FK25L
FK25L
    TPI(TPI 公司)
    FLAT SENSOR BETWEEN PACK PROBE
FK25L 数据手册
Temperature Probes Probe Tips Penetration / Immersion Type “F” 20 Pointed penetration 21 Tapered penetration 22 Chisel penetration 24 Rounded Immersion 26 Corkscrew penetration 28 Alligator Immersion Surface/Contact Type “C” 30 Flat disk (Thermistor) 32 Ribbon 34 Between pack 36 Heavy duty spring Air/Gas Type “G” 40 Air (Thermistor) 42 Beaded thermocouple 44 Hooded 46 Caged 48 Caged with rack clip Sub-Mini Connector Lumberg Connector Bipolar Connectors Temperature Probe Catalog V101 Three Year Limited Warranty on TPI Products Copyright © 2008 Test Products International, Inc. www.tpi-thevalueleader.com • 503.520.9197 Probe Tips Probe Type Penetration / Immersion Type “F” F: Penetration/immersion C: Contact/Surface G: Air/Gas 20 Pointed penetration Sensor Type K: Type K-thermocouple T: Type T-thermocouple J: Type J-thermocouples X: Thermistor (PST) 21 Tapered penetration Connector Type M- Sub-miniature L- Lumberg connector B- Bipole 22 Chisel penetration 24 Rounded Immersion 26 Corkscrew penetration F K 21 M 28 Alligator Immersion Surface/Contact Type “C” 30 Flat disk (Thermistor) Sequential Number 32 Ribbon 34 Between pack What is the difference between thermocouple and thermistor probes? Thermocouple probes utilize the reaction between two dissimilar metals to produce a voltage that changes as temperature changes. A thermistor is a resistive with a change in temperature. In general, thermocouples offer a wider temperature range and quicker response time than thermistors. Thermistors are typically more accurate than thermocouples. What are the differences between thermocouple types? Each thermocouple uses different metals and there fore have different characteristics. Here are general guidelines: K-Type- Wide temperature range used in many digital thermometers. Identified by a yellow connector. T-Type- Narrower temperature range than J-type but more accurate than K and J types, used in digital thermometers. Identified by a blue connector. J-Type- Narrower temperature reange the K-Type used in analog and digital thermometers. Identified by a black connector. 36 Heavy duty spring Air/Gas Type “G” 40 Air (Thermistor) 42 Beaded thermocouple 44 Hooded 46 Caged 48 Caged with rack clip Can different thermocouple types be interchanged? No. Since each thermocouple type uses different metals in it’s construction they have different output characteristics. Using a J-type thermocouple in a K-type thermometer will cause measurements to be very inaccurate. What are the differences between the connector types TPI offers? Sub-Mini- This is an industry standard connector type allowing TPI probes to be used in any thermocouple thermometer using this type of connector. Sub-mini connectors are quick and easy to use, simply push in and out. A wide variety of economical probes are available with sub-mini connectors, enhancing versatility and affordability of the temperature tester. Lumberg- This connector uses a screw collar to attach to the thermometer and is the most secure connection available. Lumberg connectors are designed for the rigors of food processing environments. Advantages include: • Strong connection - stainless steel collar holds and protects connection. Probe will not pull out of instrument with out unscrewing the collar. • Waterproof stainless steel will not rust and is ideal for wet, humid conditions • Lumberg connectors are manufactured following ISO9000 quality control guidelines. Bi-Polar- This connector is used in the TPI thermistor probe line. 2 Sub-Mini Connector Lumberg Connector Bipolar Connectors REFER TO THE TPI WEBSITE FOR ADDITIONAL OR OEM PROBE OPTIONS Copyright © 2008 Test Products International, Inc. www.tpi-thevalueleader.com • 503.520.9197 Contact/Surface Probe Applications (C) Penetration / Immersion Probe Applications (F) • Measure grill temperature to assure correct cooking temperatures. • Check internal food temperatures to assure quality control. • Measure deep fat fryers with a high temp immersion probe. • Measure liquids and semi-solid temperatures in food processing applications. • Use a reduced tip probe for quicker response times where time is crucial to the process. • Check frozen food to assure proper storage temperatures. • Measure temperatures between package to ensure proper quality control. • Check any surface for correct process control temperatures. Air/Gas Probe Applications. (G) • Measure superheats on condensers. • Measure air temperatures in duct work. • Measure air temperature coming from diffusers while Trouble-shooting heating and air conditioning systems. • Measure flame temperatures to trouble-shoot industrial heating applications. • Calibrate thermostats using an ambient air probe. • Measure griddle temperature. • Measure mackinery or mold temperature with a surface probe. • Measure pipe temperatures in any industrial application. Penetration/Immersion (F) Probe Tips Use for penetation into solids and immersion into semi-solids & liquids. Contact/ Immersion (C) Air/Gas (G) Measure air or gas temperatures Designed to measure surface temperatures Pointed: Can be used in air with slower response Ribbon: Fast response. Chisel: Can be used in air and on surfaces with Spring: Heavy duty sensing element for higher slower response surface temperatures Tapered: Heavy duty, large diameter shaft for bend resistant Beaded: Flexible, can be used in some liquid immersion applications Hooded: Rigid, hood provides protection for the sensing element. Caged: Rigid, cage provides maximum protection for the sensing element. What type of probe should I use? The type of probe you use depends upon your application. Here are some general guidelines for different types of probes. Penetration/Immersion (F) General purpose probe used for penetration and immersion; can be used for air, but is much slower than an air probe. Need to select the tip type that best cuits the application. Contact/Surface (C) Contact probes are used to measure surface temperatures. Penetration probes, with the exception of the chisel tip, can’t measure surface temperatures. Need to select the tip type that best suits the application Air/Gas (G) Air probes measure the air or gas temperatures. They respond significantly faster than penetration or contact probes in air. Need to select the tip type that best fits the application. K-Type Thermocouple with Sub-Mini Connector Probes Model # Description Application Range°F°C Contact temperaCK11M -58° to 500°F Contact surface tures on flat and -50° to 250°C probe, water proof uneven surfaces CK12M Contact temperaContact surface tures on flat and probe, right angle, uneven surfaces waterproof Contact temperaCK13M tures on flat and Heavy-duty contact uneven high temsurface probe perature surfaces CK14M Contact temperaRight angle heavy- tures on flat and duty contact surface uneven high temprobe perature surfaces CK15M Contact temperaHeavy-duty contact tures on flat and surface probe for uneven high temperature surfaces HK11M handle Probe tip 32 -58° to 500°F -50° to 250°C 32 -58° to 1202°F -50° to 650°C 36 -58° to 1202°F -50° to 650°C 36 -40° to 950°F -40° to 510°C 36 Dimensions Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: 4" (102mm) 0.13" (3.2mm) 39.4" (1M) N/A 4" (102mm) w/90° bend 0.3" (7.5mm) 39.4" (1M) N/A 4" (102mm) 0.6" (14mm) 39.4" (1M) N/A 6" (152mm) w/90° bend 0.6" (14mm) 39.4" (1M) N/A 8" (203mm) 0.6" (14mm) N/A N/A REFER TO THE TPI WEBSITE FOR ADDITIONAL OR OEM