HXG-2D
HXG-2D
    TPI(TPI 公司)
    DETECTORCOMBUSTIBLEGASLEAK
HXG-2D 数据手册
HXG-2D Data Sheet 07.10 HXG-2D Combustible Gas Leak Detector PARTIAL LIST OF INDUSTRlES: • Utility Companies • Gas Processing Plants • Propane Marketers • Safety Engineers • Fire and Police • Emergency Vehicles • Appliance Repair • Plant Maintenance • Plumbing Contractors • Furnace Heat Exchanger Testing • Marine Operations • Heating and Air Conditioning • Municipalities • Mobile Home Parks • Apartment Buildings PARTIAL LIST OF GASES SENSED: • Methane • Natural Gas • Ammonia • Hydrogen • Butane • Propane • Acetone • Gasoline • Halon • Jet Fuel • Refrigerants • Ethylene Oxide • Lacquer Thinner • Industrial Solvents • Alcohol "How big is the leak?' • Direct PPM readout • Direct "LEL" percent readout FIND LEAKS QUICKLY • New "Patent Pending" electronic tick control • Ideal for Natural, Propane and Butane gas leaks SAFE, DURABLE and RELIABLE • Intrinsically safe design • SENSIT "ruggedized" design HXG-2D SPECIFICATIONS PHYSICAL Size: Weight: Construction: Battery Power: Gooseneck: 3.5 x 10 x 1.6" (8.9 x 25 x 4 cm) 1.3 Ibs. (0.59kg) High impact ABS 3 "C" alkaline batteries or 3 "C" rechargeable NiCad batteries (Recharge time ~ 5 hours) Alkaline - 50 hours of operation Rechargeable - 20 hours of operation 16" reach (41 cm) SENSOR Type: Sensitivity: Response Time: Alarm Set: Solid State To 10ppm Less than 1 second 0.5% methane (10% LEL) Battery Life: PARTIAL LIST OF GASES SENSED Methane Gasoline Natural Gas Halon Ammonia Jet Fuel Hydrogen Refrigerants Butane Ethylene Oxide Propane Lacquer Thinner Acetone Industrial Solvents Copyright © 2010 Test Products International, Inc. www.testproductsintl.com Sensor Red Alarm Light Green Ready Light Gooseneck Clip Flexible Gooseneck “C” Light/Zero Button “A” Power/Mute Button Battery Compartment “B” Tick/Cal Button Ex II 2 G Ex ic IIB T3 IP20 Intrinsically Safe (USA) Class I, Division 1, Groups C and D, T3 (Canada) Class I, Division 1, Groups C and D, T3 Patent Pending Size: Weight: 3.5 x 10 x 1.6" (8.9 x 25 x 4 cm) 1.3 Ibs. (0.59kg)
HXG-2D 价格&库存
很抱歉,暂时无法提供与“HXG-2D”相匹配的价格&库存,您可以联系我们找货
