707
707
    TPI(TPI 公司)
    BOX ABS BLACK 6.25"L X 3.75"W
707 数据手册
707 Carbon Monoxide Analyzer What about Carbon Monoxide? Test flue gasses at home or office spaces for the presence and location of CO leaks. With a protective rubber boot, the new 707 fits comfortably in your hand and operates with the push of a button. National Ambient Air Quality Primary Standards in the US call for less than 9 ppm carbon monoxide for an 8 hour average during any 12 month period. • Clear and fast response with advance pump driven technology. • Peak Hold to capture peak CO reading. • Instrument recycles and will not shut off if 15ppm CO is present, increasing safety. • Store Button allows you to save up to eight readings and then print using the IR port and optional A740 printer. • 1 ppm sensitivity. • Measures up to 10,000ppm. • Push on fittings are fast and easy to use. • Large easy to read backlit display. • Advanced electrochemical sensor is field replaceable and calibrateable. • Protective rubber boot and soft carrying case with shoulder strap 3-YEAR LIMITED is included. Concentrations of 1 to 2 ppm may be found in homes with a normally operating gas furnace, to well over 1,000ppm in homes with a faulty furnace. Just 200 ppm CO over 2 to 3 hours can cause slight headache, fatigue, dizziness, and nausea. Carbon Monoxide testing is a crucial service provided by HVAC/R technicians. Learn more about CO on the back of this sheet. Turn over for technical information and accessory part numbers. NOTE: When selecting oil as fuel be sure to use the optional oil filter or reading could become erratic. Order item A773. The Value ™ Leader WARRANTY 4.0”w X 8.12”h x 2.25”d More About CO Carbon monoxide poisoning is one of the leading causes of sickness and death each year. CO is the by-product of incomplete combustion in heating and cooking appliances, as well as gasoline, natural gas, and propane powered engines. Carbon monoxide is a colorless, tasteless, invisible toxic gas, which can cause serious health problems. The following chart depicts the health effects of exposure to CO: 0ppm 9ppm 50ppm 400ppm 800ppm 1600ppm 12800ppm Desired level Acceptable limit above ambient conditions in living areas (ASHRAE) Limit for continuous exposure in any 8 hour period (OSHA) Frontal headaches 1-2 hours Nausea and convulsions, death within 2 hours Nausea within 20 minutes, death within 1 hour Death within 1-3 minutes A740 Infrared Printer • Self test at power on. • Adjustable contrast. • Uses common thermal paper. • Manual paper advance. 3-YEAR LIMITED WARRANTY 3.0”w x 6.0 h x 1.75”d visit us at www.tpi-thevalueleader.com 707 Carbon Monoxide Analyzer TECHNICAL SPECIFICATIONS AND ACCESSORIES Power Supply Sensor Range Warm Up Response Time Duty Cycle Battery Life Size Weight Probe Length Tube Length 3 “AA” Alkaline Batteries Electrochemical (2 year warranty) 0- 10,000ppm Approx. 20 seconds 90% of reading < 60 seconds 30 minutes Approx. 30 hours 3.75” x 8” x 3” (95 x 203 x 76 mm) 1.1 lbs. (500g) 9” (230mm) 5’ (152.4 cm) Standard Sensor Instruction Manual Soft Carrying Case Protective Boot Pump Protect Filter Assembly In-line Filter Assembly Flue Probe Batteries Optional Calibration Kit Calibration Gas IR Printer Oil Filter A780 707 Manual A768 A765 A763 A762 A729 3 each “AA” Alkaline A733 728 A740 A773 NOTE: When selecting oil as fuel be sure to use the optional oil filter or reading could become erratic. Order item A773. Test Products International, Inc. Headquarters: 9615 SW Allen Blvd. Beaverton, OR 97005 USA 503-502-9197 Fax: 503-520-1225 email: Distributed By: Test Products International, Ltd. 342 Bronte St. South Unit 9 Milton, Ontario L9T 5B7 Canada 905-693-8558 Fax: 905-693-0888 email: Can a CO analyzer be used for heat exchanger testing? While a CO analyzer can provide a safety test of the furnace, it cannot provide a discernable test for heat exchanger integrity. The TPI HXG2 and HETKIT are recommended for this test and together are AGA approved. How often should I calibrate my CO analyzer? It depends on the use of the instrument. If used for service work, it is recommended that an annual calibration be performed. If any aspect of worker safety is included in the instrument’s job, monthly calibration is recommended. If I perform my own calibration, do I increase my liability? As long as traceable calibration gas is used and manufacturer’s calibration procedures are followed, liability will be minimized. Calibration records should be documented and retained. How long will the TPI 707 sensor last? Two to three years. Who can use this product? Users of the 707 include HVACR contractors; gas fireplace installers; gas utility companies; chemical plants; propane companies; municiple, industrial; and rural fire departments; school and municipalities; and home inspection professionals. info@tpicanada.com Test Products International UK Ltd. contactus@tpieurope.com Why should I purchase a pump driven CO analyzer rather than a less expensive CO monitor? A pump driven analyzer is a much more versatile tool. The pump draws a sample into the instrument whish allows source pinpointing. A pump driven instrument will also respond faster, and can be used for hot air (flue) sampling. How many calibrations can I expect out of a 21 liter bottle of calibration gas? 35-50 calibrations info@tpi-thevalueleader.com Longley House, East Park Crawley, West Sussex RH10 6AP England Tel: +44 (0)1293 561212 Fax: +44 (0)1293813465 FAQ To learn about the entire line of TPI products visit: www.tpi-thevalueleader.com L 707-0305 Copyright © 2005 Test Products International, Inc. L707-03
很抱歉,暂时无法提供与“707”相匹配的价格&库存,您可以联系我们找货
