Data Sheet
50 MHz Programmable Pulse Generators
Models 4033 & 4034
Description
Features & Benefits
The 4033 and 4034 are high performance programmable pulse generators for testing digital
systems and circuits based on TTL, CMOS, or
ECL te chnologie s. Both instruments generate
clean and accurate pulses at up to 6 digits resolution with a repetition rate up to 50 MHz, variable pulse widths from 10 ns to 10 s, and pulse
delays from 0 ns to 10 s. Output levels are
adjustable from -10 V to +10 V, with pulse
amplitudes settable from 0.1 Vpp to 10 Vpp into
a 50 ohm load. All parameters, modes, and
functions are programmable via the front panel
or remote control commands. Additionally, the
pulse generators provide selectable complementary pulse and double pulse generation in continuous, triggered, gated, and counted burst
modes.
Repetition rate of 0.1 Hz to 50 MHz
Flexible trigger modes: Continuous, Triggered
parameters such as pulse width and transition
(internal, external, manual), Gated Burst and
time can be set independently
Technical data subject to change
© B&K Precision Corp. 2019
External Width
Pulse width programmable from 10 ns to 10 s
Transition times (rise and fall times) variable
Dual-Channel Model 4034
Both channels offer full functionality and all
Synchronize both channels with the push of a
button
Saves cost and bench space
from 6 ns to 100 ms
Programmable delay and double pulse
Predefined amplitude levels for ECL, TTL, and
Applications
CMOS signals
Automatic Test Equipment (ATE)
Store up to 99 different test setups with auto
Avionics and radar testing
retention of last power down setup
Switching power supply testing
10 Vpp into 50 ohm output
Characterization of active components
Closed case calibration
Programmable via GPIB and RS-232
SCPI compatible
Three year warranty
w w w.bk prec ision.c om
Models 4033 & 4034
Industry Leading Performance
External Width
Variable Transitions
Straightforward User Interface
In the external width pulse mode, pulse period
and width are determined by an externally
applied signal. The pulse generator then applies
transition and level parameters to this signal in
order to generate the pulse. A power supply
designer for example could use this feature to
shape the width and period of the output signal
to drive the power supply’s FET transistors while
remaining synchronized with its control circuits.
For added flexibility, variable rise and fall times
can be programmed from 6 ns to 100 ms.
Various shapes of pulses can be obtained for
applications where parameters such as linearity,
switching times, or reflection times must be analyzed. Programmable rise and fall times could be
used to measure operational amplifier slew rates
and easily test thresholds of devices and circuits.
These generators use a menu-driven front panel
keypad and control knob to adjust all parameters.
The bright, easy-to-read display shows all relevant parameters along with a graphical representation of the output pulse. If an entered parameter is not compatible with the existing setup status, the operator is informed by an error message.
Users can conveniently select predefined amplitude levels for TTL, ECL, and CMOS signals, or
choose a custom amplitude level for specialized
applications.
Front Panel Interface
Menu Keys – Selects menu
options for waveform parameters
F1-F5 Key – Select menu options
that appear on the bottom section
of the LCD display
Output On Button – Turns the
main output signal on or off
Manual Trigger Key – Sends
manual trigger pulse when
pushed (requires instrument
to be in manual trigger
mode)
4033 Output Section –
Main output and Sync
output
2
w w w .b k p r ec is i o n .c o m
Models 4033 & 4034
Specifications
The specifications describe the instrument performance after 30 minutes warm-up period into a 50 Ω load. All timing characteristics are measured at 50% of
amplitude with fastest edges.
Mode ls
4033
4 03 4
CHANNELS
1
2
FREQUENCY
T RANS IT IO N T IME S
0.1 Hz to 50 MHz
T I M I NG C H A R A C T E R I S T I C S
Range (single pulse)
20 ns to 10 s (50 MHz to 0.1 Hz repetition rate)
Range (double
pulse)
40 ns to 10 s (25 MHz to 0.1 Hz repetition rate)
Resolution
Up to 6 digits, limited to 100 ps
PERIOD
Accuracy
2 V into 50 Ω and with 3.5
ns typical transition times.
Low Level Range
-10 V to +9.90 V into 50 Ω load
(-20 V to +19.80 V into open circuit)
Amplitude Range
0.1 V to 10 V p-p into 50 Ω load
(20 V p-p max into open circuit)
Resolution
3 digits limited to 10 mV
Interface
GPIB and RS-232, IEEE-488.2 and SCPI compatible
Accuracy
±1% of setting ±10 mV into 50 Ω
GPIB Function Codes
SH1, AH1, T6, L4, SR1, RL1, PP0, DC1,DT1, C0, E2
Aberrations
很抱歉,暂时无法提供与“4034”相匹配的价格&库存,您可以联系我们找货
