PG-100N-103R-W
PG-100N-103R-W
    NIDEC(尼得科)
    Manometer For Measuring Pressure (Air) Includes Battery, Half Union, Barb Fitting
PG-100N-103R-W 数据手册
HANDHELD DIGITAL MANOMETER PG-100N ■ FEATURES Zero point adjustment button ● Excellent stability H i g h p re c i s i o n s e m i c o n d u c to r c h i p c o m b i n e d w i t h temperature compensation circuit guarantee excellent stability. ● Long battery life Lasts more than 1000hrs with two AAA dry batteries. ● Automatic power off function ● Easy, one-handed operation ● Easy-to-read large LCD display ● Pressure unit selectable type also available Pressure port 3 1/2 digit LCD display (PG-100N-****-W). Power button Hold button Unit of display OUTLINE DIMENSIONS W55mm × H110 × D16.9mm ■ MODEL NUMBER DESIGNATION P G - 1 0 0 N - 1 0 2 R - M X2 T Traceability system chart Series name Blank: Not attached T: Traceability system chart Rated pressure range 101:− 10 ~ 10 kPa 102:− 100 ~ 100 kPa 103:− 100 ~ 1000 kPa Inspection report / Calibration Certificate Blank: Not attached X1:Inspection report X2:Inspection report and Calibration certificate Pressure reference R:Gauge(Compound) Unit of display Blank:kPa M:MPa H :mmHg ※ W:Selectable(bar, psi, inch Hg, mmHg, mmAq, kPa, MPa according to the pressure range) ※ ※:103R range products do not correspond to Unit mmHg of Pressure unit selectable W type. (Refer to the Pressure unit selectable W type below.) ■ Pressure unit selectable W type Pressure range kPa 101R ○ 102R ○ 103R ○ ※ " ー " is not supported as a display unit. Mpa ー ○ ○ mmHg Unit selectable W type in.Hg mmAq ○ ○ ○ ○ ー ○ ○ ー ー psi bar ○ ○ ○ ○ ○ ○ PG-100N HANDHELD DIGITAL MANOMETER ■ LIST OF MODEL NUMBERS 〈For non-corrosive gas〉 Pressure reference -10 ~ 10 Gauge(Compound) -100 ~ 100 -100 ~ 1000 Product only PG-100N-101R PG-100N-102R PG-100N-103R Inspection report PG-100N-101R-X1 PG-100N-102R-X1 PG-100N-103R-X1 Inspection report and Traceability system chart PG-100N-101R-X1T PG-100N-102R-X1T PG-100N-103R-X1T Inspection report and Calibration certificate PG-100N-101R-X2 PG-100N-102R-X2 PG-100N-103R-X2 Traceability system chart PG-100N-101R-T PG-100N-102R-T PG-100N-103R-T Inspection report,Calibration certificate and Traceability system chart PG-100N-101R-X2T PG-100N-102R-X2T PG-100N-103R-X2T Rated pressure range (kPa) kPa Product only PG-100N-103R-M Inspection report PG-100N-103R-M-X1 Inspection report and Traceability system chart PG-100N-103R-M-X1T Inspection report and Calibration certificate PG-100N-103R-M-X2 Traceability system chart PG-100N-103R-M-T Inspection report,Calibration certificate and Traceability system chart PG-100N-103R-M-X2T MPa Product only PG-100N-102R-H Inspection report PG-100N-102R-H-X1 Inspection report and Traceability system chart PG-100N-102R-H-X1T Inspection report and Calibration certificate PG-100N-102R-H-X2 Traceability system chart PG-100N-102R-H-T Inspection report,Calibration certificate and Traceability system chart PG-100N-102R-H-X2T mmHg Product only PG-100N-101R-W PG-100N-102R-W PG-100N-103R-W Inspection report PG-100N-101R-W-X1 PG-100N-102R-W-X1 PG-100N-103R-W-X1 Inspection report and Traceability system chart PG-100N-101R-W-X1T PG-100N-102R-W-X1T PG-100N-103R-W-X1T Inspection report and Calibration certificate PG-100N-101R-W-X2 PG-100N-102R-W-X2 PG-100N-103R-W-X2 Traceability system chart PG-100N-101R-W-T PG-100N-102R-W-T PG-100N-103R-W-T Inspection report,Calibration certificate and Traceability system chart PG-100N-101R-W-X2T PG-100N-102R-W-X2T PG-100N-103R-W-X2T Selectable PG-100N HANDHELD DIGITAL MANOMETER ■ STANDARD SPECIFICATIONS 〈kPa version〉 ● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5°C. Item PG-100N Gauge Pressure reference General specifications Model number 101R 102R 103R − 10 ~ 10 − 100 ~ 100 − 100 ~ 1000 Rated pressure range kPa Maximum pressure kPa 20 200 1500 Break-down pressure kPa 50 500 2000 Operating temp. range °C 0 ~ 50 Compensated temp. range °C 0 ~ 50 Operating humidity Storage temp. 15 ~ 85(No condensation) % RH − 20 ~ 70(Atmospheric pressure, humidity 65 %RH maximum) °C Pressure medium Non-corrosive gases M5 female Pressure port Net weight g Approx. 