BU-PB24-5
BU-PB24-5
    MUELLERELECTRIC
    TESTLEADBANANATOBANANA24"
BU-PB24-5 数据手册
BU-PBXX-@ (Test Lead: Stackable Banana Plugs Each End) • Mueller’s BU-PB is a test lead with stackable, 4mm banana plugs on each end. The banana plugs mate with any standard 4mm banana jack. • Constructed with PVC-jacketed, 18 AWG test lead wire and has color matching overmolded banana plugs. • Materials: Banana plug Nickel-plated beryllium copper Wire insulation PVC Overmold Polypropylene • Ratings: Current 15 Amps Voltage Hands-free testing to 1000V • Length: The “XX” in the part number represents overall length in inches. Standard lengths: 4”, 12”, 18”, 24”, 36”, 48”, 60”, 72” • Color: The “@” in the model number represents color. Available colors: -0 Black, -2 Red, -4 Yellow, -5 Green, -6 Blue, -9 White • RoHS 3 compliant Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305 www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
BU-PB24-5
物料型号:BU-PBXX-@
器件简介:Mueller的BU-PB是一种测试线,两端都有可堆叠的4mm香蕉插头。香蕉插头可以与任何标准的4mm香蕉插座配对。
引脚分配:文档中没有提供具体的引脚分配信息。
参数特性: - 材料:香蕉插头 - 镀镍铍铜 - 线绝缘 - PVC - 外模 - 聚丙烯 - 额定电流:15安培 - 电压:免提测试至1000V
功能详解:文档中没有提供详细的功能解释。
应用信息:文档中没有提供具体的应用信息
封装信息:长度 - “XX”在型号中代表总长度(英寸)。标准长度有4", 12", 18", 24", 36", 48", 60", 72"。 颜色 - “@”在型号中代表颜色。可用颜色有:-0黑色,-2红色,-4黄色,-5绿色,-6蓝色,-9白色。
BU-PB24-5 价格&库存
很抱歉,暂时无法提供与“BU-PB24-5”相匹配的价格&库存,您可以联系我们找货
BU-PB24-5
  • 1+64.117821+8.30550
  • 50+59.3198950+7.68400
  • 100+57.13901100+7.40150
