TLS2010
TLS2010
    TPI(TPI 公司)
    JUMPER LEAD KIT STRAIGHT MULTI
TLS2010 数据手册
TLS2010 JUMPER LEAD SET (PVC INSULATION) Color identification is safe way to work on electrical circuits Four-piece Color Coded Jump Lead Set • Alligator clips on both ends securely grip terminal connections • Lead length is 48” (122cm) for extra reach • Heavy duty but flexible rubber boots provide safety insulation and wire connection strain relief • Soldered and clamped wire connections to alligator clips provides low signal loss and prolongs life • Four distinct colors facilitate easy identification of test circuits Copyright © 2008 Test Products International, Inc. Voltage Rating 600 V Amperage Rating Insulation Material 10 Amp PVC Dimensions Lead Length: 48 inches (122cm) Type Alligator clip to alligator clip jumper leads. Voltage / Amperage Rating Category Rating Type Dimensions Insulation Material
TLS2010 价格&库存
很抱歉,暂时无法提供与“TLS2010”相匹配的价格&库存,您可以联系我们找货