PROBE OPTIONS Copyright © 2008 Test Products International, Inc. Insulation Material Polyurethane Polyurethane Polyurethane Polyurethane N/A 3 www.tpi-thevalueleader.com • 503.520.9197 K-Type Thermocouple with Sub-Mini Connector Probes Model # Description Range°F°C Probe tip -40° to 950°F -40° to 510°C 36 -40° to 500°F -50° to 250°C 32 CK18M Contact surface probe Contact temper-58° to 500°F atures on flat -50° to 250°C surfaces 32 CK20M Pipe clamp probe Clamp probe for -58° to 212°F pipe tempera-50° to 100°C tures N/A CK21M Pipe clamp probe Clamp probe for -58° to 212°F pipe tempera-50° to 100°C tures N/A Application Contact temperaCK16M tures on flat and Heavy-duty contact uneven high temsurface probe perature surfaces CK17M Contact temperaContact surface tures on flat and probe, 45 degree uneven surfaces angle CK22M Contact temper- atures on flat -58° to 500°F Fast response contact surface probe, 45 degree and uneven sur- -50° to 250°C faces angle swivel head sensor CK23M 32 Contact temper- atures on flat -58° to 500°F Fast response contact surface probe, 90 degree and uneven sur- -50° to 260°C faces angle swivel head sensor General purpose FK11M penetration into -58° to 500°F Chisel tip penetrasemi-solids and -50° to 250°C tion probe liquids 32 20 Heavy duty penetra- FK12M tion into semi-solids Pointed tip tapered and liquids tapered penetration probe shaft resist bending FK13M General purpose Pointed tip penetra- penetration into tion probe for semi-solids and HK11M handle liquids General purpose FK14M penetration into Chisel tip penetrasemi-solids and tion probe liquids Food temperature FK15M Tapered tip low mass measurements quick response pene- and other light tration probe duty applications -58° to 500°F -50° to 250°C 21 -40° to 1562°F -40° to 850°C 20 -40° to 1562°F -40° to 850°C 20 -58° to 500°F -50° to 250°C 20 General purpose light -58° to 500°F duty penetration applications requiring -50° to 250°C fast response 21 General purpose light FK22M -58° to 500°F duty penetration Pointed tip penetra- applications requiring -50° to 250°C tion probe fast response 21 General purpose FK23M -40° to 950°F air / liquid probe Rack clamp probe -40° to 510°C with clip 28 FK24M General purpose Heavy duty T-handle penetration into -40° to 500°F long stem penetra- semi-solids and -40° to 250°C tion probe liquids 21 FK21M Tapered chisel tip penetration probe 4 Dimensions Stem Length: 8" (203mm) Diameter: 0.6" (14mm) Lead Length: 39.4" (1M) IP Rating: N/A Stem Length: 4" (102mm) w/45° bend Diameter: 0.3" (7.5mm) Lead Length: 39.4" (1M) IP Rating: N/A Stem Length: N/A Nomin: 2.36" (60mm) Lead Length: 39.4" (1M) IP Rating: N/A Max jaw opening: 0.79" Nominal jaw opening: 0.25" Lead Length: 39.4" (1M) IP Rating: N/A Max jaw opening: 1.2" Nominal jaw opening: 0.75" Lead Length: 39.4" (1M) IP Rating: N/A Stem Length: 4.5" (114mm) w/45° bend Diameter: 0.5" (12.7mm) Lead Length: 39.4" (1M) IP Rating: N/A Stem Length: 4.9" (125mm) w/90° bend Diameter: 0.5" (12.7mm) Lead Length: 39.4" (1M) IP Rating: Stem Length: 4" (102mm) Diameter: 0.13" (3.2mm) Lead Length: 39.4" (1M) IP Rating: 67 Stem Length: 11.8" (300mm) Diameter: 0.25 / 0.10" (6.4 / 2.5mm) Lead Length: 39.4" (1M) IP Rating: 67 Stem Length: 8" (203mm) Diameter: 0.15" (3.75mm) Lead Length: N/A IP Rating: 67 Stem Length: 8" (203mm) Diameter: 0.15" (3.75mm) Lead Length: 39.4" (1M) IP Rating: 67 Stem Length: 3.75" (80mm) Diameter: 0.06 (1.6mm) Lead Length: 39.4" (1M) IP Rating: N/A Stem Length: 4.” (101.6mm) Diameter: 0.13”/.06” (3.2/1.6mm) Lead Length: 39.4” (1M) IP Rating: 67 Stem Length: 4" (101.6mm) Diameter: 0.09/0.06" (3.2/2.5mm) Lead Length: 39.4" (1M) IP Rating: N/A Stem Length: N/A Diameter: N/A Lead Length: 177" (4.5M) IP Rating: 67 Stem Length: 