709R
709R
    TPI(TPI 公司)
    709 COMBUSTION ANALYZER
709R 数据手册
709R Combustion Analyser Delivering test and measurement advantages for HVAC/R professionals worldwide Test the TPI advantage The Value Leader TM www.tpieurope.com Test Products International, Europe Ltd Longley House International Drive Southgate Crawley West Sussex RH10 6AQ Tel: +44 (0) 1293 530196 Fax: +44 (0) 1293 531870 contactus@tpieurope.com HANDHELD OSCILLOSCOPES DIGITAL MULTIMETERS DIGITAL CLAMP-ON METERS DMM & CLAMP-ON ACCESSORIES CO ANALYSERS COMBUSTION EFFICIENCY ANALYSERS COMBUSTIBLE GAS DETECTORS GAS DETECTION ACCESSORIES DIGITAL MANOMETERS REFRIGERANT LEAK DETECTORS TEMPERATURE INSTRUMENTS INFRARED NON-CONTACT THERMOMETERS POCKET DIGITAL THERMOMETERS DIGITAL VACUUM GAUGE ELECTRICAL TESTERS HUMIDITY TESTERS AIRFLOW TESTERS SERVICE & CALIBRATION ACCESSORIES Visit tpieurope.com or call 01293-530196 The TPI 709R Combustion Analyser Performs: 1) Combustion Analysis l Check Net/Gross Efficiency l Adjust CO,CO2 & Ratio Values l Check CO2 & O2 Values on Appliance 2) Differential Pressure l Adjust Gas/Air Mixture l Test Air Pressure Switch l Use for Tightness Testing Use with optional A740 Printer! 3) Differential Temperature l Flow & Return Adjustments l Balance Radiators l Check Thermostat & Water Temperatures 4) CO Detection l Highlights CO Spillage l Indicates areas of High CO Production * Wa r r a n t y S u b j e c t t o A n n u a l S e r v i c i n g b y T P I E u r o p e L t d . TIME & MONEY SAVING FEATURES!!!!!!!!!! l Long Life O2 & CO Sensors. Long Life Sensors means lower servicing costs during a 6 year period from new. l Water Trap & Disc Filter as standard on the thermocouple gas sampling probe. Complete protection from water ingress into 709R. l In-line Pump Protection Filter as standard. Stopping dust/dirt ingress into pump (the main cause of pump/analyser failure) See Overleaf for Accessories & Specifications 709R Combustion Analyser Delivering test and measurement advantages for HVAC/R professionals worldwide Test the TPI advantage The Value Leader TM www.tpieurope.com Test Products International, Europe Ltd Longley House International Drive Southgate Crawley West Sussex RH10 6AQ Tel: +44 (0) 1293 530196 Fax: +44 (0) 1293 531870 contactus@tpieurope.com HANDHELD OSCILLOSCOPES DIGITAL MULTIMETERS DIGITAL CLAMP-ON METERS DMM & CLAMP-ON ACCESSORIES CO ANALYSERS COMBUSTION EFFICIENCY ANALYSERS COMBUSTIBLE GAS DETECTORS GAS DETECTION ACCESSORIES DIGITAL MANOMETERS REFRIGERANT LEAK DETECTORS TEMPERATURE INSTRUMENTS Carbon Monoxide (CO) Measurement Range 0 to 10,000 ppm Resolution 1 ppm Accuracy ±5 ppm or 5%, whichever is greater Oxygen (0 2 ) Measurement Range Resolution Accuracy 0 to 25% 0.1% ±0.3% Carbon Dioxide (CO 2 ) Range 0 to 25% Resolution 0.1% Accuracy Calculated Ratio (CO/CO2) Range Resolution Accuracy 0 to 0.999 0.001 Calculated Gross/Net Efficiency Range 0 to 100% Resolution 0.1% Temperature Measurement Range -40° to 800° C (-40° to 1472° F) Resolution 1°C or F Accuracy (K-type) ±0.3%, ±1°C or ±2°F Draft/Pressure Measurement Selectable Ranges mBar,kPa, and inH2O Ranges Resolution Accuracy Instrument Specifications Operating Temperature Range -10° to 50°C (14° to 122°F) Battery Rechargeable Ni-MH, >6 Hour Life Charger Input Voltage 115V or 230V : 50/60 Hz AC Fuels Natural Gas, LPG, Light Oil, Heavy Oil OPT 1 = Bituminous Coal OPT 2 = Anthrachite Coal OPT 3 = Coke OPT 4 = Butane OPT 5 = Wood (Dry) OPT 6 = Bagasse Display Backlit LCD Data Storage 50 sets of readings Time & Date 24 Hour Real Time Clock Dimensions 200mm x 90mm x 60mm Weight 500g Exhaust Safety Spigot Conforms To: BS7927 (and the draft BS7967) Standard Accessories Flue Temperature Probe ‘K’-Type Temperature Air Probe In-Line Water Trap Bowl Filter Complete Mini Pump Protection Filter Assembly Battery Charger Protective Boot Soft Carrying Case Exhaust Spigot -150 mBar to +150 mBar -15 kPa to +15 kPa -60 inH2O to +60 in H20 Optional Accessories:- 0.01mBar ±0/5% fsd A773 - Oil Filter A740 Infra Red Printer A770 GK11M A795 A763 A766 A765 A768 A764 A788 - Smoke Test Pump INFRARED NON-CONTACT THERMOMETERS POCKET DIGITAL THERMOMETERS CK21M - Temperature Pipe Clamps DIGITAL VACUUM GAUGE ELECTRICAL TESTERS HUMIDITY TESTERS A746 - 10 Spare Paper Rolls for IR Printer Plus Various ‘K’ Type Thermocouple Probe AIRFLOW TESTERS SERVICE & CALIBRATION ACCESSORIES Visit tpieurope.com or call 01293-530196 To learn more about the vast TPI Product Range visit www.tpieurope.com
很抱歉,暂时无法提供与“709R”相匹配的价格&库存,您可以联系我们找货
