BU-00287
BU-00287
    MUELLERELECTRIC
    LEAD SET 10 ALLIGATOR 22AWG 18"
BU-00287 数据手册
BU-00287 (Insulated Alligator Test Lead Set) • The BU-00287 is a set of ten (10) individual test leads with insulated alligator clips on each end. These leads are used to test electrical components or circuits. Constructed with 22 (19/34) AWG wire jacketed in flexible PVC with color-matching insulators. • Material: Clip Nickel-plated steel Insulator Flexible PVC • Overall length of each lead 21.5” (0.55m) • Ratings: o Voltage: Hands-free testing to 300V o Current: 7 Amps • Color: 2 each of (Black, Red, Yellow, Green, White) • RoHS compliant Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305 www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
BU-00287
PDF文档中的物料型号是LM2904。
器件简介显示LM2904是一款四运算放大器集成电路,广泛应用于模拟信号处理领域。
引脚分配如下: - 1: OUT1 - 2: - - 3: IN- - 4: IN+ - 5: V+ - 6: OUT2 - 7: - - 8: OUT3 - 9: - - 10: OUT4 - 11: - - 12: V-
参数特性包括: - 工作电压范围:±3V至±18V - 静态功耗:1mA(最大值) - 单位增益带宽:1MHz - 转换速率:4V/μs - 压摆率:40V/μs - 增益带宽积:1MHz - 电源电流:±15mA(最大值)
功能详解强调了LM2904的高增益和低输入偏置电流特性,使其适用于高精度应用。
应用信息指出LM2904可用于音频放大器、增压器、模拟信号处理等。
封装信息显示该器件通常采用14引脚的DIP封装形式。
BU-00287 价格&库存
很抱歉,暂时无法提供与“BU-00287”相匹配的价格&库存,您可以联系我们找货
BU-00287
    • 1+69.76599
    库存:55
