719
719
    TPI(TPI 公司)
    COMBUSTIBLE GAS LEAK DETECTOR
719 数据手册
719 Combustible Gas Leak Detector Features • Visual and audible indication of combustible gas leaks. • 30ppm sensitivity (methane) • Detect combustible gases including natural gas, propane, butane, etc. • Thumbwheel adjustable tic rate to locate leaks quickly and accurately. • Audio / Visual alarm indication. • Earphone jack for use in noisy environments. • Approximately 20 hours of continuous use (C cell alkaline batteries x2) Specifications Leak Detection Sensitivity (methane): 30ppm Audible Leak Indication: Adjustable tic rate via side thumb wheel Alarm Indication: Visual and audible Sensor Test and Zero: Automatic at start up Goose Neck: 16” long with visual alarm indicator in sensor housing Dimensions Copyright © 2008 Test Products International, Inc. Size: 9.4” x 2.9” x 2.2” (240mm x 74mm x 55mm) Weight: 1 lb (454g)
很抱歉,暂时无法提供与“719”相匹配的价格&库存,您可以联系我们找货
