LOG-0001
LOG-0001
    MIDE(米德)
    VIBRATION DATA LOGGER
LOG-0001 数据手册
Shock Impact Vibration Data Logger FEATURES •• •• •• •• •• •• Free Analysis Software - click here for web page Simple and Easy to Use Small and Lightweight High Speed - 3.2 KHz Sampling Rate Rechargeable Characterizes Vibration Profile for Energy Harvesting Applications •• Dust Proof Enclosure •• Simple Analysis & Configuration Software APPLICATIONS •• •• •• •• •• •• DESCRIPTION Characterizing Energy Harvesting Vibrations Equipment Installation Verification Vibration Characterization for Damping Purposes Condition Based Maintenance Equipment Monitoring Bearing Monitoring PRODUCT DIMENSIONS 2.71 [68.834] 1.47 [37.338] Y Z 0.34 [8.636] X 0.91 [23.114] TOP VIEW 0.18 [4.572] SIDE VIEW * Dimensions in Inches [Millimeters] The Slam Stick™ is a high speed ultra portable rechargeable data logger capable of measuring acceleration in all three axes. The device uses a USB Port for on the fly configuring, charging and downloading of data. Simple configuration software allows users to tailor the device to their specific needs. The configuration options include an adjustable delay time before each measurement, different measurement durations, and a trigger based on a pre-determined acceleration level. Free analysis software allows for complete vibration characterization enabling the user to determine the frequency content of their given vibration. The Slam Stick™ can be used for many different applications including energy harvesting vibration characterization, modal surveys and equipment monitoring. Simply configure the device for your application, mount the device on your vibrating structure, hit the button and download the data to your computer. PN: LOG-0001 | REVISION No. 004 | DATE: 10-24-2014 | Web: www.mide.com | Email: service@mide.com 1 of 3 SPECIFICATIONS Accelerometer LOG-0001 Range ±16 g Sampling Rate: Maximum | Minimum Amplitude Response Within ±5% Accuracy (X, Y) 3.2 kHz | 100 Hz 0 to 300 Hz Amplitude Response Within ± 5% Accuracy (Z Axis) Transverse Sensitivity Natural Frequency Bandwidth Noise Density Resolution 0 to 500 Hz < 10% > 6000 Hz 0 to 1000 Hz 430µg/√Hz for Z Axis, 290µg/√Hz for X, Y Axis 13-bit (~3.9mg/LSB) Environmental Operating Temperature Accurate Temperature1 Storage Temperature Recharging Temperature Humidity Shock Limit -40°C to +80°C -20°C to +60°C -30°C to +40°C 0°C to +45°C 0 to 95 %RH >100 g Accelerometer Accuracy is within ±5% 25°C is Recommended to Preserve Battery Life Non-condensing 10,000g Raw Accelerometer Shock Rating Physical Mass Dimensions Case Material 16 grams 0.34” x 0.91” x 2.71” Polycarbonate/ABS See Product Dimensions for Axis Direction Miscellaneous Battery Life >15 Minutes @ 3.2 kHz Sampling >90 Minutes @ 100 Hz Sampling 2 years 16 MB (~ 8.4 million samples) Battery Lifetime Storage Capacity Battery needs to be charged at a minimum twice a year 15 Minutes recording @ 3.2 kHz, or 7 hours @ 100 Hz Analysis/Configuration Software Specifications Compatible Operating Systems Interface Maximum # of Data Samples Windows USB >500 Million Analysis of Data is Available during Import Software-Main Features Statistics FFT and spectrograms can be generated for every sensor channel. Absolute maximum, minimum, as well as sampling rate and range of each sensor channel is provided. Logger Configuration Export Data Configure the sampling frequency, calendar wake, time delay, recording duration, and g-level triggers. Ability to export all data in a CSV format for use with Excel, MATLAB, or other analysis software packages. FFT and Spectrogram can also be exported. The time range of exported data is user selectable. Part Number Product Description LOG-0001 ±16 g Acceleration, Data Logger. Included: Analysis Software. PN: LOG-0001 | REVISION No. 004 | DATE: 10-24-2014 | Web: www.mide.com | Email: service@mide.com 2 of 3 PREFORMANCE PLOTS Noise Distribution | Y Axis 30 25 25 Number of Occurrences (%) Number of Occurrences (%) Noise Distribution | X Axis 30 20 15 10 5 20 15 10 5 0 -0.06 -0.04 -0.02 0 0.02 0.04 0 -0.06 0.06 Deviation from Mean (G, one bin per LSB) -0.04 -0.02 0 0.02 0.04 0.06 Deviation from Mean (G, one bin per LSB) Noise Distribution | Z Axis Typical Frequency Roll Off 15 2.4 2 1.8 10 Amplitude (g) Number of Occurrences (%) 2.2 5 1.6 1.4 1.2 1 0.8 0.6 0 -0.1 -0.08 -0.06 -0.04 -0.02 0 0.02 0.04 0.06 0.08 1 Deviation from Mean (G, one bin per LSB) For the noise measurement, a sample Slam Stick recording was taken at room temperature with no vibrations present. The plots above represent the distribution of noise in the recorded data for each axis. This distribution is approximately Guassian, with the majority of samples falling very close to the correct value and less frequent outliers falling further from the correct value. This distribution is typical of random noise present in any measurement. 0.4 1 10 10 2 10 3 10 4 Frequency (Hz) Frequency roll off data was taken by exciting the Slam Stick at a constant amplitude (1 gee in this case) over a range of frequencies from 10 Hz to 3200 Hz. The measured vibration amplitude from the Slam Stick was then plotted versus frequency. Note that the roll off is severe after ~500 Hz in the Z axis. This roll off occurs at ~300 Hz in the X and Y axes. Different devices performed differently after this frequency and amplitude data should not be trusted when above this frequency. Frequency data is not impacted by this roll-off. PN: LOG-0001 | REVISION No. 004 | DATE: 10-24-2014 | Web: www.mide.com | Email: service@mide.com 3 of 3
LOG-0001 价格&库存
很抱歉,暂时无法提供与“LOG-0001”相匹配的价格&库存,您可以联系我们找货
