4
3
2
ZONE
ALL
TC-K-01-CA003
TC-K-01-CA006
TC-K-01-CA012
LENGTH IN FEET
TC-K-02-CA003
TC-K-02-CA006
TC-K-02-CA012
TC-K-03-CA003
TC-K-03-CA006
TC-K-03-CA012
C
REV
N/C
BY
RR
NOTES, UNLESS OTHERWISE SPECIFIED:
D
NUMBER OF CONDUCTORS
1
REVISION HISTORY
DESCRIPTION
DATE
INITIAL RELEASE 08/03/2013
1
INSTALL CONNECTORS AS REQUIRED
2
STRIP AND TIN PER IEC-J-STD-001
3
USE STRAIN RELIEF AS REQUIRED
4
CONDUCTORS: ULTRA FLEXIBLE,
FINELY STRANDED, CHROMEL AND ALUMEL
5
MINIMUM BEND RADIUS: 6X CABLE HEIGHT FOR
INTERMEDIATE FLEX;
10X CABLE HEIGHT FOR CONTINUOUS FLEX
6
OUTER JACKET DUROMETER RATING:
65 (SHORE A)
7
CABLE TEMPERATURE RATING:
-65°C TO +260°C
ASSEMBLY TEMPERATURE RATING:
-29°C TO +220°C
8
9
TC-K-04-CA003
TC-K-04-CA006
TC-K-04-CA012
D
THERMOCOUPLE TYPE "K", TC-K-01 BILL OF MATERIALS
QTY
FN
DESCRIPTION PART NUMBE
MFG
1
A/R
2
2
CICOIL CABLE
589R101-1
THERMOCOUPLE SMPW-CC-K-M
CONNECTOR
CICOIL
OMEGA
THERMOCOUPLE TYPE"K", TC-K-02 BILL OF MATERIALS
QTY
FN
MFG
1
A/R
2
4
CICOIL CABLE
589R101-2
THERMOCOUPLE
SMPW-CC-K-M*
CONNECTOR
CICOIL
OMEGA
C
THERMOCOUPLE TYPE "K", TC-K-03 BILL OF MATERIALS
QTY DESCRIPTION PART NUMBE
FN
MFG
OUTER JACKET DIELECTRIC STRENGTH:
450 VOLTS/MILS (17.7 kv/mm)
1
A/R
2
6
CICOIL CABLE
589R101-3
THERMOCOUPLE
SMPW-CC-K-M*
CONNECTOR
CICOIL
OMEGA
*OR EQUIVALENT
THERMOCOUPLE TYPE "K", TC-K-04 BILL OF MATERIALS
QTY
FN
MFG
1
A/R
2
8
CICOIL CABLE
589R101-4
THERMOCOUPLE
SMPW-CC-K-M*
CONNECTOR
CICOIL
OMEGA
THERMOCOUPLE TYPE "K", TC-K-08 BILL OF MATERIALS B
B
FN
1
QTY
A/R
2
16
DESCRIPTION PART NUMBER
MFG
CICOIL CABLE
589R101-8
CICOIL
THERMOCOUPLE
SMPW-CC-K-M* OMEGA
CONNECTOR
TC-K-08-CA003
TC-K-08-CA006
TC-K-08-CA012
THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF
CICOIL LLC AND ARE ISSUED IN STRICT CONFIDENCE AND SHALL NOT
BE REPRODUCED OR COPIED OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE 0F EQUPMENT WITHOUT PERMISSION.
STANDARD TOLERANCES
UNLESS OTHERWISE NOTED
DIMENSIONS ARE IN INCHES
.X+/- 0.5
.XX+/-0.05
.XXX+/-0.005
ANGLES +/- 5 DEG
[MM]
A
VIEW PROJECTION
DATE
SIGNATURE
24960 AVENUE TIBBITTS, VALENCIA, CA 91355 www.cicoil.com 661-295-1295
DRAWN:
rruiz
CHECK
JOHN PALAHNUK
ENGINEER
JOHN PALAHNUK
9/3/2013
TITLE
9/3/2013
9/3/2013
SIZE
CAGE CODE
DASH
NO
QTY
REQD
NEXT
ASSEMBLY
FINAL
ASSEMBLY
MATERIAL:
19476
DRAWING NUMBER
A
REVISION
TC-K-0X-CAXXX
N/C
APPLICATION
SCALE
DO NOT SCALE DRAWING
4
3
2
FILE: TC-K-0X (C).idw
SHEET 1 OF 3
1
很抱歉,暂时无法提供与“TC-K-08-CA003”相匹配的价格&库存,您可以联系我们找货
