716
716
    TPI(TPI 公司)
    CASE PLASTIC BLACK 5"L X 4.25"W
716 数据手册
716 Combustion Analyzer 716 Data Sheet 06.12 Test the TPI Advantage Specifications Instrument Operating Temperature Range Battery / Batery Life Charger Input Voltage Fuels Features QUICK AND SIMPLE SET UP All TPI analyzers feature quick and simple set up. Fast purge and the ability to performfuel selectionduring start up enable tests to be performed quickly without requiring extra set-up time after initial startup. TPI analyzers also use the last selected fuel as the default setting. This feature prevents the need toperform fuel selection every time the analyzer is turned on. • Built-in differential manometer with 0.001” H2O resolution • Calculates combustion efficiency • Data Logging with time and date stamp • Will not shut off if 15 ppm CO is present for increased safety • Communicate to a PC via the USB interface • Optional A740 IR printer available for hard copies of test results • Built-in differential thermometer • Store function to save up to 10 readings • Pump driven for fast response • Push on fittings for fast and easy use • Large easy to read backlit display • Ten selectable fuels www.tpithevalueleader.com Units of Pressure Display Data Storage Data Logging Single Logging Time & Date Dimensions Weight 14°F to +122°F (-10°C to +50°C) Rechargeable Ni-MH / > 6 Hours 115V or 230V : 50/60 Hz AC Natural Gas, LPG, Light Oil, Heavy Oil, Bituminous Coal, Anthracite Coal, Coke, Butane, Wood, Bagasse mbar, kPa & inH2O 8 line graphical LCD Backlit 100 sets of readings 400 sets of readings 150 sets of readings 24 Hour Real Time Clock 7.8” x 3.5” x 2.4” 1.1lbs Gases Range Resolution Oxygen 0-25% 0.1% Carbon Monoxide 0-10,000 ppm 1 ppm Carbon Dioxide 0-25% 0.1% CO/CO2 Ratio 0-0.999 0.001 Combustion Eff. 0-100% 0.1% Gas Leak Sensor 100-10,000ppm (calibrated to methane) * Bluetooth module optional Pressure Measurement Selectable Ranges mbar, kPa and inH2O Range -120 inH2O to 120 inH2O Resolution 0.001 inH2O Accuracy +/- 0.5% fsd A787 Soft Carrying Case A776 Static Tip (2) Temperature Measurement Input Type K-Type thermocouple Range -58°F to 1832°F (-50°C to 1000°C)* Resolution 1°F (1°C) Accuracy +/-(0.3% of rdg+2°F) or +/-(0.3% of rdg+1°C) A770 Flue Probe A603 Brass Hose Barb Fitting (2) Copyright © 2012 Test Products International, Inc. Accuracy +/- 0.3% +/- 5 ppm or 5% Calculated Calculated Calculated GK11M K-type thermocouple A774 Silicone Tubing A611 Gas Valve Pressure Adapter A806 Combustible Gas Leak Probe A791 Adapter tubing 716 Combustion Analyzer Test the TPI Advantage 716 Data Sheet 06.12 Gas and Pressure Inlet Ports Charger Socket and USB Port Thermocouple Sockets Using TPI analyzers to determine combustion efficiency at the time of equipment set up minimizes call backs. Analyzers can be used to verify to the home owner the value of service work by showing the increase in equipment efficiency after work is performed. Efficiency calculations can also be used to generate business by demonstrating the need to improve the efficiency of equipment or to show the benefit of purchasing new equipment with higher efficiency. QUICK AND SIMPLE SET UP All TPI analyzers feature quick and simple set up. Fast purge and the ability to perform fuel selection during start up enable tests to be performed quickly without requiring extra set-up time after initial start up. TPI analyzers also use the last selected fuel as the default setting. This feature prevents the need to perform fuel selection every time the analyzer is turned on. Exhaust Port Infrared Window Blue Soft Keys: The function of these keys is shown on the bottom part of the display and changes depending on the menu selected. Up Arrow Key: Scrolls up and increases values in menus. Down Arrow Key: Scrolls down and decreases values in menus. On/Off Key: Home: Turns instrument On and Off Returns the analyzer to the main menu. All combustion analyzers come with A787 soft padded carrying case 200mm x 90mm x 60mm Back Key: Returns the analyzer to a previous menu level.
很抱歉,暂时无法提供与“716”相匹配的价格&库存,您可以联系我们找货
