4084
4084
    B&K
    FUNCTION GENERATOR 20MHZ PRG DDS
4084 数据手册
Data Sheet Programmable DDS Function Generator Series Models 4084, 4085, 4086 & 4087 Versatile modulation and trigger capabilities The generators provide extensive modulation capabilities including AM, FM, FSK, PSK, pulse modulation and linear/logarithmic sweep. Internal and external modulation sources, as well as internal, external and gated trigger sources are supported. Modulation parameters can be set precisely and are adjustable over a wide range. For instance burst count is programmable in 1 burst increments up to 10000 bursts and burst phase is adjustable in 0.1º increments. B&K Precision® models 4084, 4085, 4086 and 4087 are high performance laboratory grade synthesized function generators with a wide frequency range of up to 120 MHz. Direct digital synthesis (DDS) techniques are used to create stable, accurate output signals for all 27 built-in standard and complex (arbitrary) waveforms. The generators produce high purity, low distortion sine waves, square waves up to 40 MHz and provide a stable output of very small signals down to the 1mV - 10mV range. The instrument also provides a built-in 100 MHz universal counter with frequency measurement and totalize function. The versatility and capabilities of this series make it an ideal tool for many general-purpose test and bench applications or for use in training and education. Fig.1 Single cycle burst, start phase=0º Technical data subject to change © B&K Precision Corp. 2012 w w w.bk prec ision.c om Convenient user interface and operation You can adjust parameters via knob or numeric keypad. Enter amplitude values directly in Vpp, mVpp, Vrms, mVrms or dBm and display the correct voltage by entering the actual output configuration used (terminated with 50 Ohm or open circuit). You can enter frequency in terms of frequency or seconds using time values s, ms, Hz, kHz or MHz. Submenus are used for modulation modes and other complex functions. The generators are fully programmable via the standard RS232 interface, using SCPI commands. The instrument also provides 10 memories to store and recall instrument settings. Additionally the current state is saved at power off and can be restored at power up. Programmable DDS Function Generator Series Models 4084, 4085, 4086 & 4087 Specifications Models 4084 4085 4086 4087 Frequ ency Characte ristics 1µHz ~ 20MHz 1µHz ~ 40MHz 1µHz ~ 80MHz 1µHz ~120MHz Sine 1µHz ~ 20MHz 1µHz ~ 40MHz 1µHz ~ 40MHz 1µHz ~40MHz Square 1µHz ~ 100kHz All Other waveforms Frequency Stability ±1x10-6 (22°C ±5°C) Resolution 1µHz Accuracy ≤ ± 5x10-6 (22°C ±5°C) s, ms, Hz, kHz, MHz Data entry Units Wave for m Characteris tics Main Waveforms (Sine, Square) Amplitude resolution 12 bits Sample Rate 200MSa/s 300MSa/s Sine Harmonic Distortion ≤ - 50dBc (frequency ≤ 5MHz) ≤ - 45dBc (frequency ≤ 10MHz) of Sine Wave* ≤ - 40dBc (frequency ≤ 20MHz) ≤ - 35dBc (frequency ≤ 40MHz) ≤ - 30dBc (frequency > 40MHz) THD * 0.1% (20Hz ~ 100kHz) Square Rise and fall time* ≤ 15ns * = Note: Test conditions for harmonic distortion, sine distortion, rise/fall time Output Amplitude 2Vp-p, Environmental temperature: 25°C±5°C Others built-in waveforms 27 build-in standard and Sine, Square, Triangle, Positive Ramp, Falling Ramp, complex waveforms Noise, Pulse, Positive Pulse, Negative Pulse, Positive DC, Negative DC, Stair wave, Coded Pulse, Full wave rectified, Half-wave rectified, Sine transverse cut, Sine vertical cut, Sine phase modulation, Logarithmic, Exponential, Half-round, Sinx/x, Square root, Tangent, Cardiac, Earthquake, Combination Waveform Length 4096 dots