, Narrow FM : 6.25 kHz, 12.5 kHz Wide FM : 6.25~125 kHz (Multiple of 6.25 kHz) 125~2500 kHz (Multiple of 125 kHz) AM, SSB, Narrow FM : 1 MHz, 2 MHz Wide FM : 1~20 MHz (Multiple of 1 MHz) 20~400 MHz (Multiple of 20 MHz) Center, Start/ Stop, Span -45 dBm to –110 dBm Wide FM : -100 dBm Max. Narrow FM : -110 dBm Max. AM/SSB : -100 dBm Max. dBm, dBmV, dBuV ±3.0 dB (Typical) @ 400 kHz to 600 kHz ±2.0 dB @ over 600 kHz 0 dBm to –80 dBm 0.2 dB/DIV min, in 0.25 dB Span (5 Display Division) 10 dB ±1.0 dB (@25) Min. 500 msec Narrow FM / Wide FM / AM / SSB Free Run /Single Run /Continuous /Wave Squelch Run TTL Level Marker / Delta Marker Max 100 Waveforms and 100 States Mono STN LCD 192 Pixels X 192 Pixels On / Off 35 MHz to 2,000 MHz 7 Digits ±50 PPM ±1 COUNT 1 sec 35 MHz to 2,000 MHz : 150 mVrms 20 MHz to 1,000 MHz : 100 mVrms 50 Ω 5 Vrms Max. N type Female, 50Ω Max. +10 dBm, 5V rms 0º C to 40º C 35% RH to 85% RHP 10º C to 50º C AA Type Ni-MH Rechargeable Battery × 6 PCS AA Type 1.2 V, 2,700 mAh Rechargeable Nickel Metal Hydride Battery SMPS Type AC Adapter (DC 12 V Output) Car-Adapter (DC 12 V Output) Off/ 5 min./ 10 min./ 20 min./30 min. 4 ”(W)×9 ”(H)×1.8 ”(D) Approx. 0.66 kg(1.45 lbs) (including Antenna, except Battery) One Year Warranty Accessories Screenshot of the exported CSV data 2 Supplied: Antenna (Receive Only), SMPS Type AC Adapter, Fuji-AA type NI-MH Rechargeable Battery (6 PCS, 1.2 V 2,700 mAh), Manual, Coaxial Cable, Earphone, Carrying Case, Carrying Belt, RS-232C Cable, Adapter(N-BNC), Software for PC Application w w w .b k p r ec is i o n .c o m
很抱歉,暂时无法提供与“2640”相匹配的价格&库存,您可以联系我们找货
