4040DDS
4040DDS
    B&K
    DDS SWEEP FUNCTION GEN 20MHZ
4040DDS 数据手册
Data Sheet 20MHz DDS Sweep Function Generator Model 4040DDS Model FREQUENCY CHA RACTERISTICS Sine Square Triangle , Ramp Accuracy Resolution OUTPUT CHAR ACTE RISTI CS Amplitude Range Resolution Amplitude Accuracy Flatness (for sine wave at 4040DDS (STANDA RD WAVEFORMS) 0.1Hz to 20MHz 0.1Hz to 20MHz 0.1Hz to 2MHz 0.01 % (100 ppm) 4 digits or 10mHz 10mV to 10Vp-p into 50Ω 3 digits (1000 counts) ± 2% ± 20mV of the programmed output from 1.01V- 10V 0.5 dB at 1MHz, 1 dB to 20 MHz 5 Vp-p into 50 Ω) Offset Range Offset Resolution Offset Accuracy Output Impedance Output Protection The model 4040DDS is a low cost, full featured Direct Digital Synthesis (DDS) generator with a menu-driven front panel interface that includes a large, easy-to-read graphical LCD display. Waveform parameter changes and data entry can be made using the front panel rotary knob. The unit generates superb quality waveforms with high signal precision and stability. It provides sine & square wave outputs over the frequency range from 0.1 Hz to 20 MHz in one extended range (triangle/ramped wave outputs to 2 MHz). A full range of triggering capabilities is available, including internal-external trigger source and gated modes of operation. ■ 20MHz Frequency Range (sine & square only) ■ Sine, Square & Triangle ■ Modulation in both AM & FM ■ Lin or Log Sweep Function ■ Adjustable Duty Cycle ■ Adjustable DC Offset ■ Bright Informative LCD ± 4.5V into 50Ω, depending on the Amplitude setting 10 mV with 3 digits resolution ± 2% ± 10mV into 50Ω 50Ω The instrument output is protected against short circuit or accidental voltage practically available in electronic laboratories, applied to the main output connector WAVEFORM CHA RACTERISTICS Harmonic Distortion (for sine 0-20KHz, -50 dBc, 20KHz-100KHz, -45dBc wave at 5 Vp-p into 50 Ω) 100KHz-1MHz, -40 dBc, 1MHz-20MHz, -30 dBc Spurious DC-1MHz,
4040DDS 价格&库存
很抱歉,暂时无法提供与“4040DDS”相匹配的价格&库存,您可以联系我们找货
