JP-25182-N
JP-25182-N
    MUELLERELECTRIC
    TEST CLIP
JP-25182-N 数据手册
JP-25182-@ (Small Telecom Clip with Bed of Nails) JP-25182/JP25182-S JP-25182-N/JP25182-SN JP-25182-J/JP-25182-TJ • The JP-25182 is the smaller version of the JP-8783. Intended for applications that do not require the single spike. Jaws open to a maximum of 1.0” (25.4mm). • Overall length 2.34” (59.4mm) (Except where noted) • Material: Clip Nickel Silver (Except where noted) Hardware Brass • RoHS 3 compliant • The JP-25182 is sold as is or with the following suffixes: Blank Has wire mounting hardware installed -N No wire mounting (used if you want to solder wire to clip) -L Wire mounting hardware included but not installed -J 4mm banana jack installed (increases length to 2.9” (74mm)) -TJ 8-32 threaded banana jack installed (Increases to 2.9” (74mm)) -S Same as {Blank} except material is nickel-plated steel -SN Same as {-N} except material is nickel-plated steel -SL Same as {-L} except material is nickel-plated steel Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305 www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
JP-25182-N 价格&库存
很抱歉,暂时无法提供与“JP-25182-N”相匹配的价格&库存,您可以联系我们找货
