BU-60C
BU-60C
    MUELLERELECTRIC
    CLIP COPPER 10A ALLIGATOR 1.97"
BU-60C 数据手册
BU-60 Series (Uninsulated Steel Alligator Clips) • • • • • • Mueller Electric’s BU-60 is the most common and versatile alligator clip. Compatible with BU-62 and BU-62S high-temperature PVC insulators. Overall length 1.96” (50.1mm), overall width 0.31” (7.9mm), maximum jaw spread = 0.31” (7.9mm) Can be attached to wire via solder or crimp connection. Ratings: Current 10 Amps The BU-60 is sold under the following models: BU-60 Nickel-plated steel clip, compatible with 4mm banana plugs BU-60HT Zinc-plated steel BU-60, rated to 1100°F (593°C) BU-60X Stainless-steel BU-60 (including hardware) BU-60BLACK Black BU-60 BU-60G Gold-plated steel BU-60 BU-60U BU-60 with U-shaped barrel BU-60TBO BU-60 with 8-32 threaded barrel BU-60PR2 BU-60 with phone tip/test prod tip connection BU-60S BU-60 with #6 screw for wire attachment BU-60-ZZZN Same as BU-60 with no screw hole, no wire strap RoHS 3 compliant Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305 www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
BU-60C 价格&库存
很抱歉,暂时无法提供与“BU-60C”相匹配的价格&库存,您可以联系我们找货
BU-60C
  • 1+10.970731+1.42380
  • 5+10.361255+1.34470
  • 25+9.7517625+1.26560
  • 100+9.22934100+1.19780
  • 200+8.96814200+1.16390
  • 500+8.53279500+1.10740
  • 1000+8.271581000+1.07350
库存:50
BU-60C
    • 5+12.02591
    • 25+11.90374
    • 50+11.80073
    库存:60
    BU-60C
    • 1+13.414111+1.74091
    • 10+11.8251210+1.53469
    • 25+11.3839625+1.47743
    • 100+11.03105100+1.43163
    • 500+10.76631500+1.39727
    • 1000+10.589891000+1.37438
    库存:2157
