A771
A771
    TPI(TPI 公司)
    Gas Analyzer For Measuring Carbon Monoxide Includes Battery, Pouch, Sensor
A771 数据手册
A771 Carbon Monoxide Adapter for DMMs and Clamp-on Meters What about Carbon Monoxide? Measure Ambient Air CO With Any DMM National Ambient Air Quality Primary Standards in the US call for less then 9 ppm carbon monoxide for an 8 hour average during any 12 month period. • No Bulk! Easily carry one on your belt or tool box • Easy to use with any DMM or Clamp-on Meter with a minimum 3 1/2 digit LCD, 2 or 4 Volt DC range and 10M or greater input impedance Concentrations of 1 to 2 ppm may be found in homes with a normally operating gas furnace to well over 1,000 ppm in homes with a faulty furnace. • A771 generates 1mV per 1ppm of CO • Detects CO levels from 0-1999 ppm, with resolution as low as 0.1ppm and ±5% of reading accuracy • Low battery and power indication • Calibrate in the field • Complete with Belt pouch, A771P Just 200 ppm CO over 2 to 3 hours can cause slight headache, fatigue, dizziness, and nausea. • Use as personal CO alarm 3-YEAR LIMITED WARRANTY Carbon Monoxide testing is a crucial service provided by HVAC/R technicians. Turn over for technical information and accessory part numbers. The Value Leader™ Actual size 6.5” X 2.0” X 1.25” 65 X 50 X 29mm Use Your DMM And The A771 For These Carbon Monoxide Applications • Conduct Tests of CO Levels In Room Air To Meet ASHRAE and OSHA Standards • Confirm Proper Operation of Alarming CO Detectors in Households • Check For Proper Installation of Ventless Gas Fireplaces, Furnaces, and Other Combustion Devices. • Use The A771 as a Personal Alarm Preset at 30 CO visit us at www.tpi-thevalueleader.com A771 Carbon Monoxide Adapter for DMMs and Clamp-on Meters TECHNICAL SPECIFICATIONS AND ACCESSORIES • Digital Multimeters • Clamp Meters • Hand-held Oscilloscopes • Refrigerant & Combustible Gas Leak Detectors • Temperature Testers • BNC Coax Cable Connectors • Test Leads • Accessories SPECIFICATIONS CO Sensor Range Alarms Alarm Set Range Response Time Operation Temperature Relative Humidity Accuracy Size Weight Battery Battery Life 24 month warranty 0 - 1999ppm with 3.5 digit DMM display Visual/Audible 0 to 200ppm 90% of reading in 30 seconds -10° to 50° or -50° to 122°F 5 to 95% RH ±5ppm or 5% of reading whichever is greater 6.5 x 2.1 x 1.2 in (165 x 55 x 30 mm 7.23oz (205 g) 9V Alkaline 500 hours Distributed By: Test Products International, Inc. Headquarters: 9615 SW Allen Blvd. Beaverton, OR 97005 USA 503-520-9197 Fax: 503-520-1225 email: info@tpi-thevalueleader.com Test Products International, Ltd. 342 Bronte St. South Unit 9 Milton, Ontario L9T 5B7 Canada 905-693-8558 Fax: 905-693-0888 email: info@tpicanada.com Test Products International UK Ltd. Longley House, East Park Crawley, West Sussex RH10 6AP England Tel: +44 (0)1293 561212 Fax: +44 (0)1293813465 contactus@tpieurope.com To learn about the entire line of TPI products visit: www.tpi-thevalueleader.com L A771-1104 Copyright © 2004 Test Products International, Inc.
很抱歉,暂时无法提供与“A771”相匹配的价格&库存,您可以联系我们找货
