4013DDS
4013DDS
    B&K
    FUNCTION GENERATOR 12MHZ SWEEP
4013DDS 数据手册
Data Sheet DDS Sweep Function Generators Models 4007DDS & 4013DDS Models 4007DDS & 4013DDS are a versatile sweep function generators utilizing an advanced direct digital synthesis (DDS) design. These units generates superb quality waveforms with high signal precision and stability. It provides sine & square wave outputs over the frequency range from 0.2 Hz to 7 MHz (4007DDS) & 0.2 Hz to 12 MHz (4013DDS) in one extended range (triangle/ramped wave outputs to 100KHz for 4007DDS) & (triangle/ramped wave outputs to 1MHz for model 4013DDS). ■ 7MHz, 12MHz Frequency Ranges (sine & square only) ■ Sine, Square, Triangle ■ Lin or Log Sweep Function ■ Adjustable Duty Cycle ■ Adjustable DC Offset Model 4007DDS 4013DDS Frequency Range (sine & square wave only) 0.2 Hz to 7 MHz 0.2 Hz to 12 MHz Waveforms Sine, Square, Triangle, Ramp, Pulse Amplitude 10V p-p into 50Ω Offset ± 4.5V into 50 Ω (amplitude dependent) Distortion DC-20KHz = -55dBc (
4013DDS 价格&库存
很抱歉,暂时无法提供与“4013DDS”相匹配的价格&库存,您可以联系我们找货