24" (610mm) Diameter: 0.37"/0.15" (9.5mm/3.76mm) Lead Length: 39.4" (1M) IP Rating: 67 Insulation Material Polyurethane Polyurethane Polyurethane Polyurethane Polyurethane Polyurethane Polyurethane Polyurethane Polyurethane N/A Polyurethane Teflon Polyurethane Teflon Teflon Polyurethane REFER TO THE TPI WEBSITE FOR ADDITIONAL OR OEM PROBE OPTIONS Copyright © 2008 Test Products International, Inc. www.tpi-thevalueleader.com • 503.520.9197 K-Type Thermocouple with Sub-Mini Connector Probes Model # Description Application Range°F°C Probe tip FK25M Flat sensor pack probe Between pack temperatures -40° to 400°F -40° to 204°C 34 FK26M Petes plug probe Petes plug temperatures -40° to 400°F -40° to 204°C 24 FK27M Waterproof long stem heavy duty penetration probe General purpose penetration into -58° to 500°F semi-solids and -50° to 250°C liquids 21 FK28M Heavy duty penetration probe Heavy duty penetration into semi-solids -58° to 500°F and liquids tapered -50° to 250°C shaft resist bending 22 General purpose FK29M penetration into Long stem pointed semi-solids and tip penetration probe liquids Heavy duty penetraFK30M Long stem heavy tion into semi-solids duty T-handle pene- and liquids tapered shaft resist bending tration probe -58° to 500°F -50° to 250°C 22 -58° to 500°F -50° to 250°C 22 FK31M General purpose -58° to 500°F T-handle corkscrew penetration into -50° to 250°C insertion probe semi-solids 26 Must be used with EXT31M extension (included) FK32M Long stem heavy duty T-handle penetration probe Heavy duty penetration into semi-solids -58° to 500°F and liquids tapered -50° to 250°C shaft resist bending 24 GK11M General purpose beaded tip probe Exposed junction for fast response in non- -40° to 950°F food liquid, air and -40° to 510°C surface applications 42 GK12M General purpose beaded tip probe with rack clip Exposed junction for fast response in air applications. -40° to 950°F -40° to 510°C 42 GK13M General purpose beaded tip probe Exposed junction for fast response in -40° to 400°F food and non-food liquid, air and sur- -40° to 204°C face applications 42 Exposed junction for fast response in air applications. -58° to 910°F -40° to 510°C 44 GK16M Caged exposed -40° to 500°F General purpose caged junction for fast air probe for use with -40° to 260°C response in air HK11M handle 46 GK14M Rigid stem hooded exposed tip probe GK17M General purpose caged air probe Caged exposed -40° to 500°F junction for fast -40° to 260°C response in air 46 GK18M General purpose caged air probe with rack clip and armored cable GK19M General purpose beaded tip probe with armored cable Caged exposed -40° to 586°F junction for fast -40° to 308°C response in air 48 Exposed junction for fast response in -40° to 950°F non-food liquid, air and surface appli- -40° to 510°C cations 42 Dimensions Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: N/A N/A 39.4" (1.2M) 67 3" (76mm) 0.12" (3mm) 39.4" (1M) 67 11.8" (300mm) 0.25"/0.10" (6.4mm/2.5mm) 39.4" (1M) 67 6.3" (160mm) 0.13" (3.2mm) 39.4" (1M) N/A 6.3" (160mm) 0.13" (3.2mm) 39.4" (1M) N/A 24" (609.60mm) 0.38" (9.5mm) 39.4” (1M) 67 4.5" (114mm) 0.20" (5mm) 39.4" (1M) 67 18" (457mm) 0.37"/0.15" (9.5mm/3.76mm) 39.4" (1M) 67 N/A 28 gauge 48" (1.2M) N/A N/A 20 gauge 48" (1.2M) N/A N/A 24 gauge 48" (1.2M) N/A 3.74" (95mm) 0.13" (3.75mm) 39.4" (1M) N/A 8" (203mm) 0.26" (6.5mm) 39.4" (1M) N/A 8" (203mm) 0.26" (6.5mm) 39.4" (1M) N/A N/A N/A 39.4" (1M) N/A N/A 28 gauge 48" (1.2M) N/A REFER TO THE TPI WEBSITE FOR ADDITIONAL OR OEM PROBE OPTIONS Copyright © 2008 Test Products International, Inc. Insulation Material Polyurethane Polyurethane Polyurethane Polyurethane Polyurethane Polyurethane Polyurethane Polyurethane Fiberglass Fiberglass Teflon Polyurethane N/A Polyurethane Braided