4065
4065
    B&K
    160MHZ DUAL WAVEFROM GEN
4065 数据手册
Data Sheet Dual Channel Function/Arbitrary Waveform Generators 4060 Series The 4060 Series Dual Channel Function/Arbitrary Waveform Generators are capable of generating stable and precise sine, square, triangle, pulse, and arbitrary waveforms. With an easy-to-read color display and intuitive user interface with numeric keypad, these instruments offer plenty of features including linear/logarithmic sweep, built-in counter, extensive modulation and triggering capabilities, a continuously variable DC offset, and a high performance 14-bit, 500 MSa/s arbitrary waveform generator. Easily create custom arbitrary waveforms using the included waveform editing software or use any of the 36 built-in predefined arbitrary waveforms. Up to 8 user-defined 512-kpt arbitrary waveforms and 24 user-defined 16-kpt arbitrary waveforms can be saved to the instrument. Additionally, the included LabVIEW™ drivers allow users to conveniently load and save .CSV or text file data directly into the arb memory without having to use waveform editing software. Extensive modulation capabilities include amplitude and frequency modulation (AM/FM), double sideband amplitude modulation (DSBAM), amplitude and frequency shift keying (ASK/FSK), phase modulation (PM), and pulse width modulation (PWM). The standard external 10 MHz reference clock input and output allows users to synchronize their instrument with another generator. This feature is typically not found in function generators at this price point. Additionally, the phase of both output channels can be synchronized conveniently with the push of a button. These versatile function/arbitrary waveform generators are suitable for education and other applications that require high signal fidelity, a variety of modulation schemes, or arbitrary waveform generation capabilities. Features & Benefits ■ 14-bit, 500 MSa/s, 512k point (Ch2 only) arbitrary waveform generator ■ Two independent channels with one-button synchronization ■ Generate sine waves up to 160 MHz ■ Large 4.3-inch LCD color display ■ Linear and logarithmic sweep ■ AM/DSB-AM/ASK/FM/FSK/PM/PWM modulation functions ■ Variable DC offset ■ Adjustable duty cycle ■ Internal/external triggering ■ Gate and burst mode ■ 36 built-in predefined arbitrary waveforms ■ Store/recall up to 10 instrument settings and 32 user-defined arbitrary waveforms (8 x 512 kpts, 24 x 16 kpts) ■ Built-in counter ■ USB device port (USBTMC-compliant) and front panel USB host port Model 4063 4064 4065 Sine frequency range 1 µHz – 80 MHz 1 µHz – 120 MHz 1 µHz – 160 MHz Square frequency range Technical data subject to change © B&K Precision Corp. 2015 1 µHz – 40 MHz 1 µHz – 50 MHz www.bkprecision.com ■ GPIB connectivity with optional USB-to-GPIB adapter ■ Arbitrary waveform editing software included ■ Short circuit output protection ■ LabVIEW™ drivers available Dual Channel Function/Arbitrary Waveform Generators 4060 Series Front panel USB host port 4.3” color LCD display Numeric keypad Rotary control knob Dedicated channel selection buttons Power button Menu function keys Waveforms, Utility and Parameter keys Modulation, Sweep, and Burst keys Channel outputs Intuitive user interface Easily adjust all waveform parameters using the intuitive menu-driven front panel keypad with dedicated channel selection keys, numeric keypad, and rotary control knob. Connect your USB flash drive to the USB host port to quickly save and recall instrument settings and waveforms. Rear panel Sync output External 10 MHz clock input BNC BNC Chassis ground Modulation input BNC External trigger/gate/FSK/Burst BNC connector 2 External 10 MHz clock output BNC USB interface www.bkprecision.com Dual Channel Function/Arbitrary Waveform Generators 4060 Series Flexible operation Dual channel output Wide variety of modulation schemes Generate waveforms with ease Save time with the 4060 Series’ two independent channels to output synchronous signals. With a push of a button, all waveform parameters can be quickly copied between channels to set up identical output signals. Phase between channels can