Amplitude Resolution 10 bits Pulse Duty Cycle 0.1% ~ 99.9% (below 10kHz), 1% ~ 99% (10kHz ~ 100kHz) Rise/Fall Time ≤ 100ns (Duty Cycle 20%) DC signal characteristics DC range ≤ 10mV – 10V (high impedance) DC Accuracy ≤ ±5% of setting +10mV (high impedance) Arbitrary Non volatile memory 8 waveforms Waveform length 8~16000 points Amplitude resolution 10 bits Frequency range 1µHz~100kHz Sample rate 200MSa/s A mplitu de Characteristics Amplitude Range For all models Freq ≤ 40MHz: 2mV ~ 20Vpp (open circuit) , 1mV ~ 10Vpp (50Ω) 4084, 4085, 4086 Freq > 40MHz: 2mV ~ 4Vp-p (open circuit), 1mV ~ 2Vpp (50Ω) 4087 Freq > 40MHz: 0.1mV ~ 3Vpp (50Ω) Resolution 2µVpp (open circuit), 1µVpp (50Ω) Accuracy ± 1%+0.2mV (sine wave relative to 1kHz) Stability ±0.5 % /3 hours Flatness For amplitude ≤ 2Vpp ±3% (freq≤ 5MHz), ±10% (5MHz2Vpp: ±5% (freq≤ 5MHz), ±10% (5MHz20MHz) ±1dBm (frequency>40MHz) Output Impedance 50Ω Output Units Vpp, mVpp, Vrms, mVrms, dBm DC Offset Characteristics Offset Range (open circuit) Freq ≤ 40MHz: ±10Vpk ac+dc (Offset ≤ 2 x pk - pk amplitude) Freq > 40MHz: ±2Vpk ac+dc (Offset ≤ 2 x pk - pk amplitude) Offset Resolution 2µV (open circuit), 1µV (50Ω) Offset Error ±5% of setting +10mV (Ampl. ≤ 2Vpp into open circuit) ±5% of setting +20mV (Ampl. > 2Vpp into open circuit) Modu lation AM Characteristics Carrier Waveforms Modulation Source Internal Modulating Waveform Frequency of modulating signal Distortion Modulation Depth Sine or Square Internal or external Sine, Square, Triangle, Rising/Falling Ramp 100µHz ~ 20kHz ≤ 2% 1% ~ 120%, 1% ~ 80% (frequency>40MHz, Ampl > 2Vpp into open circuit) ± 5%+0.2% (100µHz < frequency ≤ 10kHz) Modulation Error ±10%+2% (10kHz < frequency ≤ 20kHz) Max. Amplitude of ext. input signal 3Vp-p (-1.5V~ +1.5V) FM Characteristics Carrier Waveforms Sine or Square Modulation Source Internal or external Sine, Square, Triangle, Rising/Falling Ramp Internal Modulating Waveform 100µHz ~ 10kHz Frequency of modulating signal Max. 50% of carrier frequency for internal FM Deviation Max 100kHz (carrier frequency≥ 5MHz) for external FM, with input signal voltage 3Vp-p (-1.5V~+1.5V) FSK Characteristics Carrier Waveform Sine or Square Internal or external trigger (external: TTL level, Control ModeI low level F1, high level F2) FSK Rate 0.1ms ~ 800s PSK Characteristics Sine or Square Carrier Waveform Phase1 (P1) and Phase 2 (P2), range: 0.0 ~ 360.0° PSK 0.1° Resolution PSK rate 0.1ms ~ 800s Control Mode Internal or external trigger (external: TTL level, low level P1, high level P2) Burst Characteristics Waveform Sine or Square Burst Counts 1 ~ 10000 cycles Time interval between bursts 0.1ms ~ 800s Control Mode Internal, single or external gated trigger Frequency Sweep Characteristics Waveform Sine or Square Sweep Time 1ms ~ 800s (linear), 100ms ~ 800s (log) Sweep Mode Linear or Logarithmic Start/ Stop Frequency Same as frequency range of Sine & Square External trigger signal frequency DC ~ 1kHz (linear) DC~10Hz (log) Control Mode Internal or external trigger I npu ts/ Outputs Main Output Impedance 50Ω Protection Short circuit and overload protected Output MOD OUT Frequency 100Hz ~ 20kHz Waveform Sine, Square, Triangle, Rising/Falling Ramp Amplitude 5Vp-p ± 5% Output Impedance 600Ω Modulation IN 3Vpp = 100% Modulation External Input Trig/FSK/Burst Level - TTL Univ ersal Cou nter, Ke y Specs* Frequency Range Frequency Measurement 1Hz ~ 100MHz Totalize mode 50MHz max * For full specification of the counter section, refer to online manual at www.bkprecision.com Ge neral AC Input 198~242V or 99~121V, Frequency: 47~ 63Hz Power Consumption
很抱歉,暂时无法提供与“4084”相匹配的价格&库存,您可以联系我们找货