100 Display Power No. of digits 3 1/2 Display element LCD Rated display range − 10.00 ~ 10.00 Display cycle − 100.0 ~ 100.0 − 100 ~ 1000 −. 100 ~ 1.000(MPa) Approx. 4 times/s ± 0.5 %F.S. ± 2 digits (at 25 °C ± 5 °C) Integrated accuracy Resolution Power supply (External supply) Analog output AAA dry battery DC 1.5 V × 2 Battery life 1000 h minimum Output voltage ± 1.5 %F.S. ± 2 digits (at 25 °C ± 25 °C) ± 1.0 %F.S. ± 2 digits (at 25 °C ± 25 °C) 1 digit 5 ± 0.5 V DC 5 mA maximum 0 ~ ± 1.000 V ※ Proportionate to display value Output accuracy / Resolution ± 10 mV / 1mV Output resistance Approx. 10 kΩ Response Approx. 10 ms Additional function Accessories Option (Sold seperately) Auto power off, Display hold, Battery replacement display, (LOBAT), Zero point adjustment 2 fittings (half union for 6mm OD tube, barb fitting for 4mm OD tube), 2 AAA batteries, strap PG-100N soft carrying case PG-100N HANDHELD DIGITAL MANOMETER ■ STANDARD SPECIFICATIONS 〈Non SI unit version〉 ● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5°C. PG-100N Item Pressure reference Gauge Model number(mmHg display : compound) 102R-H Rated pressure range General specifications Maximum pressure Break-down pressure kPa (mmHg) kPa (mmHg) kPa (mmHg) Operating temp. range °C 0 ~ 50 Compensated temp. range °C 0 ~ 50 Operating humidity Storage temp. % RH °C Pressure medium Net weight Power 35 ~ 85(No condensation) − 20 ~ 70(Atmospheric pressure, humidity 65 %RH maximum) Non-corrosive gases M5 female Pressure port Display − 100 ~ 100 (− 750 ~ 750) 200 (1500) 500 (3750) g Approx. 100 AAA dry battery DC 1.5 V × 2 Battery life 1000 h minimum No. of digits 3 1/2 Display element LCD Rated display range(mmHg display) Display cycle − 750 ~ 750 Approx. 4 times/s ± 0.5 %F.S. ± 2 digits (at 25 °C ± 5 °C) Integrated accuracy ± 1.0 %F.S. ± 2 digits (at 25 °C ± 25 °C) Resolution Analog output Power supply (External supply) Output voltage 1 digit 5 ± 0.5 V DC 5 mA maximum 0 ~ ± 1.000 V ※ Proportionate to display value Output accuracy / Pesolution ± 10 mV / 1 mV Output resistance Approx. 10 kΩ Response Approx. 10 ms Additional function Accessories Option (Sold seperately) Auto power off , Display hold, Battery replacement display(LOBAT), Zero point adjustment 2 fittings (half union for 6mm OD tube, barb fitting for 4mm OD tube), 2 AAA batteries, strap PG-100N soft carrying case PG-100N HANDHELD DIGITAL MANOMETER ■ ENVIRONMENTAL CHARACTERISTICS Test conditions(At 25 ± 5 °C) Test item Permissible change Amplitude 1.5 mm P-P, 10 ~ 55 Hz, 3 directions for 2 hours each (packed) Vibration Shock 98.1 m/s2, 3 directions for 3 times each (packed) Pressure cycling 0 ~ Rated pressure, 106 cycles Moisture resistance 40 °C, 90 ~ 95 %RH, 240 hrs. ■ OUTLINE DIMENSIONS Indicating accuracy: ± 1 %F.S. maximum Unless otherwise specified, tolerance : ± 0.5 (Unit: mm) 1 Pressure Port M5 female Pressure medium Strap Power button Display Nameplate Zero adjust button Hold button Battery case ■ OPTION The soft carrying case for PG-100N ‒ Order item: PG-100 soft carrying case (Useful for when carrying out and keeping.)
PG-100N-103R-W 价格&库存
很抱歉,暂时无法提供与“PG-100N-103R-W”相匹配的价格&库存,您可以联系我们找货
