TLS2011
TLS2011
    TPI(TPI 公司)
    48.0" (1219.20mm) Alligator Clip, Insulated To Alligator Clip, Insulated Test Lead 600VDC
TLS2011 数据手册
TLS2011 JUMPER LEAD SET (PVC INSULATION) Color identification is safe way to work on electrical circuits Four-piece Color Coded Jump Lead Set • Alligator clips on both ends securely grip terminal connections • Coiled cord stretches to 48” (122cm) for extra reach • Coil cords recoil requiring minimum storage space and less tangling • Heavy duty but flexible rubber boots provide safety insulation and wire connection strain relief • Soldered and clamped wire connections to alligator clips provides low signal loss and prolongs life • Four distinct colors facilitate easy identification of test circuits Copyright © 2008 Test Products International, Inc. Voltage Rating 600 V Amperage Rating Insulation Material 10 Amp PVC Dimensions Lead Length: 48 inches (122cm) Jaw Opening: N/A Type Alligator clip to alligator clip jumper leads. Voltage / Amperage Rating Category Rating Type Dimensions Insulation Material
TLS2011 价格&库存
很抱歉,暂时无法提供与“TLS2011”相匹配的价格&库存,您可以联系我们找货
