3003
3003
    B&K
    MODULE_5.5X2.1MM
    信号发生器 10MHz 5.50 x 2.10mm
3003 数据手册
Data Sheet 10 MHz Sine/Square Wave Generator Model 3003 The model 3003 signal generator is a cost-effective signal source that delivers clean and accurate DC to 10 MHz waveforms with frequency accuracy of 0.02% and 0.1Hz frequency resolution. Eight push wheel switches enable the user to quickly and easily set the frequency. Specifications 3003 Frequency Characteristics Waveforms Sine, Square Range DC to 9.9999999 MHz, 0.1 Hz steps Accuracy 0.02% (under 100 Hz accuracy is not specified) Sine Wave Output 0 – 4.5 Vp-p (no load) Variable amplitude control Output impedance 50 Ω Square Wave Output 5 Vp-p (no load) Duty Cycle 50% typical Output impedance 50 Ω General Power An external AC adapter (6 V - 9 V DC, 150 mA) or one 9 V battery Dimensions 2.1" x 3.6" x 6" (53.3 x 91.4 x 152.4 mm) Weight 1 lb (0.45 kg) Included Accessories User manual and power adapter One-Year Warranty Technical data subject to change © B&K Precision Corp. 2013 v050913 www.bkprecision.com
很抱歉,暂时无法提供与“3003”相匹配的价格&库存,您可以联系我们找货
