BU-60X
BU-60X
    MUELLERELECTRIC
    CLIP ALLIGATOR STNLSS STEEL 10A
BU-60X 数据手册
BU-60 Series (Uninsulated Steel Alligator Clips) • • • • • • Mueller Electric’s BU-60 is the most common and versatile alligator clip. Compatible with BU-62 and BU-62S high-temperature PVC insulators. Overall length 1.96” (50.1mm), overall width 0.31” (7.9mm), maximum jaw spread = 0.31” (7.9mm) Can be attached to wire via solder or crimp connection. Ratings: Current 10 Amps The BU-60 is sold under the following models: BU-60 Nickel-plated steel clip, compatible with 4mm banana plugs BU-60HT Zinc-plated steel BU-60, rated to 1100°F (593°C) BU-60X Stainless-steel BU-60 (including hardware) BU-60BLACK Black BU-60 BU-60G Gold-plated steel BU-60 BU-60U BU-60 with U-shaped barrel BU-60TBO BU-60 with 8-32 threaded barrel BU-60PR2 BU-60 with phone tip/test prod tip connection BU-60S BU-60 with #6 screw for wire attachment BU-60-ZZZN Same as BU-60 with no screw hole, no wire strap RoHS 3 compliant Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305 www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
BU-60X 价格&库存
很抱歉,暂时无法提供与“BU-60X”相匹配的价格&库存,您可以联系我们找货
BU-60X
  • 1+12.18163
  • 5+11.51086
  • 11+10.07350
  • 29+9.54647
库存:71
BU-60X
  • 5+8.87821
  • 65+8.67974
  • 125+8.49748
库存:770
BU-60X
  • 1+13.144641+1.57070
  • 5+12.388115+1.48030
  • 25+11.2533225+1.34470
库存:71
BU-60X
  • 250+7.27227
  • 500+7.09001
  • 1000+6.98167
库存:775
BU-60X
  • 1+11.592611+1.38525
  • 10+9.4922310+1.13426
  • 100+9.04816100+1.08120
  • 500+8.75178500+1.04579
  • 1000+8.590281000+1.02649
库存:4565
