4084AWG
4084AWG
    B&K
    20MHz Arbitrary, Sweep Function Generator, DDS 1 Channel Sine, Square, Triangle, Ramp, Pulse Display...
4084AWG 数据手册
Data Sheet Arbitrary/Function Generators Models 4084AWG & 4086AWG The B&K Precision® 4084AWG and 4086AWG are high performance laboratory grade synthesized function generators with arbitrary capability. Direct digital synthesis (DDS) techniques are used to create stable, accurate output signals for all 27 built-in standard and complex (arbitrary) waveforms. The generators produce high purity, low distortion sine waves up to 80 MHz, square waves up to 40 MHz and a stable output of very small signals down to the 1mV - 10mV range. The instrument also provides a built-in 100 MHz Universal Counter with frequency measurement and totalize function. Unmatched affordability and excellent performance make models 4084AWG & 4086AWG a perfect fit for many applications in Electronic Test and Design, Sensor Simulation and Education and Training. Custom waveform generation made easy In addition to the built-in complex waveforms, you can use the 4084AWG & 4086AWG to generate custom arbitrary waveforms with 10 bit vertical resolution, 16k memory depth and a sample rate of 200MSa/s. Increase your productivity with the included intuitive Windows Software: Generate and edit waveforms and download them to the instrument with a single click. Waveforms can be generated in many ways: Draw waveforms freehand, import them from a text file or start out with standard functions and customize them with the provided math functions (Fig. 1). Additionally, the software provides a direct interface to Tektronix® TDS1000, TDS2000 TPS2000 and TDS3000 series digital storage oscilloscopes. Users can easily import waveforms originating from the DSO’s display or internal memory and download and "replay" them on the instrument. Versatile modulation and trigger capabilities The generators provide extensive modulation capabilities including AM, FM, FSK, PSK, pulse modulation and linear/logarithmic sweep. Internal and external modulation sources, as well as internal, external and gated trigger sources are supported. Modulation parameters can be set precisely and are adjustable over a wide range. For instance, burst count is programmable in 1 burst increments up to 10000 bursts and burst phase is adjustable in 0.1º increments. Convenient user interface and operation You can adjust parameters via knob or numeric keypad. Enter amplitude values directly in Vpp, mVpp, Vrms, mVrms or dBm, and display the correct voltage by entering the actual output configuration used (terminated with 50 Ohm or open circuit). You can enter frequency in terms of frequency or seconds using time values s, ms, Hz, kHz or MHz. Submenus are used for modulation modes and other complex functions. The generators are fully programmable via the standard RS232 interface, using SCPI commands. The instrument also provides 10 memories to store and recall instrument settings. Additionally the current state is saved at power off and can be restored at power up. Fig. 1 Arbitrary Waveform Generation Software Technical data subject to change © B&K Precision Corp. 2012 w w w.bk prec ision.c om Arbitrary/Function Generators Models 4084AWG & 4086AWG Specifications Models Fre qu ency Characteristics Sine Square All Other waveforms Frequency Stability Resolution Accuracy Data entry Units Wave form Characteris tics Main Waveforms (Sine, Square) Amplitude resolution Sample Rate Sine Harmonic Distortion of Sine Wave* 4084AWG 4086AWG 1µHz ~ 20MHz 1µHz ~ 20MHz 1µHz ~ 80MHz 1µHz ~ 40MHz 1µHz ~ 100kHz ±1x10-6 (22°C ±5°C) 1µHz ≤ ± 5x10-6 (22°C ±5°C) s, ms, Hz, kHz, MHz 12 bits 200MSa/s ≤ - 50dBc (frequency ≤ 5MHz) ≤ - 45dBc (frequency ≤ 10MHz) ≤ - 40dBc (frequency ≤ 20MHz) ≤ - 35dBc (frequency ≤ 40MHz) ≤ - 30dBc (frequency > 40MHz) 0.1% (20Hz ~ 100kHz) THD* Square Rise and fall time* ≤ 15ns * = Note: Test conditions