BU-7042-F-48-2
BU-7042-F-48-2
    MUELLERELECTRIC
    TEST LEAD BANANA TO PROBE 48"
BU-7042-F-48-2 数据手册
BU-7042-F-XX-@ (Dual Tip Probe Test Lead, Kelvinized) • The BU-7042-F is a test lead with a Kelvinized, dual, pogo tipped test probe (probe tips electrically isolated). Each probe tip is spring loaded to promote solid contact when the probe is held at an angle or the surface being tested is uneven. • The tab at the end of the probe corresponds to the tab on the dual 4mm banana plug. • The connecting cable is RG174 and has a 50 Ohm impedance. The pin spacing on the probe is 0.124”. • Material: Contact Gold-plated beryllium copper Body Polypropylene • Ratings: Voltage 30 V Max. • Length: The “XX” in the model number indicates length. Available lengths: 44”, 48”, 60”, 72”, 120”, 144”, 300”, 480” • Color: The “@” in the model number indicates color. Available colors: -0 Black, -2 Red Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305 www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
BU-7042-F-48-2 价格&库存
很抱歉,暂时无法提供与“BU-7042-F-48-2”相匹配的价格&库存,您可以联系我们找货
