NC1GY
NC1GY
    TPI(TPI 公司)
    CLIP NANO GRAY
NC1GY 数据手册
SURFACE MOUNT TEST CLIPS DESCRIPTION AND COLOR CHOICE SETS FEATURES Access 0.3mm or 1.27mm Pitch Leads Allows you to attached the clip to a lead on the smallest of surface mount IC’s. Normal oscilloscope lead tips are too large and the probe handle is too heavy to access these leads. Gold-Plated hood and contact Ensure minimal signal loss and constant contact with highly conductive gold plating. Fluorine Resin coated barrel extension The barrel of the clip is fully insulated eliminating the chance of clip shorting together. Assorted Colors Clips are available in Black, Red, Yellow, Blue, Green and Gray for easy identification SPECIFICATIONS Maximum Voltage: 25VDC Maximum Amperage: 300mADC Part No. NANO CLIPS 0.3 mm NC2BR NC6BR NC6R NC6B NC6Y NC6CBIue NC6G NC6GY NC12 NC1B NC1GY NC1Y NC1G NC1Blue NCGround NCHot NCDual LC85 LC65 MICRO CLIPS 1.27 mm MC1B MC1G MC1R MC12 Description Package Includes black, red black, red red black yellow blue green gray assorted black gray yellow green blue ground hot dual lead lead out contact lead out contact 2 clips, 2 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 6 clips, 3 lead sets, and ground lead 12 clips, 6 lead sets, and ground lead 1 clip 1 clip 1 clip 1 clip 1 clip 1 lead 1 lead 1 lead use with 24-28 AWG wire (solder type) use crimp tool for Nano clips and micro clips black gray red assorted 1 clip 1 clip 1 clip 6 clips, 3 lead sets, and ground lead MECHANICAL Nano clip • 0.3 mm pitch Micro clip • 1.27 mm pitch Dimensions in mm
NC1GY
1. 物料型号:文档列出了多种型号的测试夹,包括NANO CLIPS 0.3mm和MICRO CLIPS 1.27mm,具体型号如NC2BR、NC6BR、NC6R等。
2. 器件简介:这些测试夹适用于接触最小尺寸的表面贴装集成电路的引脚,特别是0.3mm或1.27mm间距的引脚。
3. 引脚分配:文档中提到了不同颜色的测试夹,每种颜色代表不同的引脚分配,例如黑色、红色、黄色等。
4. 参数特性: - 最大电压:25VDC - 最大电流:300mA
5. 功能详解: - 金镀罩和接触点确保最小信号损失和与高导电金的持续接触。 - 氟树脂涂层的夹子杆完全绝缘,消除了夹子短路的可能性。
6. 应用信息:测试夹适用于需要精确测量和测试的场合,特别是在需要接触小间距引脚的表面贴装IC时。
7. 封装信息:文档提供了不同型号测试夹的尺寸信息,例如Nano clip的尺寸为1.65mm x 12.5mm x 4.4mm,Micro clip的尺寸为3.0mm x 25mm x 18.7mm。
NC1GY 价格&库存
很抱歉,暂时无法提供与“NC1GY”相匹配的价格&库存,您可以联系我们找货
