JP-8078-TJ
JP-8078-TJ
    MUELLERELECTRIC
    TESTCLIP
JP-8078-TJ 数据手册
JP-8078-@ (Small Telecom Clip with Hex Spike) • The JP-8078 is a small framed, telecom clip with a hex spike for insulation piercing. Jaw opens to maximum of 1.0” (25mm). • Overall length 2.34” (59.4mm) (Except where noted) • Material: Clip Nickel silver Hardware Brass • The JP-8078 is sold as is or with the following suffixes: Blank Has wire mounting hardware installed -N No wire mounting (used if you want to solder wire to clip) -L Wire mounting hardware included but not installed -J 4mm banana jack installed (increases length to 2.9” (74mm)) -TJ 8-32 threaded banana jack installed (increases to 2.9” (74mm)) • RoHS 3 compliant Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305 www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
JP-8078-TJ 价格&库存
很抱歉,暂时无法提供与“JP-8078-TJ”相匹配的价格&库存,您可以联系我们找货
