JP-8783-S
JP-8783-S
    MUELLERELECTRIC
    TESTCLIP
JP-8783-S 数据手册
JP-8783-@ (Large Telecom Clip with Bed of Nails and Spike) • The JP-8783 is the most versatile and widely used telecom clip on the market. Jaws open to a maximum of 1.0” (25mm). • Overall length 2.6” (66mm) (Except where noted) • Material: Clip Nickel sliver Hardware Brass • The JP-8783 is sold as is or with the following suffixes: Blank Has wire mounting hardware installed -N No wire mounting (used if you want to solder wire to clip) -L Wire mounting hardware included but not installed -J 4mm banana jack installed (increases length to 3.3” (84mm)) -TJ 8-32 threaded banana jack installed (Increases to 3.3”(84mm)) -S Same as {Blank} except material is nickel-plated steel -SN Same as {-N} except material is nickel-plated steel • RoHS 3 compliant Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305 www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
JP-8783-S 价格&库存
很抱歉,暂时无法提供与“JP-8783-S”相匹配的价格&库存,您可以联系我们找货
JP-8783-S
  • 1+65.273141+8.44408
  • 10+57.4335410+7.42991
  • 25+55.1434525+7.13365
  • 100+53.46997100+6.91716
  • 500+52.41322500+6.78045
  • 1000+51.355901000+6.64367
库存:6
