JP-8783-@
(Large Telecom Clip with Bed of Nails and Spike)
• The JP-8783 is the most versatile and widely used telecom clip on the
market. Jaws open to a maximum of 1.0” (25mm).
• Overall length 2.6” (66mm) (Except where noted)
• Material: Clip
Nickel sliver
Hardware Brass
• The JP-8783 is sold as is or with the following suffixes:
Blank
Has wire mounting hardware installed
-N
No wire mounting (used if you want to solder wire to clip)
-L
Wire mounting hardware included but not installed
-J
4mm banana jack installed (increases length to 3.3” (84mm))
-TJ
8-32 threaded banana jack installed (Increases to 3.3”(84mm))
-S
Same as {Blank} except material is nickel-plated steel
-SN
Same as {-N} except material is nickel-plated steel
• RoHS 3 compliant
Mueller Electric Company
2850 Gilchrist Rd. Bld 5A
Akron, OH 44305
www.muellerelectric.com
Toll Free: 800.955.2629
Phone: 330.780.2525
Fax: 330.780.2524
很抱歉,暂时无法提供与“JP-8783”相匹配的价格&库存,您可以联系我们找货
