397
397
    TPI(TPI 公司)
    ROUND SPACER #4 ALUMINUM 3/16"
397 数据手册
397 Data Sheet 03.10 397 pH Meter - Pen Style Test the TPI advantage TPI Part Number 397 Features: • Wide pH range of 0.10-14.00pH Applications: covers most applications • Boiler water testing for proper pH level to avoid internal • Operating temperature from Specifications: Range: Accuracy: Calibration: Resolution: Operating Temp: Power supply: 0.10-14.00pH +0.10 pH 2 point system 0.10pH 40-120 ºF or 5-50 ºC (ATC) DC 4 × 1.5V (LR1130 Button battery) 40 -120 ºF (5 - 50 ºC); for material degradation temperature compensated readings • Check automotive • Waterproof design protects the meter during use radiators to avoid acid level build up resulting from • Low power consumption extends battery life for low operation costs dissimilar metals • Auto-off function turns power off automatically after • Onsite water testing 10 minutes for wells and septic systems; saving lad testing time • Quickly and easily • Replaceable Glass Test Tip Electrode that screws on for ease a solid of use • Protective case included for storage test aquariums, spas and swimming pools for proper pH levels www.tpithevalueleader.com Copyright © 2010 Test Products International, Inc.
很抱歉,暂时无法提供与“397”相匹配的价格&库存,您可以联系我们找货