also be adjusted from the front panel. These instruments are capable of many different types of modulation for various applications. Modulate your waveforms with AM, DSB-AM, FM, PM, ASK, FSK, and PWM modulation schemes. The provided waveform editing software can be used to create point-by-point arbitrary waveforms via freehand or waveform math functions. A standard USB interface on the rear panel allows users to easily interface with a PC to load these arbitrary waveforms into the instrument. The front panel also offers a convenient USB host port for connecting your USB flash drive to save/recall instrument settings and waveforms. Synchronization and external triggering Arbitrary waveform generation Easy-to-read color display All models in the 4060 series provide non-volatile memory to create, store, and recall up to 24 different 16-kpt arbitrary waveforms and up to 8 different 512-kpt arbitrary waveforms. Users can also output any of the 36 built-in predefined arbitrary waveforms. Use the external 10 MHz clock input and output to synchronize your signals to a master time base. The Sync output generates a TTL pulse for synchronization to a channel’s frequency. An external trigger BNC connector is also available for inputting or generating a trigger signal. Large 4.3” color display shows the currently selected channel and all relevant parameters. Advanced pulse generator 4060 Series adjustable rise/fall times 12 ns width pulse at 0.1 Hz frequency Typical DDS generator with limited rise/fall time ranges 86.06 ps cycle-to-cycle jitter For applications requiring high signal integrity and edge stability, the 4060 Series can generate pulses with a low cycle-to-cycle jitter of < 100 ps. 3 Capable of setting edge times within a large range, the 4060 Series can generate pulses with minimum rise/fall times of 6 ns and maximum rise/fall times of 6 seconds.. Unlike traditional DDS generators, the 4060 Series has the capability to output a rapid pulse at very low frequencies. Duty cycle can be set to as low as 0.0001%. www.bkprecision.com Dual Channel Function/Arbitrary Waveform Generators 4060 Series Specifications Model 4063 Channels 4064 4065 2 Frequency Characteristics Sine Square Triangle, Ramp Pulse Gaussian Noise (-3 dB) Arbitrary Accuracy Resolution 1 µHz – 80 MHz 1 µHz – 40 MHz 1 µHz – 20 MHz 1 µHz – 20 MHz 1 µHz – 120 MHz 1 µHz – 160 MHz 1 µHz – 50 MHz 1 µHz – 4 MHz 1 µHz – 30 MHz 100 MHz 1 µHz – 30 MHz ± 2 ppm (1 year) 1 µHz 1 µHz – 40 MHz 1 µHz – 40 MHz Arbitrary Characteristics Built-in Waveforms Waveform Length Vertical Resolution Sampling Rate Minimum Rise/Fall Time Jitter (pk-pk) Non-volatile Memory Storage Output Characteristics 36 Ch1: 16,000 points, Ch2: 512,000 or 16,000 points 14 bits 500 MSa/s 6 ns (typical) 2 ns (typical) 8 x 512 kpts waveforms and 24 x16 kpts waveforms Amplitude Range (into 50 Ω) 1 mVpp – 10 Vpp, ≤ 40 MHz 1 mVpp – 5 Vpp, ≤ 100 MHz 1 mVpp – 1.5 Vpp, ≤ 160 MHz Amplitude Resolution Amplitude Accuracy (100 kHz) up to 4 digits ± (0.3 dBm + 1 mVpp) Amplitude Flatness (relative to 100 kHz Sine, 1 Vpp) Cross Talk ≤ 10 MHz ± 0.2 dB ≤ 80 MHz ± 0.5 dB ≤ 160 MHz ± 0.8 dB < -65 dBc Offset Range (DC) ± 5 V into 50 Ω ± 10 V into open circuit Offset Resolution Offset Accuracy Output Impedance Output Protection up to 4 digits ± ( |offset setting value| x 1% + 1 mV) 50 Ω, high impedance short-circuit protection Waveform Characteristics Harmonic Distortion (Sine) Total Harmonic Distortion (Sine) Spurious (non-harmonic) Phase Noise Rise/Fall Time (Square) Variable Duty Cycle (Square) Asymmetry (50% duty cycle) Jitter (Square) Ramp Symmetry Linearity (Triangle, Ramp at 1 kHz, 1 Vpp, 100% Symmetry) 4 DC – 1 MHz, < -54 dBc 1 MHz – 10 MHz, < -46 dBc 10 MHz – 100 MHz, < - 35 dBc 100 MHz – 160 MHz, < -26 dBc DC – 20 kHz at 1 Vpp, < 0.2 % DC – 1 MHz, < -70 dBc 1 MHz – 10 MHz, < -65 dBc 100 kHz offset, - 116 dBc/Hz (typical) < 8 ns (10 % - 90 %) at full amplitude into 50 Ω 20% - 80% to 10 MHz 40% - 60% to 40 MHz 50% > 50 MHz 1% of period + 5 ns (typical,1 kHz, 1 Vpp) 100 ps rms (typical) 0% - 100% < 0.1% of peak output (typical) www.bkprecision.com Dual Channel