stainless steel Braided stainless steel 5 www.tpi-thevalueleader.com • 503.520.9197 K-Type Thermocouple with Sub-Mini Connector Probes Model # Description Application Range°F°C GK20M Flue temperature probe Exposed junction with cone stop, fast response in flue temperature applications -40° to 932°F -40° to 260°C 42 EXT 31M Male to Male Extension Use with FK31M N/A N/A N/A N/A HK11M Use with Handle for use with FK13M, CK15M, K-type interchangeand GK16M able probe tips Probe tip Dimensions Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: 4.33" (110mm) 0.24" (6mm) 16' (4.9M) N/A NA NA 39.4” (1M) N/A N/A N/A 39.4" (1M) N/A Insulation Material Teflon Polyurethane Polyurethane J-Type Thermocouple with Sub-Mini Connector Probes Model # Application Description GJ11M Exposed juncStandard fiberglass insulation, 4 foot, bead- tion for fast response ed end (disposable) Oven clip to GJ12M shield sensor GJ11M with from direct oven clip radiated heat Range°F°C Probe tip Dimensions Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: -40° to 950°F -40° to 500°C -40° to 950°F -40° to 500°C N/A 24 Gauge 1.2 N/A N/A 24 Gauge 1.2 N/A Insulation Material Fiberglass Fiberglass K-Type Thermocouple with Lumberg Connector Probes Model # Description FK21L Contact surface probe with ribbon sensor. Water proof Probe tip Application Range°F°C Food Penetration -58° to 500°F -50° to 250°C 21 FK22L Oven food probe Testing food temperatures during cooking -58° to 500°F -50° to 250°C 20 FK23L Immersion / Penetration probe no handle or lead Food Penetration -58° to 500°F -50° to 250°C 21 FK25L Flat sensor pack probe Between pack -40° to 400°F -40° to 204°C 34 FK26L Immersion / Penetration probe Food Penetration -58° to 500°F -50° to 250°C 20 Dimensions Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: 4” (101.6mm) 0.13/.06” (3.2/1.6mm) 39.4” (1M) 67 4”(101.6mm) 0.09/.06” (3.2/1.6mm) 47.2” (1.2M) 3.9”(100mm) 0.15” (3.75mm) NA 67 NA NA 47.2” (1.2M) 67 4”(101.6mm) .09/.06” (2.4/1.6mm) 39.4” (1M) 67 Insulation Material Polyurethane Teflon NA Teflon Polyurethane T-Type Thermocouple with Lumberg Connector Probes Model # Description Application Range°F°C Probe tip CT11L Surface probe with ribbon sensor Surface Temperatures Grills -58° to 500°F -50° to 250°C 32 Stem Length: Diameter: Lead Length: IP Rating: 4”(102mm) 0.13” (3.2mm) 39.4” (1M) N/A General purpose FT11L penetation into -148° to 500°F Chisel tip penetra- semi-solids and -100° to 250°C tion probe liquids 22 Stem Length: Diameter: Lead Length: IP Rating: 4”(101.6mm) 0.13/.15” (3.2mm/2.2mm) Polyurethane 39.4” (1M) 67 6 Dimensions Insulation Material PVC REFER TO THE TPI WEBSITE FOR ADDITIONAL OR OEM PROBE OPTIONS Copyright © 2008 Test Products International, Inc. www.tpi-thevalueleader.com • 503.520.9197 T-Type Thermocouple with Lumberg Connector Probes Model # Description Application Range°F°C Probe tip FT12L Needle probe Weiner probe for food processing -148° to 500°F -100° to 250°C 22 FT15L Needle probe Weiner probe for food processing -148° to 500°F -100° to 250°C 22 FT21L Tapered end for food penetration Waterproof Food penetration -148° to 500°F -100° to 250°C 21 FT22L Oven food probe Testing food temperature during cooking -40° to 500°F -50° to 250°C 22 FT23L Oven food probe Testing food temperature during cooking -40° to 950°F -40° to 510°C 28 -40° to 500°F -40° to 250°C 21 -148° to 500°F -100° to 250°C 42 FT24L General purpose Heavy duty T-handle penetration into long stem penetra- semi-solids and tion probe liquids GT13L General Beaded probe with FDA approved Purpose. Air insulation GT19L Oven clamp probe Special -40° to 500°F hangingClip for -40° to 510°C ovens. Air. 48 Dimensions Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Insulation Material 