for harmonic distortion, sine distortion, rise/fall time Output Amplitude 2Vp-p, Environmental temperature: 25°C±5°C Others built-in waveforms Sine, Square, Triangle, Positive Ramp, Falling Ramp, 27 build-in standard and Noise, Pulse, Positive Pulse, Negative Pulse, Positive complex waveforms DC, Negative DC, Stair wave, Coded Pulse, Full wave rectified, Half-wave rectified, Sine transverse cut, Sine vertical cut, Sine phase modulation, Logarithmic, Exponential, Half-round, Sinx/x, Square root, Tangent, Cardiac, Earthquake, Combination Waveform Length 4096 dots Amplitude Resolution 10 bits Pulse Duty Cycle 0.1% ~ 99.9% (below 10kHz), 1% ~ 99% (10kHz ~ 100kHz) Rise/Fall Time ≤ 100ns (Duty Cycle 20%) DC signal characteristics DC range ≤ 10mV – 10V (high impedance) DC Accuracy ≤ ±5% of setting +10mV (high impedance) Arbitrary Non volatile memory 8 waveforms Waveform length 8~16000 points Amplitude resolution 10 bits Frequency range 1µHz~100kHz Sample rate 200MSa/s Amplitu de Ch aracteristics Amplitude Range (open circuit) Freq ≤ 40MHz: 2mV ~ 20Vpp , 1mV ~ 10Vpp (50Ω) Freq > 40MHz: 2mV ~ 4Vp-p, 1mV ~ 2Vpp (50Ω) Resolution 2µVpp (open circuit), 1µVpp (50Ω) Accuracy ± 1%+0.2mV (sine wave relative to 1kHz) Stability ±0.5 % /3 hours Flatness For amplitude ≤ 2Vpp ±3% (freq≤ 5MHz), ±10% (5MHz2Vpp: ±5% (freq≤ 5MHz), ±10% (5MHz20MHz) ±1dBm (frequency>40MHz) Output Impedance 50Ω Output Units Vpp, mVpp, Vrms, mVrms, dBm DC Offset Characteristics Offset Range (open circuit) Freq ≤ 40MHz: ±10Vpk ac+dc (Offset ≤ 2 x pk to pk amplitude) Freq >40MHz: ±2Vpk ac+dc (Offset ≤ 2 x pk to pk amplitude) Offset Resolution 2µV (open circuit), 1µV (50Ω) Offset Error ±5% of setting +10mV (Ampl. ≤ 2Vpp into open circuit) ±5% of setting +20mV (Ampl. > 2Vpp into open circuit) Distortion Modulation Depth Modulation Error Max. Amplitude of ext. input signal FM Characteristics Carrier Waveforms Modulation Source Internal Modulating Waveform Frequency of modulating signal Deviation FSK Characteristics Carrier Waveform Control ModeI FSK Rate PSK Characteristics Carrier Waveform PSK Resolution PSK rate Control Mode ≤ 2% 1% ~ 120%, 1% ~ 80% (frequency>40MHz, Ampl > 2Vpp into open circuit) ± 5%+0.2% (100µHz < frequency ≤ 10kHz) ±10%+2% (10kHz < frequency ≤ 20kHz) 3Vp-p (-1.5V~ +1.5V) Sine or Square Internal or external Sine, Square, Triangle, Rising/Falling Ramp 100µHz ~ 10kHz Max. 50% of carrier frequency for internal FM Max 100kHz (carrier frequency≥ 5MHz) for external FM, with input signal voltage 3Vp-p (-1.5V~+1.5V) Sine or Square Internal or external trigger (external: TTL level, low level F1, high level F2) 0.1ms ~ 800s Sine or Square Phase 1 (P1) and Phase 2 (P2), range: 0.0 ~ 360.0° 0.1° 0.1ms ~ 800s Internal or external trigger (external: TTL level, low level P1, high level P2) Burst Characteristics Waveform Sine or Square Burst Counts 1 ~ 10000 cycles Time interval between bursts 0.1ms ~ 800s Control Mode Internal, single or external gated trigger Frequency Sweep Characteristics Waveform Sine or Square Sweep Time 1ms ~ 800s (linear), 100ms ~ 800s (log) Sweep Mode Linear or Logarithmic Start/ Stop Frequency Same as frequency range of Sine & Square External trigger signal frequency DC ~ 1kHz (linear) DC~10Hz (log) Control Mode Internal or external trigger I nputs/ Outputs Main Output Impedance 50Ω Protection Short circuit and overload protected Output MOD OUT Frequency 100Hz ~ 20kHz Waveform Sine, Square, Triangle, Rising/Falling Ramp Amplitude 5Vp-p ± 5% Output Impedance 600Ω Modulation IN 3Vpp = 100% Modulation External Input Trig/FSK/Burst Level - TTL Univ ersal Cou nter, Key Specs* Frequency Range Frequency Measurement 1Hz ~ 100MHz Totalize mode 50MHz max * For full specification of the counter section, refer to online manual at www.bkprecision.com G eneral Power Supply 198~242V or 99~121V, Frequency: 47~ 63Hz Power Consumption
4084AWG 价格&库存
很抱歉,暂时无法提供与“4084AWG”相匹配的价格&库存,您可以联系我们找货