Function/Arbitrary Waveform Generators 4060 Series Model 4063, 4064 & 4065 Pulse Pulse Width Rise/Fall Time Duty Cycle Range Overshoot Jitter (pk-pk) 12 ns minimum, 100 ps resolution, 1,000,000 s max 6ns – 6s(1), 100 ps resolution 0.0001 % to 99.9999 % < 3% < 100 ps rms (typical) Sweep Characteristics Waveforms Sweep Shape Sweep Time Sweep Trigger sine, square, ramp, arbitrary (except DC) linear or logarithmic, up or down 1 ms – 500 s ± 0.1% internal, external, manual Inputs and Outputs 50 Ω, high impedance TTL compatible > 50 ns width, not adjustable 50 Ω (typical) output impedance 10 MHz max. frequency ± 5 V for 100% modulation > 10 kΩ input impedance max. voltage input: + 5 V Frequency Range: 10 MHz ±1 kHz Min. Voltage Input: 2.3 V Output Impedance Burst Waveform Type Start/Stop Phase Internal Period Gated Source Trigger Source sine, square, ramp, pulse, arbitrary (except DC) cycle (1 – 1,000,000 cycles), infinite, gated 0 ° – 360 ° 1 µs – 1000 s ± 1% external trigger internal, external, manual Sync Out Modulation In External Clock In Phase Offset Range Resolution -360 ° – 360 ° 0.1 ° Trigger Characteristics Trigger Input Input Level Slope Pulse Width Input Impedance Maximum Frequency Input Latency Trigger Output Voltage Level Pulse Width Output Impedance Maximum Frequency TTL compatible rising or falling, selectable > 50 ns > 5 kΩ, DC coupling 1 MHz < 380 ns TTL compatible > 60 ns (typical) 50 Ω (typical) 1 MHz AM, FM & PM Modulation Characteristics Carrier Source Modulation Waveform AM Modulation Depth FM Frequency Deviation PM Phase Deviation sine, square, ramp, arbitrary (except DC) internal, external sine, square, ramp, noise, arbitrary (1 mHz – 50 kHz) 0% - 120%, 0.1% resolution 0 – 0.5 x bandwidth, 1 mHz resolution 0 – 360 °, 0.1 ° resolution ASK & FSK Modulation Characteristics Carrier Source Modulation Waveform sine, square, ramp, arbitrary (except DC) internal, external 50% duty cycle square waveform (1 mHz – 1 MHz) DSB-AM Modulation Characteristics Carrier Source Modulation Waveform sine, square, ramp, arbitrary (except DC) internal, external sine, square, ramp, noise, arbitrary (1 mHz – 50 kHz) PWM Modulation Characteristics Source Modulation Waveform External Modulation Duty Cycle Modulating Frequency (1) depending on pulse width internal, external sine, square, ramp, arbitrary (except DC) - 5 V to + 5 V (max. width deviation) 1 mHz – 50 kHz External Clock Out Frequency: 10 MHz Voltage Level: >1 Vpp Ext Trig/Gate/FSK/Burst TTL compatible max. voltage input: + 5 V Frequency Counter Measurement frequency, period, positive/negative pulse width, duty cycle Measurement Range 100 mHz – 200 MHz Frequency Resolution Voltage Range (non-modulated signal) 6 bits DC offset range: ± 1.5 VDC 100 mHz – 100 MHz, 50 mVrms - ± 2.5 V 100 MHz – 200 MHz, 100 mVrms - ± 2.5 V 1 Hz – 200 MHz, 100 mVrms – 5 Vpp DC Coupling AC Coupling Pulse Width/Duty Cycle Voltage Range Input Impedance Coupling Trigger Level Range 50 mVrms – 5 Vpp 1 MΩ AC, DC -3 V to +1.8 V Environmental and Safety Temperature operating: 32 ºF – 104 ºF (0 °C – 40 °C) storage: -4 ºF – 140 ºF (-20 °C – 60 °C) Humidity < 95º F (< 35 °C), ≤ 90 % RH 95 ºF – 104 ºF (35 °C – 40 °C), ≤ 60 % RH Altitude operating: below 9,842 ft (3,000 m) storage: below 49,212 ft (15,000 m) Electromagnetic Compatibility EMC Directive 2004/108/EC, EN61326:2006, EN61000-3-2:2006+A2:2009, EN61000-3-3:2008 Safety low voltage directive 2006/95/EC, EN61010-1:2001, EN61010-031:2002+A1:2008 General Display Interfaces Storage Memory AC Input 4.3” TFT-LCD display, 480 x 272 USBTMC (standard), GPIB (optional), USB host port 10 instrument settings, 32 arbitrary waveforms 100 – 240 VAC ± 10%, 50 / 60 Hz ± 5% 100 – 120 VAC ± 10%, 45 – 440 Hz Power Consumption 30 W max. Dimensions (W x H x D) Weight 10.3” x 4.1” x 13.5” (261 x 105 x 344 mm) 6.1 lbs (2.8 kg) Three-Year Warranty Standard Accessories Optional Accessories 5 v050515 Getting started manual, full instruction manual on CD, AC power cord, USB type A-to-type B cable, certificate of calibration USB-to-GPIB adapter (model AK40G) www.bkprecision.com
很抱歉,暂时无法提供与“4065”相匹配的价格&库存,您可以联系我们找货
