TC-K-04-CA012
TC-K-04-CA012
    CICOIL
    THERMOCOUPLE K 4 COND 28AWG 12'
TC-K-04-CA012 数据手册
4 3 2 ZONE ALL TC-K-01-CA003 TC-K-01-CA006 TC-K-01-CA012 LENGTH IN FEET TC-K-02-CA003 TC-K-02-CA006 TC-K-02-CA012 TC-K-03-CA003 TC-K-03-CA006 TC-K-03-CA012 C REV N/C BY RR NOTES, UNLESS OTHERWISE SPECIFIED: D NUMBER OF CONDUCTORS 1 REVISION HISTORY DESCRIPTION DATE INITIAL RELEASE 08/03/2013 1 INSTALL CONNECTORS AS REQUIRED 2 STRIP AND TIN PER IEC-J-STD-001 3 USE STRAIN RELIEF AS REQUIRED 4 CONDUCTORS: ULTRA FLEXIBLE, FINELY STRANDED, CHROMEL AND ALUMEL 5 MINIMUM BEND RADIUS: 6X CABLE HEIGHT FOR INTERMEDIATE FLEX; 10X CABLE HEIGHT FOR CONTINUOUS FLEX 6 OUTER JACKET DUROMETER RATING: 65 (SHORE A) 7 CABLE TEMPERATURE RATING: -65°C TO +260°C ASSEMBLY TEMPERATURE RATING: -29°C TO +220°C 8 9 TC-K-04-CA003 TC-K-04-CA006 TC-K-04-CA012 D THERMOCOUPLE TYPE "K", TC-K-01 BILL OF MATERIALS QTY FN DESCRIPTION PART NUMBE MFG 1 A/R 2 2 CICOIL CABLE 589R101-1 THERMOCOUPLE SMPW-CC-K-M CONNECTOR * CICOIL OMEGA THERMOCOUPLE TYPE"K", TC-K-02 BILL OF MATERIALS QTY FN DESCRIPTION PART NUMBE MFG 1 A/R 2 4 CICOIL CABLE 589R101-2 THERMOCOUPLE SMPW-CC-K-M* CONNECTOR CICOIL OMEGA C THERMOCOUPLE TYPE "K", TC-K-03 BILL OF MATERIALS QTY DESCRIPTION PART NUMBE FN MFG OUTER JACKET DIELECTRIC STRENGTH: 450 VOLTS/MILS (17.7 kv/mm) 1 A/R 2 6 CICOIL CABLE 589R101-3 THERMOCOUPLE SMPW-CC-K-M* CONNECTOR CICOIL OMEGA *OR EQUIVALENT THERMOCOUPLE TYPE "K", TC-K-04 BILL OF MATERIALS QTY FN DESCRIPTION PART NUMBE MFG 1 A/R 2 8 CICOIL CABLE 589R101-4 THERMOCOUPLE SMPW-CC-K-M* CONNECTOR CICOIL OMEGA THERMOCOUPLE TYPE "K", TC-K-08 BILL OF MATERIALS B B FN 1 QTY A/R 2 16 DESCRIPTION PART NUMBER MFG CICOIL CABLE 589R101-8 CICOIL THERMOCOUPLE SMPW-CC-K-M* OMEGA CONNECTOR TC-K-08-CA003 TC-K-08-CA006 TC-K-08-CA012 THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CICOIL LLC AND ARE ISSUED IN STRICT CONFIDENCE AND SHALL NOT BE REPRODUCED OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE 0F EQUPMENT WITHOUT PERMISSION. STANDARD TOLERANCES UNLESS OTHERWISE NOTED DIMENSIONS ARE IN INCHES .X+/- 0.5 .XX+/-0.05 .XXX+/-0.005 ANGLES +/- 5 DEG [MM] A } VIEW PROJECTION DATE SIGNATURE 24960 AVENUE TIBBITTS, VALENCIA, CA 91355 www.cicoil.com 661-295-1295 DRAWN: rruiz CHECK JOHN PALAHNUK ENGINEER JOHN PALAHNUK 9/3/2013 TITLE 9/3/2013 THERMOCOUPLE TYPE "K" 9/3/2013 SIZE CAGE CODE DASH NO QTY REQD NEXT ASSEMBLY FINAL ASSEMBLY MATERIAL: 19476 DRAWING NUMBER A REVISION TC-K-0X-CAXXX N/C APPLICATION SCALE DO NOT SCALE DRAWING 4 3 2 FILE: TC-K-0X (C).idw SHEET 1 OF 3 1
TC-K-04-CA012 价格&库存
很抱歉,暂时无法提供与“TC-K-04-CA012”相匹配的价格&库存,您可以联系我们找货
TC-K-04-CA012
  • 2+4126.786052+515.68197