4”(101.6mm) 0.13”(3.2mm) PVC 39.4” (1.0M) 67 3.15”(80mm) 0.06”(1.6mm) Teflon 39.4” (1.2M) N/A 3.75”(95.3mm) 3.2/1.6mm PVC 39.4” (1.0M) 67 3.93”(100mm) 0.13” (3.2mm) Teflon 98.4” (2.5M) N/A NA NA Teflon 177.2” (4.5M) N/A 24" (610mm) 0.37"/0.15" (9.5mm/3.76mm) Polyurethane 39.4" (1M) 67 NA NA Teflon 47.2” (1.2M) 67 NA NA SS 39.4” (1M) 67 Thermistor Probe with Lumberg Connectors Model # Description FX11L Liquid immersion probe Application Range°F°C General -40° to 300°F Purpose, Liquid -40° to 150°C Probe tip 24 Dimensions Stem Length: Diameter: Lead Length: IP Rating: 4”(102mm) 0.13” (3.2mm) 39.4” (1M) 67 Insulation Material PVC Thermistor Probe with Bipolar Connectors Model # Description Application Range°F°C Probe tip CX13B Surface flat disk probe Surface -40° to 300°F -40° to 150°C 30 FX12B Liquid immersion probe General Purpose -40° to 300°F -40° to 150°C 24 FX13B Liquid immersion probe General Purpose -40° to 300°F -40° to 150°C 24 GX15B Shielded air probe Air -40° to 300°F -40° to 150°C 44 EX11B extension lead Thermistor probes N/A NA Dimensions Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: Stem Length: Diameter: Lead Length: IP Rating: 3.15”(80mm) 0.3” (7.5mm) 15.7” (0.4M) N/A 3.15”(80mm) 0.13” (3.2mm) 15.7” (0.4M) N/A 8”(203mm) 0.13” (3.2mm) 15.7” (0.4M) 67 3.15”(80mm) 0.13” (3.2mm) 15.7” (0.4M) N/A N/A N/A 36” (0.9M) N/A REFER TO THE TPI WEBSITE FOR ADDITIONAL OR OEM PROBE OPTIONS Copyright © 2008 Test Products International, Inc. Insulation Material PVC PVC PVC PVC PVC 7 The Val ue Leader • Di gi tal Mul ti meters Probe selection • Di gi tal Cl amp-Ons TPI has three basic types of temperature probes: Penetration/Immersion (F), Contact/Surface (C), and Air/Gas (G). • Temperature Products • • Combusti on Anal yzers • • • Carbon Monoxi de Penetration/Immersion (F) probes are used for liquids, semi-solids, and solids. Contact/Surface (C) probes are designed for surface temperatures. Air/Gas (G) probes are designed to measure air or gas temperatures. Anal yzers Select your type of application and probe tip first. Then match the connector type of the probe to your instrument. • Combusti bl e Gas Detectors • Di gi tal Manometers • Indoor Ai r Qual i t y OEM/specialty temperature probes • Insul ati on Resi stance Whatever your OEM temperature probe needs are, let TPI help you. Just let us have the following information, along with your company and contact information. Testers (IRT) • Handhel d Osci l l i scopes • Refri gerati on Leak Detectors • Coax / BNC Cabl es and Adapters • Osci l l i scope Probes / SMTP Cl i ps 1. 2. 3. 4. 5. 6. 7. Application, environment, and operating temperature New or existing product Annual usage and release quantities Connector type or bare wire details Length of lead wire and straight or coiled wire Probe tip type and dimensions Any other special requirements, materials, etc. • Speci al t y Testers Cost of ownership temperature probe Ask us about a customized cost of ownership temperature probe program. Three Year Limited Warranty on TPI Products Copyright © 2008 Test Products International, Inc. The Val ue Leader ™ Test Products International, Inc. Headquarters: 9615 SW Allen Blvd. Beaverton, OR 97005 USA 503-520-9197 Fax: 503-520-1225 info@tpi-thevalueleader.com Temperature Probe brochures 07.10.08 Test Products International, Ltd. 342 Bronte St. South Unit #9 Milton, Ontario L9T 5B7 Canada 905-693-8558 Fax: 905-693-0888 info@tpicanada.com Test Products International UK Ltd. Longley House, East Park Crawley, West Sussex RH10 6AP England Tel: +44 (0)1293 561212 Fax: +44 (0)1293 813465 e-mail: info@tpi-uk.com For additional products, specifications, and info contact TPI at tpi-thevalueleader.com or 800.368.5719
FK25L 价格&库存
很抱歉,暂时无法提供与“FK25L”相匹配的价格&库存,您可以联系我们找货
