TLS2021
TLS2021
    TPI(TPI 公司)
    JUMPER LEAD KIT COILED BLACK
TLS2021 数据手册
TLS2021 JUMPER LEAD SET (PVC INSULATION) Multiple length jump leads for working on electrical circuits Four-piece, Four Length Jump Lead Set • Four distinct sizes facilitate various applications that make the job easier to complete • Alligator clips on both ends securely grip terminal connections • Coil cords recoil requiring minimum storage space and less tangling • Heavy duty but flexible rubber boots provide safety insulation and wire connection strain relief • Soldered and clamped wire connections to alligator clips provides low signal loss and prolongs life Copyright © 2008 Test Products International, Inc. Voltage Rating 600 V Amperage Rating Insulation Material 10 Amp PVC Dimensions Lead Length: 12 inches (30cm) 18 inches (46cm) 24 inches (61cm) 120 inches (305cm) Type Alligator clip to alligator clip jumper leads. Voltage / Amperage Rating Category Rating Type Dimensions Insulation Material
TLS2021 价格&库存
很抱歉,暂时无法提供与“TLS2021”相匹配的价格&库存,您可以联系我们找货
